Hi,
OpenMandriva has a Zen optimized build available. All packages are build using a special flag including the Java Virtual Machine. I tested this out on a Threadripper system (3960X). There is some significant performance impact compiling java code to native code using OpenMandriva compared to Manjaro (mvn clean client:build -P build.Android):
- Manjaro 20.02: [total]: 85,509.19 ms, 7.64 GB (1.42 minutes)
- ClearLinux: [total]: 75,645.77 ms, 6.65 GB (1.26 minutes)
- openMandriva zver1: [total]: 78,610.22 ms, 7.59 GB (1.31 minutes)
- Fedora 32: [total]: 79,950.81 ms, 6.92 GB (1.33 minutes)
That is an 8% performance gain comparing Manjaro to openMandriva.
Now my question, is it possible to build Manjaro using this new compilation flag? I am not sure if this is easy or how much work is involved. OpenMandriva has an open build server (see link above, ABF). Does Manjaro also have this available to try out or is it build internally?
Many thanks for your help!
Bart
