Booting stops on message with:
/dev/sda4: clean, 1275992/23920640 files, 18109937/95682560 blocks
was it working previously? were you updating/uninstalling/installing …etc?
are you using nvidia?
do you have installed more than one kernel? if so try with different kernel;
you can enter into tty in the stuck screen with: ctrl+alt+f2 - or f1-f6 keys, enter your username/password, and type:
startx
and see if it helps
Yes, It worked previously. I did a update a few day’s ago, it still worked then. But now it just stay like I mentioned above.
I am using amd.
I tried updating to linux515, but it still came up the same as before.
As for: `startx
[manjaro /]# startx
xauth: error in locking authority file /home/manjaro/.Xauthority
_XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
(EE)
Fatal server error:
(EE) Cannot establish any listening sockets - Make sure an X server isn't already running(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
Authorization required, but no authorization protocol specified
xinit: giving up
xinit: unable to connect to X server: Resource temporarily unavailable
xinit: server error
it looks like its the xauthority file, so remove it:
rm /home/manjaro/.Xauthority
reboot:
systemctl reboot
post output from:
find $HOME/ -name ".Xauthority"
so remove it too:
rm /home/qwq/.Xauthority
reboot and see if it helped
It’s still the same as before. Still stuck on clean…files
so again log into tty and type startx and post a picture of the output
you should have rebooted after removing the file… according to logs you didnt and then typed startx which didnt work because the xauthority was removed …
I tried deleting it and then rebooting. But I am still is stuck as the before.
so take a pic of this:
cat /home/qwq/.local/share/xorg/Xorg.0.log
Here’s the result
[ 2822.650]
X.Org X Server 1.21.1.4
[ 2822.650] Current Operating System: Linux qwq 5.15.72-1-MANJARO #1 SMP PREEMPT Thu Oct 6 07:30:22 UTC 2022 x86_64
[ 2822.650] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=d5b75c0a-a901-4846-8fb7-9c83f17ccc83 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 2822.651]
[ 2822.651] Current version of pixman: 0.40.0
[ 2822.651] Before reporting problems, check http://wiki.x.org
[ 2822.651] Markers: (--) probed, (**) from config file, (==) default setting,
[ 2822.652] (==) Log file: "/home/qwq/.local/share/xorg/Xorg.0.log", Time: Thu Oct 13 18:12:26 2022
[ 2822.652] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2822.653] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2822.653] (==) No Layout section. Using the first Screen section.
[ 2822.653] (==) No screen section available. Using defaults.
[ 2822.653] (**) |-->Screen "Default Screen Section" (0)
[ 2822.653] (**) | |-->Monitor "<default monitor>"
[ 2822.653] (==) No monitor specified for screen "Default Screen Section".
[ 2822.653] (==) Automatically adding devices
[ 2822.653] (==) Automatically enabling devices
[ 2822.653] (==) Automatically adding GPU devices
[ 2822.653] (==) Automatically binding GPU devices
[ 2822.654] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2822.654] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 2822.654] Entry deleted from font path.
[ 2822.654] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2822.654] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2822.654] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2822.654] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 2822.654] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2822.654] (II) The server relies on udev to provide the list of input devices.
[ 2822.654] (II) Module ABI versions:
[ 2822.654] X.Org ANSI C Emulation: 0.4
[ 2822.654] X.Org Video Driver: 25.2
[ 2822.654] X.Org XInput driver : 24.4
[ 2822.654] X.Org Server Extension : 10.0
[ 2822.655] (++) using VT number 4
[ 2822.659] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 2822.661] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 2822.661] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/drm/card1
[ 2822.663] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 2822.664] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2822.664] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:03:00.0/drm/card0
[ 2822.666] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 2822.674] (--) PCI:*(0@0:1:0) 1002:9874:17aa:3802 rev 197, Mem @ 0xe0000000/268435456, 0xf0000000/8388608, 0xf1100000/262144, I/O @ 0x00003000/256, BIOS @ 0x????????/131072
[ 2822.674] (--) PCI: (3@0:0:0) 1002:6660:17aa:3805 rev 131, Mem @ 0xd0000000/268435456, 0xf0f00000/262144, I/O @ 0x00001000/256, BIOS @ 0x????????/131072
[ 2822.674] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2822.674] (II) LoadModule: "glx"
[ 2822.674] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2822.678] (II) Module glx: vendor="X.Org Foundation"
[ 2822.678] compiled for 1.21.1.4, module version = 1.0.0
[ 2822.678] ABI class: X.Org Server Extension, version 10.0
[ 2822.678] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[ 2822.678] loading driver: amdgpu
[ 2822.678] (II) Applying OutputClass "Radeon" to /dev/dri/card0
[ 2822.678] loading driver: radeon
[ 2822.678] (==) Matched amdgpu as autoconfigured driver 0
[ 2822.678] (==) Matched ati as autoconfigured driver 1
[ 2822.678] (==) Matched radeon as autoconfigured driver 2
[ 2822.678] (==) Matched modesetting as autoconfigured driver 3
[ 2822.678] (==) Matched fbdev as autoconfigured driver 4
[ 2822.678] (==) Matched vesa as autoconfigured driver 5
[ 2822.678] (==) Assigned the driver to the xf86ConfigLayout
[ 2822.678] (II) LoadModule: "amdgpu"
[ 2822.678] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 2822.680] (II) Module amdgpu: vendor="X.Org Foundation"
[ 2822.680] compiled for 1.21.1.3, module version = 22.0.0
[ 2822.680] Module class: X.Org Video Driver
[ 2822.680] ABI class: X.Org Video Driver, version 25.2
[ 2822.680] (II) LoadModule: "ati"
[ 2822.680] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 2822.680] (II) Module ati: vendor="X.Org Foundation"
[ 2822.680] compiled for 1.21.1.4, module version = 19.1.0
[ 2822.682] (II) LoadModule: "radeon"
[ 2822.682] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 2822.683] (II) Module radeon: vendor="X.Org Foundation"
[ 2822.683] compiled for 1.21.1.4, module version = 19.1.0
[ 2822.683] Module class: X.Org Video Driver
[ 2822.683] ABI class: X.Org Video Driver, version 25.2
[ 2822.683] (II) LoadModule: "modesetting"
[ 2822.683] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 2822.683] (II) Module modesetting: vendor="X.Org Foundation"
[ 2822.683] compiled for 1.21.1.4, module version = 1.21.1
[ 2822.683] (II) LoadModule: "fbdev"
[ 2822.684] (WW) Warning, couldn't open module fbdev
[ 2822.684] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 2822.684] (II) LoadModule: "vesa"
[ 2822.684] (WW) Warning, couldn't open module vesa
[ 2822.684] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 2822.684] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 2822.684] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 2822.689] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2822.690] (WW) Falling back to old probe method for modesetting
[ 2822.690] (EE) AMDGPU(G0): amdgpu_device_initialize failed
[ 2822.690] (II) [KMS] Kernel modesetting enabled.
[ 2822.690] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 2822.690] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 2822.690] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 2822.690] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 2822.690] (==) AMDGPU(0): Default visual is TrueColor
[ 2822.690] (==) AMDGPU(0): RGB weight 888
[ 2822.690] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 2822.690] (--) AMDGPU(0): Chipset: "AMD Radeon R6 Graphics" (ChipID = 0x9874)
[ 2822.690] (II) Loading sub module "fb"
[ 2822.690] (II) LoadModule: "fb"
[ 2822.690] (II) Module "fb" already built-in
[ 2822.691] (II) Loading sub module "dri2"
[ 2822.691] (II) LoadModule: "dri2"
[ 2822.691] (II) Module "dri2" already built-in
[ 2822.786] (II) Loading sub module "glamoregl"
[ 2822.786] (II) LoadModule: "glamoregl"
[ 2822.786] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 2822.798] (II) Module glamoregl: vendor="X.Org Foundation"
[ 2822.798] compiled for 1.21.1.4, module version = 1.0.1
[ 2822.798] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2822.827] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon R6 Graphics (carrizo, LLVM 14.0.6, DRM 3.42, 5.15.72-1-MANJARO)
[ 2822.827] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 2822.827] (==) AMDGPU(0): TearFree property default: auto
[ 2822.827] (==) AMDGPU(0): VariableRefresh: disabled
[ 2822.827] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[ 2822.827] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 2822.827] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 2822.828] (II) AMDGPU(0): Output eDP has no monitor section
[ 2822.840] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 2822.841] (II) AMDGPU(0): EDID for output eDP
[ 2822.841] (II) AMDGPU(0): Manufacturer: LGD Model: 45f Serial#: 0
[ 2822.841] (II) AMDGPU(0): Year: 2013 Week: 0
[ 2822.841] (II) AMDGPU(0): EDID Version: 1.4
[ 2822.841] (II) AMDGPU(0): Digital Display Input
[ 2822.841] (II) AMDGPU(0): 6 bits per channel
[ 2822.841] (II) AMDGPU(0): Digital interface is DisplayPort
[ 2822.841] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 2822.841] (II) AMDGPU(0): Gamma: 2.20
[ 2822.841] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[ 2822.841] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 2822.841] (II) AMDGPU(0): First detailed timing is preferred mode
[ 2822.841] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 2822.841] (II) AMDGPU(0): redX: 0.579 redY: 0.344 greenX: 0.338 greenY: 0.569
[ 2822.841] (II) AMDGPU(0): blueX: 0.158 blueY: 0.124 whiteX: 0.313 whiteY: 0.329
[ 2822.841] (II) AMDGPU(0): Manufacturer's mask: 0
[ 2822.841] (II) AMDGPU(0): Supported detailed timing:
[ 2822.841] (II) AMDGPU(0): clock: 76.3 MHz Image Size: 310 x 174 mm
[ 2822.841] (II) AMDGPU(0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1610 h_border: 0
[ 2822.841] (II) AMDGPU(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 790 v_border: 0
[ 2822.841] (II) AMDGPU(0): LG Display
[ 2822.841] (II) AMDGPU(0): LP140WHU-TPBJ
[ 2822.841] (II) AMDGPU(0): EDID (in hex):
[ 2822.841] (II) AMDGPU(0): 00ffffffffffff0030e45f0400000000
[ 2822.841] (II) AMDGPU(0): 00170104951f1178ea4bb59458569128
[ 2822.841] (II) AMDGPU(0): 1f505400000001010101010101010101
[ 2822.842] (II) AMDGPU(0): 010101010101ce1d56f4500016303020
[ 2822.842] (II) AMDGPU(0): 350036ae100000190000000000000000
[ 2822.842] (II) AMDGPU(0): 00000000000000000000000000fe004c
[ 2822.842] (II) AMDGPU(0): 4720446973706c61790a2020000000fe
[ 2822.842] (II) AMDGPU(0): 004c503134305748552d5450424a00d0
[ 2822.842] (II) AMDGPU(0): Printing probed modes for output eDP
[ 2822.842] (II) AMDGPU(0): Modeline "1366x768"x60.0 76.30 1366 1414 1446 1610 768 771 776 790 -hsync -vsync (47.4 kHz eP)
[ 2822.842] (II) AMDGPU(0): Modeline "1280x720"x60.0 76.30 1280 1414 1446 1610 720 771 776 790 -hsync -vsync (47.4 kHz e)
[ 2822.842] (II) AMDGPU(0): Modeline "1024x768"x60.0 76.30 1024 1414 1446 1610 768 771 776 790 -hsync -vsync (47.4 kHz e)
[ 2822.842] (II) AMDGPU(0): Modeline "800x600"x60.0 76.30 800 1414 1446 1610 600 771 776 790 -hsync -vsync (47.4 kHz e)
[ 2822.842] (II) AMDGPU(0): Modeline "640x480"x60.0 76.30 640 1414 1446 1610 480 771 776 790 -hsync -vsync (47.4 kHz e)
[ 2822.842] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 2822.842] (II) AMDGPU(0): Output eDP connected
[ 2822.842] (II) AMDGPU(0): Using exact sizes for initial modes
[ 2822.842] (II) AMDGPU(0): Output eDP using initial mode 1366x768 +0+0
[ 2822.842] (II) AMDGPU(0): mem size init: gart size :bfc2d000 vram size: s:1edfc000 visible:1edfc000
[ 2822.842] (==) AMDGPU(0): DPI set to (96, 96)
[ 2822.842] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2822.842] (II) Loading sub module "ramdac"
[ 2822.842] (II) LoadModule: "ramdac"
[ 2822.842] (II) Module "ramdac" already built-in
[ 2822.842] (==) RADEON(G1): Depth 24, (--) framebuffer bpp 32
[ 2822.842] (II) RADEON(G1): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 2822.842] (==) RADEON(G1): Default visual is TrueColor
[ 2822.842] (==) RADEON(G1): RGB weight 888
[ 2822.842] (II) RADEON(G1): Using 8 bits per RGB (8 bit DAC)
[ 2822.842] (--) RADEON(G1): Chipset: "HAINAN" (ChipID = 0x6660)
[ 2822.842] (II) Loading sub module "fb"
[ 2822.842] (II) LoadModule: "fb"
[ 2822.842] (II) Module "fb" already built-in
[ 2822.842] (II) Loading sub module "dri2"
[ 2822.843] (II) LoadModule: "dri2"
[ 2822.843] (II) Module "dri2" already built-in
[ 2822.856] (II) Loading sub module "glamoregl"
[ 2822.856] (II) LoadModule: "glamoregl"
[ 2822.856] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 2822.857] (II) Module glamoregl: vendor="X.Org Foundation"
[ 2822.857] compiled for 1.21.1.4, module version = 1.0.1
[ 2822.857] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2822.874] (II) RADEON(G1): glamor X acceleration enabled on AMD HAINAN (LLVM 14.0.6, DRM 2.50, 5.15.72-1-MANJARO)
[ 2822.874] (II) RADEON(G1): glamor detected, initialising EGL layer.
[ 2822.874] (II) RADEON(G1): KMS Color Tiling: enabled
[ 2822.875] (II) RADEON(G1): KMS Color Tiling 2D: enabled
[ 2822.875] (==) RADEON(G1): TearFree property default: auto
[ 2822.875] (II) RADEON(G1): mem size init: gart size :7fbcf000 vram size: s:80000000 visible:fbbe000
[ 2822.875] (==) RADEON(G1): DPI set to (96, 96)
[ 2822.875] (==) RADEON(G1): Using gamma correction (1.0, 1.0, 1.0)
[ 2822.875] (II) Loading sub module "ramdac"
[ 2822.875] (II) LoadModule: "ramdac"
[ 2822.875] (II) Module "ramdac" already built-in
[ 2822.875] (II) UnloadModule: "amdgpu"
[ 2822.875] (II) UnloadModule: "modesetting"
[ 2822.875] (II) Unloading modesetting
[ 2822.875] (II) AMDGPU(0): [DRI2] Setup complete
[ 2822.875] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 2822.875] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 2822.876] (II) AMDGPU(0): Front buffer pitch: 5504 bytes
[ 2822.876] (II) AMDGPU(0): SYNC extension fences enabled
[ 2822.876] (II) AMDGPU(0): Present extension enabled
[ 2822.876] (==) AMDGPU(0): DRI3 enabled
[ 2822.876] (==) AMDGPU(0): Backing store enabled
[ 2822.876] (II) AMDGPU(0): Direct rendering enabled
[ 2823.265] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 2823.265] (II) AMDGPU(0): Acceleration enabled
[ 2823.265] (==) AMDGPU(0): DPMS enabled
[ 2823.265] (==) AMDGPU(0): Silken mouse enabled
[ 2823.265] (II) AMDGPU(0): Set up textured video (glamor)
[ 2823.274] (II) RADEON(G0): [DRI2] Setup complete
[ 2823.274] (II) RADEON(G0): [DRI2] DRI driver: radeonsi
[ 2823.274] (II) RADEON(G0): [DRI2] VDPAU driver: radeonsi
[ 2823.275] (II) RADEON(G0): Front buffer size: 3072K
[ 2823.275] (II) RADEON(G0): VRAM usage limit set to 229240K
[ 2823.275] (==) RADEON(G0): Backing store enabled
[ 2823.275] (II) RADEON(G0): Direct rendering enabled
[ 2823.662] (II) RADEON(G0): Use GLAMOR acceleration.
[ 2823.662] (II) RADEON(G0): Acceleration enabled
[ 2823.662] (==) RADEON(G0): DPMS enabled
[ 2823.662] (==) RADEON(G0): Silken mouse enabled
[ 2823.662] (II) Initializing extension Generic Event Extension
[ 2823.663] (II) Initializing extension SHAPE
[ 2823.663] (II) Initializing extension MIT-SHM
[ 2823.663] (II) Initializing extension XInputExtension
[ 2823.664] (II) Initializing extension XTEST
[ 2823.664] (II) Initializing extension BIG-REQUESTS
[ 2823.664] (II) Initializing extension SYNC
[ 2823.665] (II) Initializing extension XKEYBOARD
[ 2823.665] (II) Initializing extension XC-MISC
[ 2823.665] (II) Initializing extension SECURITY
[ 2823.666] (II) Initializing extension XFIXES
[ 2823.666] (II) Initializing extension RENDER
[ 2823.666] (II) Initializing extension RANDR
[ 2823.667] (II) Initializing extension COMPOSITE
[ 2823.667] (II) Initializing extension DAMAGE
[ 2823.667] (II) Initializing extension MIT-SCREEN-SAVER
[ 2823.668] (II) Initializing extension DOUBLE-BUFFER
[ 2823.668] (II) Initializing extension RECORD
[ 2823.668] (II) Initializing extension DPMS
[ 2823.669] (II) Initializing extension Present
[ 2823.669] (II) Initializing extension DRI3
[ 2823.669] (II) Initializing extension X-Resource
[ 2823.670] (II) Initializing extension XVideo
[ 2823.670] (II) Initializing extension XVideo-MotionCompensation
[ 2823.670] (II) Initializing extension GLX
[ 2823.691] (II) AIGLX: Loaded and initialized radeonsi
[ 2823.691] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 2823.691] (II) Initializing extension XFree86-VidModeExtension
[ 2823.692] (II) Initializing extension XFree86-DGA
[ 2823.692] (II) Initializing extension XFree86-DRI
[ 2823.692] (II) Initializing extension DRI2
[ 2823.694] (II) AMDGPU(0): Setting screen physical size to 361 x 203
[ 2823.874] (EE) XKB: Rules returned no components
[ 2823.874] (EE) XKB: Failed to load keymap. Loading default keymap instead.
[ 2823.874] XKB: Failed to compile keymap
[ 2823.874] Keyboard initialization failed. This could be a missing or incorrect setup of xkeyboard-config.
[ 2823.874] (EE)
Fatal server error:
[ 2823.874] (EE) Failed to activate virtual core keyboard: 2(EE)
[ 2823.874] (EE)
for help.
[ 2823.874] (EE) Please also check the log file at "/home/qwq/.local/share/xorg/Xorg.0.log" for additional information.
[ 2823.874] (EE)
[ 2823.874] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 2823.913] (EE) Server terminated with error (1). Closing log file.
you have this:
could be because your root is full … run this command:
sudo pacman -Scc
it will clear cache, then type again startx
xserver is the same as the last pic I post. Failed to activate virtual core keyboard.
take a pic from this:
mhwd-kernel -li && mhwd -l && mhwd -li
so first remove this kernel, its end of life:
sudo mhwd-kernel -r linux414
then rerun update:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
if no errors, uninstall video drivers:
sudo mhwd -r pci video-linux
reinstall kernels + install the 515 kernel:
sudo pacman -S linux54 linux510 linux515
sudo mhwd -a pci free 0300
reboot
