so you didnt uninstall these drivers ?
so now you are using the linux515?
as i see there is some drivers detected, is wifi working?
i did uninstall those drivers,
and no the wifi is not working
i followed the steps u mentioned
in fact the device is notgetting detected now, it used to be detected before
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp5s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 78:45:c4:b3:f8:67 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.39/24 brd 192.168.1.255 scope global dynamic noprefixroute enp5s0
valid_lft 42697sec preferred_lft 42697sec
inet6 fe80::7bd7:703f:670c:d4f2/64 scope link noprefixroute
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:e7:06:8c:52 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
lets try dkms version, since you have already installed headers:
pamac install broadcom-wl-dkms
reboot and test
when i reboot, i pick linux 515 right?
if you alredy booted with the 5.15 it will remember it and boot with it automatically, so just press enter in grub menu if you dont want to wait those 5 seconds
the command pamac install broadcom-wl-dkms
gave the following error
==> ERROR: Missing 5.15.71-1-rt51-MANJARO kernel modules tree for module broadcom-wl/6.30.223.271.
Transaction successfully finished
but somethings did get installed i think
Apply transaction ? [y/N] y
Download of broadcom-wl-dkms (6.30.223.271-33) started
Download of broadcom-wl-dkms (6.30.223.271-33) finished
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing broadcom-wl-dkms (6.30.223.271-33)... [1/1]
Unload and load kernel modules (wl is provided by broadcom-wl-dkms):
rmmod b43 b43legacy bcm43xx bcma brcm80211 brcmfmac brcmsmac ssb tg3 wl
modprobe wl
Arming ConditionNeedsUpdate... [1/2]
Install DKMS modules [2/2]
==> dkms install --no-depmod broadcom-wl/6.30.223.271 -k 5.4.217-1-MANJARO
==> dkms install --no-depmod broadcom-wl/6.30.223.271 -k 5.10.147-1-MANJARO
==> dkms install --no-depmod broadcom-wl/6.30.223.271 -k 5.15.72-1-MANJARO
==> depmod 5.10.147-1-MANJARO
==> depmod 5.15.72-1-MANJARO
==> depmod 5.4.217-1-MANJARO
wait it wants the 515 rt kernel… and you dont have it installed… just reboot and see
i rebooted, its detecting the router, but i dont have any option for the SSID.
when i do ip a
its still in state DORMANT
when you click on the wifi tray icon are there any networks being detected?
nop, the icon has an X on it.
broadcom-wl-dkms
tries to compile for each kernel installed, its okay if you haven’t installed the kernel headers for a kernel you’re not using.
To install kernel headers (for example, replace with the actual kernel you want to use): pamac install linux519-headers
After it installs, you may need this to get it active:
sudo dkms install broadcom-wl/6.30.223.271 -k 5.15.72-1-MANJARO
sudo modprobe wl
Edit - I muddied the sequence, should be
alternatively install 515-broadcom-wl instead of 1-4 above
try what mishmosh suggest with:
and also provide output from:
ls /etc/mkinitcpio.d/*.preset
sudo ls /boot/initramfs-*
sudo ls /boot/vmlinuz-*
sudo ls /usr/lib/modules/*
tried what mishmosh suggested, rebooted, nothin changed
and here is the output of the commands
1st command
[djamel@djamel ~]$ ls /etc/mkinitcpio.d/*.preset
/etc/mkinitcpio.d/linux510.preset /etc/mkinitcpio.d/linux54.preset
/etc/mkinitcpio.d/linux515.preset
2nd command
[djamel@djamel ~]$ sudo ls /boot/initramfs-*
/boot/initramfs-5.10-x86_64-fallback.img
/boot/initramfs-5.10-x86_64.img
/boot/initramfs-5.15-x86_64-fallback.img
/boot/initramfs-5.15-x86_64.img
/boot/initramfs-5.4-x86_64-fallback.img
/boot/initramfs-5.4-x86_64.img
3rd
[djamel@djamel ~]$ sudo ls /boot/vmlinuz-*
/boot/vmlinuz-5.10-x86_64 /boot/vmlinuz-5.15-x86_64 /boot/vmlinuz-5.4-x86_64
4th
[djamel@djamel ~]$ sudo ls /usr/lib/modules/*
/usr/lib/modules/5.10.147-1-MANJARO:
build modules.alias.bin modules.dep modules.symbols
extramodules modules.builtin modules.dep.bin modules.symbols.bin
kernel modules.builtin.alias.bin modules.devname pkgbase
kernelbase modules.builtin.bin modules.order updates
modules.alias modules.builtin.modinfo modules.softdep vmlinuz
/usr/lib/modules/5.15.71-1-rt51-MANJARO:
build
/usr/lib/modules/5.15.72-1-MANJARO:
/usr/lib/modules/5.4.217-1-MANJARO:
/usr/lib/modules/extramodules-5.10-MANJARO:
version
/usr/lib/modules/extramodules-5.15-MANJARO:
version
/usr/lib/modules/extramodules-5.4-MANJARO:
version
last
here is a leftover from the 5.15 rt kernel, navigate there and remove it…
and post again output from:
inxi -N
[djamel@djamel modules]$ ls
5.10.147-1-MANJARO 5.4.217-1-MANJARO extramodules-5.4-MANJARO
5.15.71-1-rt51-MANJARO extramodules-5.10-MANJARO
5.15.72-1-MANJARO extramodules-5.15-MANJARO
there are 5.15.71.1-rt51… and 5.515.72.1
do i remove both the normal and the rt?
only the rt one!!! its a leftover …
removed it, here is the output on the inxi command
[djamel@djamel modules]$ inxi -N
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
Device-2: Broadcom BCM43142 802.11b/g/n driver: wl
maybe i should reboot?
LOL and I’ve lost track which kernel you’re now running …
uname -r
If you’re in 5.15, try the modprobe again since the reboot …
sudo modprobe wl
[djamel@djamel modules]$ uname -r
5.15.72-1-MANJARO
``` im running 5.15
