Hi, im trying to enable wifi on my manjaro, however my manjaro isn’t detecting any modem.
i did a bit of googling and found a similar post, i followed the first set which said to execute the command inxi -Nazy
which outputed the following
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 05:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Dell Wireless 1704 802.11n
+ BT 4.0 driver: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 09:00.0 chip-ID: 14e4:4365 class-ID: 0280
i stopped at the next step where it said to go to the following link https://linux-hardware.org/?view=search
and search for the chipID, specifically i couldn’t take the data outputed by the command above and find the vendorID/sub-vendorID deviceID/sub-deviceID , Bus and classID
here is a system info of my machine:
Kernel: 5.10.136-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=f6bd273e-5071-4f0e-a7ad-fc558deb8c12 rw quiet apparmor=1
security=apparmor resume=UUID=174856d2-8055-40d0-8363-e60d1e168dce
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron N4050 v: N/A serial: <filter>
Chassis: type: 8 serial: <filter>
Mobo: Dell model: 0GGRV5 v: A07 serial: <filter> BIOS: Dell v: A07
date: 03/23/2012
RAM: total: 3.75 GiB used: 2.26 GiB (60.4%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
note: est.
Device-1: DIMM_A type: no module installed
Device-2: DIMM_B type: DDR3 detail: synchronous size: 4 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: SK-Hynix part-no: HMT351S6CFR8C-H9 serial: <filter>
Info: model: Intel Core i3-2370M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1013 high: 1277 min/max: 800/2400 base/boost: 2400/2400
scaling: driver: intel_cpufreq governor: schedutil volts: 1.1 V
ext-clock: 100 MHz cores: 1: 891 2: 1277 3: 1086 4: 798 bogomips: 19167
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] vendor: Dell
driver: radeon v: kernel arch: TeraScale-2 code: Evergreen
process: TSMC 32-40nm built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 1002:6760 class-ID: 0300
Device-3: Microdia Laptop_Integrated_Webcam_1.3M type: USB
driver: uvcvideo bus-ID: 1-1.5:3 chip-ID: 0c45:643e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,radeon alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x02e9 built: 2010 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 22.1.6
direct render: Yes
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.136-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 698.64 GiB used: 107.62 GiB (15.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD075
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1C scheme: MBR
ID-1: / raw-size: 690.28 GiB size: 678.37 GiB (98.28%) used: 106.08 GiB
(15.6%) fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f6bd273e-5071-4f0e-a7ad-fc558deb8c12
ID-1: swap-1 type: partition size: 8.36 GiB used: 1.54 GiB (18.4%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 174856d2-8055-40d0-8363-e60d1e168dce
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:5 info: SiGma Micro USB Keyboard type: Keyboard
power: 480mA chip-ID: 1c4f:0084 class-ID: 0301
Device-2: 1-1.2:4 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 10c4:8108 class-ID: 0301
Device-3: 1-1.5:3 info: Microdia Laptop_Integrated_Webcam_1.3M type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: Realtek RTS5138 Card Reader Controller
type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0bda:0138 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 53.0 C mobo: N/A gpu: radeon temp: 46.0 C
Fan Speeds (RPM): cpu: 2957
Processes: 257 Uptime: 34m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1456 pm: pacman pkgs: 1435 libs: 366 tools: pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 21 Shell: Bash (sudo) v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.21
