nkv
27 October 2022 23:44
1
Hi,
I need help to get my WiFi working in Manjaro
uname -a 1 ✘
Linux WFH 5.15.74-3-MANJARO #1 SMP PREEMPT Sat Oct 15 13:39:11 UTC 2022 x86_64 GNU/Linux
lsmod | grep iwlwifi ✔
iwlwifi 454656 0
cfg80211 1081344 1 iwlwifi
lspci -k | grep -i netw ✔
00:14.3 Network controller: Intel Corporation Alder Lake-P PCH CNVi WiFi (rev 01)
Subsystem: Rivet Networks Device 1692
sudo dmesg | grep iwlwifi ✔
[ 4.191618] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 4.193256] iwlwifi: No config found for PCI dev 51f0/1692, rev=0x370, rfid=0x3010d000
[ 4.193265] iwlwifi: probe of 0000:00:14.3 failed with error -22
inxi -Fazy
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: N/A modules: iwlwifi bus-ID: 00:14.3 chip-ID: 8086:51f0
class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
IF-ID-1: enp0s13f0u3u1i5 state: up speed: 100 Mbps duplex: half
mac: <filter>
rfkill list 1 ✘
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
I serached google a lot and tried installing linux-firmware, trying various kernels and other tricks; but nothing worked.
Any help will be appreciated.
Thanks
brahma
28 October 2022 05:51
2
is fast boot (or something similar) disabled in bios - you may not have this option;
is fast startup disabled in windows;
and check a keyboard shortcut/or hardware switch for the wifi
nkv
28 October 2022 11:34
3
fastboot wa enabled in both BIOS and windows.
Disabling it in both of those did not make any difference.
brahma
28 October 2022 12:51
4
and this:
run this:
sudo modprobe iwlwifi
and see if it helped
nkv
30 October 2022 11:47
5
nothing hzppens or displayed
~/Desktop sudo modprobe iwlwifi
~/Desktop
Any idea what following error means and how to resolve this:
~/Desktop sudo dmesg | grep iwlwifi ✔
[ 4.029591] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 4.031401] iwlwifi: No config found for PCI dev 51f0/1692, rev=0x370, rfid=0x3010d000
[ 4.031413] iwlwifi: probe of 0000:00:14.3 failed with error -22
Olli
30 October 2022 12:12
7
please open the package-manager, enable downloads from aur and install the package “iwlwifi-next”. it should contain the necessary files.
reboot and check.
nkv
30 October 2022 21:07
8
jrichard326:
sudo modprobe wl
~/Desktop sudo modprobe wl 1 ✘ 4m 54s
modprobe: FATAL: Module wl not found in directory /lib/modules/5.15.74-3-MANJARO
nkv
30 October 2022 21:11
9
Build failed while installing iwlwifi-next
/home/nkv/.cache/yay/iwlwifi-next/src/iwlwifi-next/drivers/net/wireless/intel/iwlwifi/mvm/tx.c:1968:70: error: ‘struct ieee80211_bss_conf’ has no member named ‘chanctx_conf’
1968 | rcu_dereference(mvmsta->vif->bss_conf.chanctx_conf);
./include/linux/rcupdate.h:392:19: note: in definition of macro ‘__rcu_dereference_check’
392 | ((typeof(*p) __force __kernel *)(________p1)); \
./include/linux/rcupdate.h:596:28: note: in expansion of macro ‘rcu_dereference_check’
596 | #define rcu_dereference(p) rcu_dereference_check(p, 0)
/home/nkv/.cache/yay/iwlwifi-next/src/iwlwifi-next/drivers/net/wireless/intel/iwlwifi/mvm/tx.c:1968:33: note: in expansion of macro ‘rcu_dereference’
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:289: /home/nkv/.cache/yay/iwlwifi-next/src/iwlwifi-next/drivers/net/wireless/intel/iwlwifi/mvm/tx.o] Error 1
make[2]: *** [scripts/Makefile.build:289: /home/nkv/.cache/yay/iwlwifi-next/src/iwlwifi-next/drivers/net/wireless/intel/iwlwifi/mvm/rxmq.o] Error 1
make[1]: *** [scripts/Makefile.build:552: /home/nkv/.cache/yay/iwlwifi-next/src/iwlwifi-next/drivers/net/wireless/intel/iwlwifi/mvm] Error 2
make: *** [Makefile:1898: /home/nkv/.cache/yay/iwlwifi-next/src/iwlwifi-next/drivers/net/wireless/intel/iwlwifi] Error 2
make: Leaving directory '/usr/lib/modules/5.15.74-3-MANJARO/build'
==> ERROR: A failure occurred in build().
Aborting...
-> error making: iwlwifi-next
brahma
30 October 2022 21:34
10
should result in this:
so did you checked if the wifi is working after running the modprobe command?
and post output from:
inxi -N
after you run the modprobe command
nkv
30 October 2022 22:20
11
No, wifi isn’t working. I think the drivers needs to be installed for Intel Alder Lake-P PCH CNVi WiFi driver - which I am not able to find.
~/Desktop inxi -N 1 ✘
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: N/A
Device-2: Realtek RTL8125 2.5GbE driver: r8169
brahma
30 October 2022 22:24
12
switch to the 6.0 kernel - not the rc one - and check again with:
inxi -N
the drivers for your wifi are in kernel: iwlwifi, and they are being loaded, but there is something with the hardware, probably related to windows/bios
nkv
30 October 2022 23:16
13
Thanks, I checked BIOS and windows. I cannot see anything that might be interfering with wifi. Wifi works fine in Windows.
I tried kernel 6.0.2-2, but that does not even load, get stuck with a blinking cursor.
Checked with Linux Mint live boot usb, the same problem there as well. No WiFi
if mod-probe failed, which could mean the lack of support in kernel 5.15. a google search did find this result;
Hello, I have purchased a modern laptop, MSI Stealth GS66 12UGS, with which I am having trouble setting up wireless connection. Please consider the following setup information and dmesg log attached. - Arch linux - Linux hardware probe:...
it seems fixed with kernel 5.17. since 5.17 is EOL now, recommend you using atleast 5.19 (since 6.0.x is not working for you)
brahma
31 October 2022 09:08
15
do you have nvidia?
go to windows and disable hibernate and fast startup, and disable the wifi from device manager, shut down your pc - dont reboot, and check again the wifi in manjaro…
nkv
25 November 2022 13:41
16
Yes, I have nvidia.
Funny thing is that wifi works good when I install Manjaro on a USB and boot from it. But, wifi does not work when I install Manjaro on SSD diskdrive and boot from there!
Kernel 5.19 works and no other kernel gets the wifi working at all
