Hi, I recently did a fresh redump on my laptop (deleted every partitions with gparted, and then reinstalled windows and manjaro in a dual boot configuration).
My windows seems to works well but I can’t boot my manjaro. When I just boot my computer it boots on windows, and when I go to the boot menu, I can see the manjaro entry but I can’t boot on it (choosing it does absolutely nothing, where it should boot to manjaro).
Here’s a few additional informations:
- I used rufus to create all my bootable keys (Gparted, Windows 10 and Manjaro)
- I use manjaro gnome
- This laptop already had the same configuration (dual boot windows 10 + manjaro gnome) before I cleaned it with gparted.
- I followed this guide https://forum.manjaro.org/t/root-tip-how-to-dual-boot-manjaro-and-windows/1164
And here’s the output of parted + print list all
Model: SAMSUNG MZVLB256HAHQ-000L7 (nvme)
Disk /dev/nvme0n1: 256GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name                          Flags
 1      1049kB  106MB   105MB   fat32           EFI system partition          boot, esp
 2      106MB   123MB   16.8MB                  Microsoft reserved partition  msftres
 3      123MB   78.1GB  78.0GB  ntfs            Basic data partition          msftdata
 4      78.1GB  78.6GB  556MB   ntfs                                          hidden, diag
 5      78.6GB  79.2GB  537MB   fat32                                         boot, esp
 6      79.2GB  81.3GB  2147MB  linux-swap(v1)                                swap
 7      81.3GB  103GB   21.5GB  ext4
 8      103GB   256GB   153GB   ext4
Maybe the manjaro entry in my boot refers to my old manjaro ? because it was already here before I reinstalled manjaro, but that feels weird.
Thanks a lot for you time !
