dede
2 December 2024 09:18
1
Hi,
I have a problem with gnome 47 accent colors : I love manjaro Maia accent color but it’s not applying everywhere. Sometime the Green color is used instead. For example :
If I choose another color in gnome accent colors, it’s applied everywhere, except in the quick settings menu.
Is there a bug, or am I missing something?
thanks,
Denis
See this post in the 2024-11-25 Testing Update thread which may be related:
For GNOME users, one can now match the system accent color with Gtk3 applications with adw-gtk-theme >= 5.5-2.
I’ve now added accent-color-change to the repos. It’s a script to change the accent color for Gtk3 and Gtk4 applications that do not use Libadwaita created by the author of adw-gtk3 (adw-gtk-theme in the repos).
EDIT : Updated with new script.
If I’m reading it correctly, installing/using accent-color-change might produce favourable results.
sudo pacman -S accent-color-change
Hi @dede and welcome to the Manjaro community.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
dede
2 December 2024 11:22
3
Thanks for your help, accent-color-change script does improve things a lot.
There is some places where green colors remains, though :
For example, after running the script:
You could try adjusting the global accent color, in case that helps.
In KDE that can be changed via:
System Settings :
Colours & Themes → Global Theme → Colours
And a dropdown then allows these choices:
Accent colour from colour scheme
Accent colour from wallpaper
Custom accent colour
I’m uncertain what the equivalent is in Gnome, or whether changing anything will affect the green pictures.
It’s a known issue. I have not figured out how to solve that yet.
…is only is applicable to Gtk3 and Gtk4 applications when using adw-gtk-theme and applying Adw-gtk3 / Adw-gtk3-dark for legacy applications.
