I am pulling my hair out trying to stop my laptop screen from blanking after 5 minutes of inactivity. I read one post saying that it was solved but do not know HOW they actually solved it. I remember one page that mentions “Call xfce4-screensaver-preferences and disable the screensaver” , somehow, but I do not know how to do that:
I tried to execute a call suggested in the above forum link but no joy:
$ xfce4-screensaver-preferences
bash: xfce4-screensaver-preferences: command not found
$ sudo xfce4-screensaver-preferences
[sudo] password for user:
sudo: xfce4-screensaver-preferences: command not found
Just to be sure, I ran the following:
$ xfce4-about -V
xfce4-about 4.20.2 (Xfce 4.20)
Copyright (c) 2008-2025
The Xfce development team. All rights reserved.
There is no dedicated “security” tab anymore. Lock screen management was massively simplified and “Light Locker” was dropped. “lock-on-sleep” is now synchronized with xfce4-session and xfce4-screensaver.
Screen locking settings are now only handled by xfce4-screensaver to avoid conflicts
But Manjaro updates did not automatically install xfce4-screensaver and remove light-locker, and users reported similar issues with screen blanking after 5 minutes, that were usually resolved by installing xfce4-screensaver manually
I set the idel timeout to 1 minute but it did not seems to work. I will reboot and try it again. I’m sure it will work then. Or do I also have to uninstall the light-locker dealie-bob?
THANKS!!!
OK! The reboot fixed it! The screen will blank after 60 seconds! Now I will set it to my preferences! Whew! That is a monkey off my back!! Thanks again you guys!!
Keyboard is unresponsive after resuming from suspend by pressing the power button. PTL, I was able to open Mousepad and the keyboard worked there. Then I went back to Firefox and keyboard worked again as you can see.
I removed light-locker and set screensaver to 1 minute and suspend to 3 minutes. Screensaver worked perfectly but suspend failed. After more than three minutes, I pressed the shift key and was greeted with my usual screen where I left off and a dialog:
Mod edit:- Please avoid posting images when a text description will suffice. Save the Server.
So I clicked on “No”. Maybe I need to look into the settings for xfce4 power manager and xfce4-screensaver…
The Security section suggests screen locking…
I enabled the “Lock Screen with Screensaver” and set it to one minute after screensaver activation and see what happens. Everything else is unchanged. Let’s see what this does.
OK screensaver blanked right on the money at 60 seconds
Lock Screen worked after two minutes and presented a login prompt that was different in appearance than the boot up lock prompt.
I still got the error dialog about not being able to suspend due to lock failure
Now I will try turning off the “lock screen when system is going to sleep” in the Security section of the xfce4 Power Manager.
BINGO! That did the trick!! I also now, finally, have a wake from suspend prompt thta does not require me to press the shift key a bunch of times to make the screen come back on so I can see the login prompt and log back in!!!
