Manjaro KDE won't boot /dev/sdb1: clean,... files,... blocks
So when I choose Manjaro from a bootloader, I get stuck on this below given screen. No matter how long I wait (1,5h) - nothing changes.
A guy told me to delete nvidia drivers using mhwd -r pci video-nvidia but it only made the resolution of this screen higher
I had this issue. If you have only on screen, you can circumvent the screen by pressing Ctrl+Alt+F2 to send you to another terminal. There you can update your system or do something else. I received this bug and running sudo pacman -Syu on a second terminal kinda fixed it.
Though, right now (a day later) I have a bug where my laptop screen shows your screenshot while only my external monitor works.
Edit: This might not work actually. If I disconnect my external monitor, I end up in the same exact situation and updating my system did not work. It might have worked the first time since it was a fresh install and there was a lot to update.
I am getting the same issue, is there any solution for that
I have booted with live USB and updated everything, but no luck
Thanks
Just happened to me too. I can ctrl-alt-f4 to a new shell and I think the nVidia drivers are the cause.
What to do?
Please provide Information:
Started a new topic, thanks.
