Alright, this is driving me crazy. What is actually happening is that after the fresh install of Manjaro KDE Plasme 21.1.1 on my laptop, it was working fine. There was no lag. BUT after few usages, when i press the superkey, the menu shown got big on its own and thats where the problem friggin starts. Whole Manjaro KDE starts to lag. And because of this very problem, i had to keep re-installing the whole OS. But it looks like I ALWAYS end up having this problem.
Please help me guyz. I love this OS but because of this bug Iâm starting to hate it.
My laptop specifications -
Intel i3 3110M @2.40GHz
4 gb ram
Intel hd 4000 graphics
SOLUTION :-
I found out that my Manjaro slowed down all of a sudden and application menu launcher got so big all of a sudden because of installing Incompatible video driver. Although I donât know why is it not compatible. Under hardware drivers in system settings, I uninstalled âvideo-vesaâ driver and rebooted, which fixed my problem.
Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e8f7f137-5dfa-46fa-a1ed-4f8b900fed4d rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20207 v: Lenovo B490 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20207 serial: <filter> UEFI-[Legacy]: LENOVO
v: H5ET73WW(1.16) date: 04/10/2013
ID-1: BAT0 charge: 6.8 Wh (46.3%) condition: 14.7/38.9 Wh (37.8%)
volts: 11.6 min: 10.8 model: SANYO 45N1043 type: Li-ion serial: <filter>
status: Charging
RAM: total: 3.43 GiB used: 1.36 GiB (39.7%)
Info: Dual Core model: Intel Core i3-3110M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 19166
Speed: 1197 MHz min/max: 1200/2400 MHz Core speeds (MHz): 1: 1197 2: 1922
3: 1533 4: 1729
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Acer Lenovo Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:5 chip-ID: 5986:0294 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1368x768 s-dpi: 112 s-size: 310x171mm (12.2x6.7")
s-diag: 354mm (13.9")
Monitor-1: default res: 1368x768
OpenGL: renderer: llvmpipe (LLVM 12.0.1 256 bits) v: 4.5 Mesa 21.2.1
compat-v: 3.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Lenovo driver: wl v: kernel
port: efa0 bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Foxconn BCM43142A0 Bluetooth module type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 105b:e065 class-ID: fe01 serial: <filter>
Local Storage: total: 465.76 GiB used: 8.7 GiB (1.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-9WS142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: LVM1 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT80N rev: LN80
dev-links: cdrom
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%) used: 8.7 GiB (1.9%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: e8f7f137-5dfa-46fa-a1ed-4f8b900fed4d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.3:3
info: Upek Biometric Touchchip/Touchstrip Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.0 speed: 12 Mb/s
power: 100mA chip-ID: 147e:1002 class-ID: 0000
Device-2: 1-1.4:4 info: Foxconn BCM43142A0 Bluetooth module type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 105b:e065
Device-3: 1-1.5:5 info: Acer Lenovo Integrated Webcam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 320mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: Alcor Micro Multi Flash Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 250mA
chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 55.0 C mobo: 40.0 C
Fan Speeds (RPM): cpu: 0
Processes: 197 Uptime: 8m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1237 lib: 357 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
