I also ran this, as su (donβt know if it matters),
systemctl status
β ppapadopoulos
State: degraded
Units: 411 loaded (incl. loaded aliases)
Jobs: 0 queued
Failed: 2 units
Since: Sun 2023-01-08 18:40:46 EET; 26min ago
systemd: 252.4-2-manjaro
CGroup: /
ββinit.scope
β ββ1 /sbin/init
ββsystem.slice
β ββModemManager.service
β β ββ760 /usr/bin/ModemManager
β ββNetworkManager.service
β β ββ737 /usr/bin/NetworkManager --no-daemon
β ββavahi-daemon.service
β β ββ712 "avahi-daemon: running [ppapadopoulos.local]"
β β ββ734 "avahi-daemon: chroot helper"
β ββbluetooth.service
β β ββ846 /usr/lib/bluetooth/bluetoothd
β ββcolord.service
β β ββ833 /usr/lib/colord
β ββcronie.service
β β ββ 713 /usr/bin/crond -n
β β ββ2989 /usr/sbin/anacron -s
β ββcups.service
β β ββ785 /usr/bin/cupsd -l
β ββdbus.service
β β ββ714 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
β ββpolkit.service
β β ββ716 /usr/lib/polkit-1/polkitd --no-debug
β ββrtkit-daemon.service
β β ββ1212 /usr/lib/rtkit-daemon
β ββsddm.service
β β ββ828 /usr/bin/sddm
β β ββ843 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{97bf46df-cbc9-4fdc-acd2-c1b695af5044} -noreset -displayfd 17
β ββsnapd.service
β β ββ717 /usr/lib/snapd/snapd
β ββsystemd-journald.service
β β ββ439 /usr/lib/systemd/systemd-journald
β ββsystemd-logind.service
β β ββ719 /usr/lib/systemd/systemd-logind
β ββsystemd-timesyncd.service
β β ββ703 /usr/lib/systemd/systemd-timesyncd
β ββsystemd-udevd.service
β β ββudev
β β ββ440 /usr/lib/systemd/systemd-udevd
β ββteamviewerd.service
β β ββ935 /opt/teamviewer/tv_bin/teamviewerd -d
β ββudisks2.service
β β ββ894 /usr/lib/udisks2/udisksd
β ββupower.service
β β ββ908 /usr/lib/upowerd
β ββwpa_supplicant.service
β ββ864 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
ββuser.slice
ββuser-1000.slice
ββsession-1.scope
β ββ1069 /usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth71bf8672-6606-4d37-b335-5b792bd0e5d6 --id 1 --start /usr/bin/startplasma-x11 --user ppapadopoulos
β ββ1076 /usr/bin/kwalletd5 --pam-login 6 8
β ββ1077 /usr/bin/startplasma-x11
ββsession-2.scope
ββ1108 "login -- ppapadopoulos"
ββ1110 -bash
ββ1123 /bin/sh /usr/bin/startx
ββ1138 xinit /home/ppapadopoulos/.xinitrc -- /etc/X11/xinit/xserverrc :1 vt2 -keeptty -auth /tmp/serverauth.yJIfyfer8u
ββ1139 /usr/lib/Xorg -nolisten tcp :1 vt2 -keeptty -auth /tmp/serverauth.yJIfyfer8u
ββ1143 startplasma-x11
ββ1149 dbus-launch --sh-syntax --exit-with-session startplasma-x11
ββ1150 /usr/bin/dbus-daemon --syslog --fork --print-pid 4 --print-address 6 --session
ββ1174 /usr/bin/plasma_session
ββ1181 /usr/lib/kf5/start_kdeinit
ββ1182 "kdeinit5: Running..."
ββ1184 /usr/lib/kf5/klauncher --fd=9
ββ1187 /usr/lib/xdg-desktop-portal
ββ1193 /usr/lib/xdg-document-portal
ββ1197 /usr/lib/xdg-permission-store
ββ1203 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
ββ1218 /usr/lib/xdg-desktop-portal-kde
ββ1240 /usr/bin/kded5
ββ1245 /usr/bin/kwin_x11
ββ1263 /usr/bin/kglobalaccel5
ββ1273 /usr/bin/ksmserver
ββ1276 /usr/lib/dconf-service
ββ1301 /usr/bin/xembedsniproxy
ββ1303 /usr/lib/org_kde_powerdevil
ββ1304 /usr/bin/kaccess
ββ1305 /usr/lib/baloo_file
ββ1308 /usr/bin/plasmashell
ββ1310 /usr/lib/polkit-kde-authentication-agent-1
ββ1317 /usr/bin/gmenudbusmenuproxy
β ppapadopoulos
State: degraded
Jobs: 0 queued
Failed: 2 units
CGroup: /
ββinit.scope
β ββ1 /sbin/init
ββsystem.slice
β ββcolord.service
β ββcronie.service
β ββcups.service
β ββdbus.service
β ββpolkit.service
β ββsddm.service
β ββsnapd.service
β β ββudev
β ββudisks2.service
β ββupower.service
it states 2 failed services but I couldnβt find them.
So here are the results,
cat /usr/lib/systemd/user/pipewire-pulse.service ξ² INT β ξ² 5m 58s ο
[Unit]
Description=PipeWire PulseAudio
# We require pipewire-pulse.socket to be active before starting the daemon, because
# while it is possible to use the service without the socket, it is not clear
# why it would be desirable.
# A user installing pipewire and doing `systemctl --user start pipewire-pulse`
# will not get the socket started, which might be confusing and problematic if
# the server is to be restarted later on, as the client autospawn feature
# might kick in. Also, a start of the socket unit will fail, adding to the
# confusion.
# After=pipewire-pulse.socket is not needed, as it is already implicit in the
# socket-service relationship, see systemd.socket(5).
Requires=pipewire-pulse.socket
ConditionUser=!root
Wants=pipewire.service pipewire-session-manager.service
After=pipewire.service pipewire-session-manager.service
Conflicts=pulseaudio.service
[Service]
LockPersonality=yes
MemoryDenyWriteExecute=yes
NoNewPrivileges=yes
RestrictNamespaces=yes
SystemCallArchitectures=native
SystemCallFilter=@system-service
Type=simple
ExecStart=/usr/bin/pipewire-pulse
Restart=on-failure
Slice=session.slice
[Install]
Also=pipewire-pulse.socket
WantedBy=default.target
cat /usr/lib/systemd/user/pipewire.service ξ² β
[Unit]
Description=PipeWire Multimedia Service
# We require pipewire.socket to be active before starting the daemon, because
# A user installing pipewire and doing `systemctl --user start pipewire`
# confusion.
# After=pipewire.socket is not needed, as it is already implicit in the
Requires=pipewire.socket
[Service]
LockPersonality=yes
NoNewPrivileges=yes
Type=simple
Restart=on-failure
Slice=session.slice
[Install]
Also=pipewire.socket
cat /usr/lib/systemd/user/pipewire-pulse.socket
[Unit]
ConditionUser=!root
Conflicts=pulseaudio.socket
[Socket]
Priority=6
ListenStream=%t/pulse/native
[Install]
WantedBy=sockets.target
cat /usr/lib/systemd/user/pipewire.socket ξ² β
[Unit]
Description=PipeWire Multimedia System Socket
[Socket]
Priority=6
ListenStream=%t/pipewire-0
[Install]
