well i dont know, since i have never used it … and if you dont know either, why do you have it installed?
so post the pacman output, we remove it
Here’s the output,
local/deepin-session-shell 5.5.78-1 (deepin)
Deepin desktop-environment - session-shell module
local/liblightdm-qt5 1:1.32.0-4
LightDM Qt client library
local/lightdm 1:1.32.0-4
A lightweight display manager
also, I don’t use deepin, I downloaded once the deepin app for the webcam of my laptop and only for that, now i see that deepin has installed a bunch of other staff.
shall we remove this as well?
yes lets remove it too:
pacman -Qs deepin
local/deepin-account-faces 1.0.12.1-1 (deepin)
Account faces for Linux Deepin
local/deepin-anything 5.0.18-1 (deepin)
Deepin Anything file search tool
local/deepin-anything-dkms 5.0.18-1
local/deepin-api 5.5.31-1 (deepin)
Golang bindings for dde-daemon
local/deepin-app-services 0.0.20-1 (deepin)
Service collection of DDE applications, including dconfig-center
local/deepin-boot-maker 5.7.8-1 (deepin-extra)
Tool to create a bootable usb stick quick and easy
local/deepin-camera 1.4.8-1 (deepin-extra)
Tool to view camera, take photo and video
local/deepin-control-center 5.5.155-1 (deepin)
New control center for linux deepin
local/deepin-daemon 5.14.106-2 (deepin)
Daemon handling the DDE session settings
local/deepin-desktop-base 2:2022.07.26-2 (deepin)
Base component for Deepin
local/deepin-desktop-schemas 5.10.11-1 (deepin)
GSettings deepin desktop-wide schemas
local/deepin-dock 5.5.75-1 (deepin)
Deepin desktop-environment - dock module
local/deepin-file-manager 1:5.8.1-1 (deepin)
Deepin File Manager
local/deepin-gtk-theme 2020.06.10-1 (deepin)
Deepin GTK Theme
local/deepin-icon-theme 2021.11.24-1 (deepin)
Deepin Icons
local/deepin-image-editor 1.0.23-1
Public library for deepin-image-viewer and deepin-album
local/deepin-launcher 5.6.1-1 (deepin)
Deepin desktop-environment - Launcher module
local/deepin-menu 5.0.1-9 (deepin)
Deepin menu service for building beautiful menus
local/deepin-network-core 1.0.63-2 (deepin)
DDE network library and plugins
local/deepin-polkit-agent 5.4.16-1 (deepin)
Deepin Polkit Agent
local/deepin-polkit-agent-ext-gnomekeyring 0.1.0-2 (deepin)
GNOME keyring extension for dde-polkit-agent
local/deepin-pw-check 5.1.17-1 (deepin)
Tool to verify the validity of the password
local/deepin-qt-dbus-factory 5.5.22-6
A repository stores auto-generated Qt5 dbus code (libdframeworkdbus)
local/deepin-qt5integration 5.5.25-1 (deepin)
Qt platform theme integration plugins for DDE
local/deepin-qt5platform-plugins 5.0.71-1 (deepin)
Qt platform plugins for DDE
local/deepin-session-ui 5.5.38-1 (deepin)
Deepin desktop-environment - Session UI module
local/deepin-sound-theme 15.10.6-1 (deepin)
Deepin sound theme
local/deepin-wallpapers 1:1.7.7-2 (deepin)
Default wallpapers for DDE
local/deepin-wayland 1.0.0-1 (deepin)
DDE wayland support libraries
local/docparser 1.0.1-1 (deepin)
A document parser library ported from document2html
local/dtkgui 1:5.6.3-1
Deepin Toolkit, gui module for DDE look and feel
local/dtkwidget 5.6.3-1
Deepin graphical user interface library
local/startdde 5.10.1-1 (deepin)
starter of deepin desktop environment
run this and post output from it, before you hit enter… this should take care of all dependencies, but just to be sure post the output…
sudo pacman -Rcns deepin-session-shell liblightdm-qt5 lightdm deepin-account-faces deepin-anything
checking dependencies...
:: brave-browser optionally requires libgnome-keyring: Enable GNOME keyring support
:: git optionally requires org.freedesktop.secrets: keyring credential helper
:: gnutls optionally requires guile: for use with Guile bindings
:: graphviz optionally requires guile: guile bindings
:: grub optionally requires libisoburn: Provides xorriso for generating grub rescue iso using grub-mkrescue
:: libsecret optionally requires org.freedesktop.secrets: secret storage backend
warning: dependency cycle detected:
warning: startdde will be removed after its deepin-session-shell dependency
warning: deepin-file-manager will be removed after its startdde dependency
warning: deepin-control-center will be removed after its startdde dependency
warning: deepin-daemon will be removed after its deepin-session-ui dependency
warning: deepin-launcher will be removed after its startdde dependency
Packages (72) avfs-1.1.4-2 bamf-0.5.6-1 blur-effect-1.1.3-2 ddcutil-1.3.0-1 deepin-anything-dkms-5.0.18-1 deepin-api-5.5.31-1 deepin-app-services-0.0.20-1 deepin-control-center-5.5.155-1 deepin-daemon-5.14.106-2
deepin-desktop-base-2:2022.07.26-2 deepin-desktop-schemas-5.10.11-1 deepin-dock-5.5.75-1 deepin-file-manager-1:5.8.1-1 deepin-gtk-theme-2020.06.10-1 deepin-icon-theme-2021.11.24-1 deepin-launcher-5.6.1-1
deepin-menu-5.0.1-9 deepin-network-core-1.0.63-2 deepin-polkit-agent-5.4.16-1 deepin-polkit-agent-ext-gnomekeyring-0.1.0-2 deepin-pw-check-5.1.17-1 deepin-qt-dbus-factory-5.5.22-6 deepin-qt5integration-5.5.25-1
deepin-qt5platform-plugins-5.0.71-1 deepin-session-ui-5.5.38-1 deepin-sound-theme-15.10.6-1 deepin-wallpapers-1:1.7.7-2 deepin-wayland-1.0.0-1 disomaster-5.0.8-1 dkms-3.0.9-1 docparser-1.0.1-1 dtkcommon-5.5.23-1
dtkcore-1:5.6.3-1 dtkgui-1:5.6.3-1 dtkwidget-5.6.3-1 ffmpegthumbnailer-2.2.2-4 freeimage-3.18.0-16 gc-8.2.2-1 gdk-pixbuf-xlib-2.40.2-2 geoip-1.6.12-2 geoip-database-20221118-1 geoip-database-extra-20221118-1
gio-qt-0.0.11-1 gnome-keyring-1:42.1-2 gsettings-qt-0.2-1 guile-3.0.8-3 i2c-tools-4.3-3 imwheel-1.0.0pre12-6 jemalloc-1:5.3.0-1 jxrlib-0.2.4-1 libgnome-keyring-3.12.0+13+g4f8ab73-3 libisoburn-1.5.4-2
libisofs-1.5.4-1 libmediainfo-22.09-1 libqtxdg-3.10.0-1 libzen-0.4.40-1 lshw-B.02.19.2-5 lucene++-3.0.8-5 lzlib-1.13-2 make-4.3-5 mimetic-0.9.8-2 papirus-icon-theme-20221201-1 patch-2.7.6-8 startdde-5.10.1-1
tinyxml2-9.0.0-1 udisks2-qt5-5.0.6-1 xcur2png-0.7.1-7 deepin-account-faces-1.0.12.1-1 deepin-anything-5.0.18-1 deepin-session-shell-5.5.78-1 liblightdm-qt5-1:1.32.0-4 lightdm-1:1.32.0-4
Total Removed Size: 787,02 MiB
:: Do you want to remove these packages? [Y/n] y
(1/2) Remove DKMS modules
(2/2) Removing old entries from the info directory file...
( 1/72) removing deepin-session-shell [#######################################################################################] 100%
( 2/72) removing startdde [#######################################################################################] 100%
( 3/72) removing deepin-dock [#######################################################################################] 100%
( 4/72) removing deepin-launcher [#######################################################################################] 100%
( 5/72) removing deepin-menu [#######################################################################################] 100%
( 6/72) removing deepin-session-ui [#######################################################################################] 100%
( 7/72) removing deepin-wallpapers [#######################################################################################] 100%
( 8/72) removing deepin-control-center [#######################################################################################] 100%
( 9/72) removing geoip-database-extra [#######################################################################################] 100%
(10/72) removing geoip [#######################################################################################] 100%
(11/72) removing geoip-database [#######################################################################################] 100%
(12/72) removing deepin-pw-check [#######################################################################################] 100%
(13/72) removing deepin-network-core [#######################################################################################] 100%
(14/72) removing deepin-daemon [#######################################################################################] 100%
(15/72) removing imwheel [#######################################################################################] 100%
Removed "/etc/systemd/user/sockets.target.wants/gnome-keyring-daemon.socket".
(16/72) removing gnome-keyring [#######################################################################################] 100%
(17/72) removing deepin-polkit-agent-ext-gnomekeyring [#######################################################################################] 100%
(18/72) removing libgnome-keyring [#######################################################################################] 100%
(19/72) removing deepin-desktop-schemas [#######################################################################################] 100%
(20/72) removing deepin-sound-theme [#######################################################################################] 100%
(21/72) removing deepin-icon-theme [#######################################################################################] 100%
(22/72) removing papirus-icon-theme [#######################################################################################] 100%
(23/72) removing deepin-gtk-theme [#######################################################################################] 100%
(24/72) removing deepin-app-services [#######################################################################################] 100%
(25/72) removing ddcutil [#######################################################################################] 100%
(26/72) removing i2c-tools [#######################################################################################] 100%
(27/72) removing bamf [#######################################################################################] 100%
(28/72) removing deepin-polkit-agent [#######################################################################################] 100%
(29/72) removing deepin-api [#######################################################################################] 100%
(30/72) removing xcur2png [#######################################################################################] 100%
(31/72) removing gdk-pixbuf-xlib [#######################################################################################] 100%
(32/72) removing blur-effect [#######################################################################################] 100%
(33/72) removing deepin-account-faces [#######################################################################################] 100%
(34/72) removing deepin-file-manager [#######################################################################################] 100%
(35/72) removing mimetic [#######################################################################################] 100%
(36/72) removing lucene++ [#######################################################################################] 100%
(37/72) removing libmediainfo [#######################################################################################] 100%
(38/72) removing tinyxml2 [#######################################################################################] 100%
(39/72) removing libzen [#######################################################################################] 100%
(40/72) removing jemalloc [#######################################################################################] 100%
(41/72) removing gio-qt [#######################################################################################] 100%
(42/72) removing ffmpegthumbnailer [#######################################################################################] 100%
(43/72) removing docparser [#######################################################################################] 100%
(44/72) removing disomaster [#######################################################################################] 100%
(45/72) removing libisoburn [#######################################################################################] 100%
(46/72) removing libisofs [#######################################################################################] 100%
(47/72) removing avfs [#######################################################################################] 100%
(48/72) removing lzlib [#######################################################################################] 100%
(49/72) removing deepin-qt5integration [#######################################################################################] 100%
(50/72) removing deepin-qt5platform-plugins [#######################################################################################] 100%
(51/72) removing deepin-wayland [#######################################################################################] 100%
(52/72) removing dtkwidget [#######################################################################################] 100%
(53/72) removing dtkgui [#######################################################################################] 100%
(54/72) removing freeimage [#######################################################################################] 100%
(55/72) removing jxrlib [#######################################################################################] 100%
(56/72) removing libqtxdg [#######################################################################################] 100%
(57/72) removing deepin-qt-dbus-factory [#######################################################################################] 100%
(58/72) removing deepin-anything [#######################################################################################] 100%
(59/72) removing udisks2-qt5 [#######################################################################################] 100%
(60/72) removing dtkcore [#######################################################################################] 100%
(61/72) removing dtkcommon [#######################################################################################] 100%
(62/72) removing lshw [#######################################################################################] 100%
(63/72) removing deepin-desktop-base [#######################################################################################] 100%
(64/72) removing gsettings-qt [#######################################################################################] 100%
(65/72) removing deepin-anything-dkms [#######################################################################################] 100%
(66/72) removing dkms [#######################################################################################] 100%
(67/72) removing patch [#######################################################################################] 100%
(68/72) removing make [#######################################################################################] 100%
(69/72) removing guile [#######################################################################################] 100%
(70/72) removing gc [#######################################################################################] 100%
(71/72) removing liblightdm-qt5 [#######################################################################################] 100%
(72/72) removing lightdm [#######################################################################################] 100%
(1/8) Reloading system manager configuration...
(2/8) Reloading device manager configuration...
(3/8) Arming ConditionNeedsUpdate...
(4/8) Refreshing PackageKit...
(5/8) Reloading system bus configuration...
(6/8) Compiling GSettings XML schema files...
(7/8) Updating icon theme caches...
(8/8) Updating the desktop file MIME type cache...
I think it went ok
no it didnt … it removed also other stuff like gc/guile/jemalloc… so install it back:
sudo pacman -S jemalloc patch make guile gc
reboot, and hopefully your system will not be more messed up as it is now
ok, I’m back after reboot. Still through tty and startx.
at least you cleaned your system up…
lets try renaming the user folder:
sudo mv /etc/systemd/user /etc/systemd/user.bak
reboot
No luck with that either… Still tty and startx and no sound.
post output from this again:
ls /etc/systemd/user/*
to check if it was recreated and is the same as before renaming…
also output from:
pacman -Qs 'sddm|pam'
I guess it didn’t recreate,
ls /etc/systemd/user/* ✔
zsh: no matches found: /etc/systemd/user/*
second one,
local/kwallet-pam 5.26.4-1 (plasma)
KWallet PAM integration
local/lib32-pam 1.5.2-1
Pluggable Authentication Modules
local/libpamac 11.4.1-3
Library for Pamac package manager based on libalpm
local/libpamac-flatpak-plugin 11.4.1-2
Flatpak plugin for Pamac
local/libpamac-snap-plugin 11.4.1-2
Snap plugin for Pamac
local/pam 1.5.2-1
PAM (Pluggable Authentication Modules) library
local/pamac-cli 10.4.3-2
A Package Manager based on libalpm with AUR and Appstream support
local/pamac-gtk 10.4.3-2
local/pamac-tray-icon-plasma 0.1.2-4
Pamac tray icon for plasma users
local/pambase 20221020-1
Base PAM configuration for services
local/sddm 0.19.0-9
QML based X11 and Wayland display manager
local/sddm-breath-theme 22.0.0-2
Breath theme for SDDM
local/sddm-kcm 5.26.4-1 (plasma)
KDE Config Module for SDDM
local/shadow 4.12.3-2
Password and account management tool suite with support for shadow files and PAM
Everytime I boot and login with tty and startx, and run brave browser, the KDE Wallet pops up and ask me for my password, even though in the settings it is set to start automatically.
ok, so rename it back:
sudo mv /etc/systemd/user.bak /etc/systemd/user
you can disable kwallet in system settings…
and lets reinstall sddm and pam:
sudo pacman -S kwallet-pam lib32-pam pam pambase sddm sddm-breath-theme sddm-kcm
if there were no errors, reboot
Done with no errors, rebooted, still login with tty and startx.
I tried
inxi -Aa
and got
inxi -Aa 1 ✘
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.63 running: no
shouldn’t the pipewire server be running?
yes it should be running but your audio is broken…
looking at the user services, you have there still pipewire-media-session service, which should be removed when you installed wireplumber…
post output from:
pacman -Qs 'wireplumber|pipewire-media-session'
local/libwireplumber 0.4.13-1
Session / policy manager implementation for PipeWire - client library
local/pipewire-media-session 1:0.4.1-2
Example session manager for PipeWire
so you have installed the media session:
and here you have installed wireplumber:
so install wireplumber:
sudo pacman -S wireplumber
it will be in conflict with the media session; when done reboot and post again output from:
done, still no sound.
/etc/systemd/user/pipewire-session-manager.service
/etc/systemd/user/default.target.wants:
xdg-user-dirs-update.service
/etc/systemd/user/pipewire.service.wants:
wireplumber.service
/etc/systemd/user/sockets.target.wants:
gcr-ssh-agent.socket p11-kit-server.socket pipewire-pulse.socket pipewire.socket
In info center I see this,
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
Subsystem: ASUSTeK Computer Inc. Device 143f
Flags: bus master, fast devsel, latency 0, IRQ 36
Memory at f7a10000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
ok, so the wireplumber service is now present…
lets try to fix permissions, that could also be the cause;
install this:
pamac build pacman-fix-permissions
when done run this:
sudo pacman-fix-permissions -a
when its done, and there were some modifications, reboot and see if it helped…
more info here:
