today I have tried to log in to my Manjaro KDE laptop and got stuck in the login loop. After putting in my password I get a short glimpse of black screen and then I am back in login screen again. I can’t start any desktop session (wayland or X) or any other WM.
I am running Manjaro KDE on a laptop with nVidia 2060 graphics card. Yesterday, everything was running fine. I did not perform any update.
I have been making some changes to my .bashrc file yesterday. I have reverted that, but that didn’t lead to resolving my issue.
I am sure I am entering my password correctly. I have been looking around this forum for a solution to my problem, but didn’t found anything specific.
I can use Ctrl + Alt + F2 to access tty.
I have no idea how to resolve this issue. Any tip on what to do would be a tremendous help!
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
Side note: I am using accessibility option to display desktop notification in KDE when I turn on the Caps-lock key. These notification have randomly an oversized window. also, my chromium browser in which I am writing this froze a few times, probably because of that. without caps lock it seems to hold.
you could try reinstalling your video drivers:
uninstall first nvidia drivers with: sudo mhwd -r pci video-hybrid-intel-nvidia-prime
im not sure if you need video linux, but i have it installed and have the same setup as you, so try installing it: sudo mhwd -i pci video-linux
reboot and check if you can boot without black screen
EDIT: if you using optimus manager dont run these commands!!!
ok so you have these errors: pcieport 0000:00:1d.5: AER: Corrected error received
i dont say thats what is causing your black screen, but it needs to be fixed… so first turn on your wifi and open the ksystemlog application and check if you have logs spamming there…
