so you have spamming … ok, lets fix it, navigate via dolphin to etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT
add this parameter: pci=nomsi
- you add it inside the " " quotes - there will be other parameters like quiet apparmor=1 security=apparmor … than copy the line and post it here if you did it correctly
so in /etc/default/grub
i have near the top this line now:
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nomsi resume=UUID=a32e7c07-2745-437d-8730-6009ad9568a5 udev.log_priority=3"
looks good, now save and exit the file, open terminal and run this:
sudo update-grub
reboot and check again the ksystemlog for spamming
The spamming is reduced to new entries about 3 - 5 seconds + less red lines.
So, how do we solve the login issues?
do you have your wifi turned on? if no turn it on, and check again, also post a screenshot of ksystemlog, what those messages are, bc thats a lot of loggin
I have wifi on, i am on x after I run startx
from tty
with all DE features.
Mostly these:
27.04.22 20:16 kernel audit: type=1327 audit(1651083385.669:195): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
27.04.22 20:16 audit BPF prog-id=0 op=UNLOAD
27.04.22 20:16 kernel audit: type=1334 audit(1651083385.715:196): prog-id=0 op=UNLOAD
27.04.22 20:16 audit BPF prog-id=57 op=LOAD
27.04.22 20:16 audit SYSCALL arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffccacb02c0 a2=80 a3=7ffccacb02c0 items=0 ppid=1 pid=586 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
27.04.22 20:16 audit PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
27.04.22 20:16 kernel audit: type=1334 audit(1651083395.701:197): prog-id=57 op=LOAD
27.04.22 20:16 kernel audit: type=1300 audit(1651083395.701:197): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffccacb02c0 a2=80 a3=7ffccacb02c0 items=0 ppid=1 pid=586 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
27.04.22 20:16 kernel audit: type=1327 audit(1651083395.701:197): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
27.04.22 20:16 kernel audit: type=1334 audit(1651083415.827:198): prog-id=0 op=UNLOAD
27.04.22 20:17 audit BPF prog-id=58 op=LOAD
27.04.22 20:17 audit SYSCALL arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffccacb02c0 a2=80 a3=7ffccacb02c0 items=0 ppid=1 pid=586 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
27.04.22 20:17 audit PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
27.04.22 20:17 kernel audit: type=1334 audit(1651083425.860:199): prog-id=58 op=LOAD
27.04.22 20:17 kernel audit: type=1300 audit(1651083425.860:199): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffccacb02c0 a2=80 a3=7ffccacb02c0 items=0 ppid=1 pid=586 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
27.04.22 20:17 kernel audit: type=1327 audit(1651083425.860:199): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
27.04.22 20:17 audit BPF prog-id=0 op=UNLOAD
27.04.22 20:17 kernel audit: type=1334 audit(1651083435.950:200): prog-id=0 op=UNLOAD
looks like the aer spamming is gone… so go to system settings, search for sddm, click on ‘behavior’ and check automatically log in with session x11, click apply, reboot and see if you can normally boot
My situation still persists, after changing the settings.
ok check again logs with this:
journalctl --boot=0 --priority=5 --no-pager
and copy the last 40 here
Output of journalctl --boot=0 --priority=5 --no-pager | tail -n 40
dub 27 20:30:12 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084212.842:127): prog-id=0 op=UNLOAD
dub 27 20:30:22 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084222.844:128): prog-id=26 op=LOAD
dub 27 20:30:22 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084222.844:128): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:30:22 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084222.844:128): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:30:22 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084222.897:129): prog-id=0 op=UNLOAD
dub 27 20:30:32 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084232.859:130): prog-id=27 op=LOAD
dub 27 20:30:32 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084232.859:130): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:30:32 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084232.859:130): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:30:53 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084253.025:131): prog-id=0 op=UNLOAD
dub 27 20:30:58 tomaskrulis-nitroan51554 kernel: audit: type=1104 audit(1651084258.488:132): pid=592 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_unix,pam_env acct="tomaskrulis" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
dub 27 20:30:58 tomaskrulis-nitroan51554 kernel: audit: type=1106 audit(1651084258.488:133): pid=592 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_loginuid,pam_limits,pam_unix acct="tomaskrulis" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
dub 27 20:31:02 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084262.971:134): prog-id=28 op=LOAD
dub 27 20:31:02 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084262.971:134): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:31:02 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084262.971:134): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:31:33 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084293.110:135): prog-id=0 op=UNLOAD
dub 27 20:31:43 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084303.110:136): prog-id=29 op=LOAD
dub 27 20:31:43 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084303.110:136): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:31:43 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084303.110:136): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:31:43 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084303.137:137): prog-id=30 op=LOAD
dub 27 20:31:43 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084303.137:137): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:31:43 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084303.137:137): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:31:43 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084303.157:138): prog-id=0 op=UNLOAD
dub 27 20:31:53 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084313.206:139): prog-id=0 op=UNLOAD
dub 27 20:32:03 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084323.189:140): prog-id=31 op=LOAD
dub 27 20:32:03 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084323.189:140): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:32:03 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084323.189:140): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:32:03 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084323.256:141): prog-id=0 op=UNLOAD
dub 27 20:32:03 tomaskrulis-nitroan51554 systemd[2679]: notifyFromSystemD.service: Failed to determine supplementary groups: Operation not permitted
dub 27 20:32:03 tomaskrulis-nitroan51554 systemd[2679]: notifyFromSystemD.service: Failed at step GROUP spawning /home/tomaskrulis/systemDJobs/notifyFromSystemD.sh: Operation not permitted
dub 27 20:32:03 tomaskrulis-nitroan51554 systemd[1002]: notifyFromSystemD.service: Control process exited, code=exited, status=216/GROUP
dub 27 20:32:03 tomaskrulis-nitroan51554 systemd[1002]: notifyFromSystemD.service: Failed with result 'exit-code'.
dub 27 20:32:03 tomaskrulis-nitroan51554 systemd[1002]: Failed to start A basic service to send a desktop notification using the systemd scheduler.
dub 27 20:32:13 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084333.216:142): prog-id=32 op=LOAD
dub 27 20:32:13 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084333.216:142): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:32:13 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084333.216:142): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:32:13 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084333.306:143): prog-id=0 op=UNLOAD
dub 27 20:32:23 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084343.259:144): prog-id=33 op=LOAD
dub 27 20:32:23 tomaskrulis-nitroan51554 kernel: audit: type=1300 audit(1651084343.259:144): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff69dc8b90 a2=80 a3=7fff69dc8b90 items=0 ppid=1 pid=600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
dub 27 20:32:23 tomaskrulis-nitroan51554 kernel: audit: type=1327 audit(1651084343.259:144): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
dub 27 20:32:53 tomaskrulis-nitroan51554 kernel: audit: type=1334 audit(1651084373.424:145): prog-id=0 op=UNLOAD
i really dont see anything there, can you check in ksystemlog and priorities select the red and orange colors
Getting things like this:
27.04.22 20:40 audit BPF prog-id=26 op=LOAD
27.04.22 20:40 audit SYSCALL arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffd89627570 a2=80 a3=7ffd89627570 items=0 ppid=1 pid=598 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
27.04.22 20:40 audit PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
27.04.22 20:40 audit BPF prog-id=27 op=LOAD
27.04.22 20:41 audit BPF prog-id=28 op=LOAD
27.04.22 20:41 audit SYSCALL arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffd89627570 a2=80 a3=7ffd89627570 items=0 ppid=1 pid=598 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
27.04.22 20:41 audit PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Also these:
27.04.22 20:42 systemd notifyFromSystemD.service: Failed to determine supplementary groups: Operation not permitted
27.04.22 20:42 systemd notifyFromSystemD.service: Failed at step GROUP spawning /home/tomaskrulis/systemDJobs/notifyFromSystemD.sh: Operation not permitted
27.04.22 20:42 systemd notifyFromSystemD.service: Failed with result 'exit-code'.
27.04.22 20:42 systemd Failed to start A basic service to send a desktop notification using the systemd scheduler.
Those are my custom systems service tests, somehow I am having trouble disabling their timers.
is it:
systemctl --user stop myjob.timer
and those audit messages are in red/yellow color? … can you disable your custom services? reboot and try again
All of them are red.
I have disabled all of my custom services, but I still can’t login through SDDM.
ok so provide output also from:
inxi -Fazy
for someone more skilled, because i have no idea… so you could try installing the 5.10 lts kernel, from system settings/ kernel … also uninstalling the modesseting driver, and keep only the video linux driver, than reboot, select the 5.10 and try with it:
command for uninstalling modesseting:
sudo mhwd -r pci video-modesetting
also check in system settings under autostart what you have there
Output of inxi -Fazy
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c3941287-a07b-4844-bffb-b439646b54a7 ro quiet pci=nomsi
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.31
serial: <superuser required>
Mobo: CFL model: Octavia_CFS v: V1.31 serial: <superuser required>
UEFI: Insyde v: 1.31 date: 06/29/2020
ID-1: BAT1 charge: 46.6 Wh (100.0%) condition: 46.6/57.5 Wh (81.1%)
volts: 16.6 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2911 high: 3920 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3852 2: 1800 3: 3150
4: 3543 5: 2509 6: 3920 7: 1978 8: 2542 bogomips: 38408
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Type: srbds mitigation: TSX disabled
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: eDP-1
empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: N/A alternate: nouveau pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
Display: server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :1 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.49 running: yes
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: alx v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 1969:e0b1
class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 399.61 GiB (41.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200 MTFDHBA1T0TCK
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P1MA003 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 944.77 GiB size: 928.94 GiB (98.32%)
used: 399.61 GiB (43.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 56.0 C pch: 58.0 C mobo: N/A
Processes: 258 Uptime: 7m wakeups: 1 Memory: 15.47 GiB
used: 3.58 GiB (23.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 alt: 10 clang: 13.0.1 Packages: 1832 guix-sys: 0 guix-usr: 0
nix-default: 0 nix-sys: 0 nix-usr: 36 lib: 6 pacman: 1796 lib: 508
Shell: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.15
For autostart, I have only megasync.
ok, I try those too.
Tank you for helping me!
ok let me know how it went
None of these solved my issue.
Just randomly one day my system works and the other it is broken and nobody knows what to do with it. I didn’t modify any system files. Yesterday, I was modifying my .bashrc
and visiting my /etc/profile
file.
Although, the symptoms could be somehow related.
Do you know where I could find the default /etc/profile
file for manjaro kde?
ok, so its probably not related to your graphic drivers, so you can install them again:
sudo mhwd -i pci video-modesetting
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
reboot
you could then try creating a new user and try with him if you still get stuck
and for the /etc/profile/ i assume the best way would be from a live usb comparing it
I have tried the new user approach already and it had the same issue. Also reinstalled the drivers, nothing lead to solving the issue.
