Hi ![]()
Intel Pentium Dual core G3220
12gb ram n 2tb hdd
Cache is always 1gb
Booting time 15 mins+
Opening after lock screen takes 3 more mins
Gnome3 version
Hi ![]()
12gb ram n 2tb hdd
Cache is always 1gb
Gnome3 version
systemd-analyze blame
1min 13.852s lvm2-monitor.service
1min 8.790s snapd.service
57.185s dev-sdb7.device
40.094s polkit.service
38.756s ModemManager.service
22.716s udisks2.service
20.346s apparmor.service
19.675s NetworkManager.service
19.667s systemd-logind.service
18.319s var-lib-snapd-snap-brave-97.mount
18.315s var-lib-snapd-snap-brave-98.mount
16.419s var-lib-snapd-snap-core18-1944.mount
15.330s systemd-udevd.service
14.890s wpa_supplicant.service
14.436s var-lib-snapd-snap-core18-1988.mount
12.446s accounts-daemon.service
10.277s dev-loop4.device
10.087s systemd-tmpfiles-setup-dev.service
9.963s systemd-modules-load.service
9.852s colord.service
9.630s modprobe@drm.service
9.177s modprobe@fuse.service
9.116s var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
9.051s dev-loop7.device
8.180s upower.service
7.488s tlp.service
7.020s var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
6.861s systemd-random-seed.service
6.801s gdm.service
6.448s var-lib-snapd-snap-snapd-10707.mount
6.312s var-lib-snapd-snap-snapd-11036.mount
6.311s systemd-fsck@dev-disk-by\x2duuid-82DC\x2d7F8F.service
6.310s dev-loop5.device
6.310s dev-loop6.device
6.081s snapd.apparmor.service
5.607s systemd-udev-trigger.service
4.897s systemd-tmpfiles-setup.service
4.799s kmod-static-nodes.service
4.794s modprobe@configfs.service
4.542s boot-efi.mount
4.541s dev-loop8.device
4.534s dev-loop9.device
4.387s var-lib-snapd-snap-shotcut-123.mount
4.021s dev-hugepages.mount
4.020s dev-mqueue.mount
4.019s sys-kernel-debug.mount
4.017s sys-kernel-tracing.mount
3.284s tmp.mount
3.134s user@1000.service
2.973s systemd-journald.service
2.939s systemd-timesyncd.service
1.830s systemd-rfkill.service
1.828s var-lib-snapd-snap-shotcut-186.mount
1.807s systemd-journal-flush.service
1.795s systemd-binfmt.service
1.690s systemd-tmpfiles-clean.service
1.578s ufw.service
1.481s systemd-update-utmp.service
1.134s systemd-sysctl.service
377ms rtkit-daemon.service
368ms systemd-user-sessions.service
361ms systemd-remount-fs.service
164ms linux-module-cleanup.service
68ms pamac-daemon.service
14ms user-runtime-dir@1000.service
7ms dev-loop2.device
7ms dev-loop1.device
6ms dev-loop3.device
6ms dev-loop0.device
3ms snapd.socket
3ms sys-kernel-config.mount
2ms sys-fs-fuse-connections.mount
2ms proc-sys-fs-binfmt_misc.mount
Need some more information.
inxi -Fazy
Kernel: 5.4.95-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=096bbb8b-bd5c-46b5-821e-a2ae8f81f354 rw quiet apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: H81M-S v: x.x serial: <filter>
UEFI: American Megatrends v: F1 date: 06/11/2014
Info: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11977
Speed: 1020 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 1020 2: 1011
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0402
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :1
screens: 1
s-diag: 582mm (22.9")
Monitor-1: VGA1 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics (HSW GT1) v: 4.5 Mesa 20.3.4
compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
class ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
class ID: 0403
Sound Server: ALSA v: k5.4.95-1-MANJARO
vendor: Gigabyte driver: r8168 v: 8.048.03-NAPI modules: r8169 port: e000
bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb
bus ID: 2-2:2 chip ID: 148f:5370 class ID: 0000 serial: <filter>
IF: wlp0s20u2 state: up mac: <filter>
Local Storage: total: 1.82 TiB used: 31.66 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10PURZ-85U8XY0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1ER162
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: GPT
ID-1: / raw size: 81.5 GiB size: 79.72 GiB (97.82%) used: 31.63 GiB (39.7%)
fs: ext4 dev: /dev/sdb7 maj-min: 8:23
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 33.5 MiB (34.9%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb9 maj-min: 8:25
System Temperatures: cpu: 29.8 C mobo: 27.8 C
I would check the health of your disk(s) with this command:
sudo smartctl -i /dev/sdX
Where X corresponds to the disk you want to check.
Is the output of smartctl -a does not show anyth ok NG bad you can perform a SMART test just in case:
sudo smartctl -t <short|long> /dev/sdX
Where short or long is the type of test, one take
s a few minutes, the other may take a couple of hours.
You can then check the test results with:
sudo smartctl -l selftest /dev/sdX
Can you remove sdb? can you delete it from your fstab?
