Hello community,
I know there are plenty of threads for this topic, but none of the solutions worked for me.
I run a system update and now when I press enter to log in I get back to the log in screen, but this time I’m unable to enter anything, switching to console mode is working though. I’m pretty sure that the problem is related to my Nvidia graphics card like almost every problem I’m running into on Linux.
I created a restore point before updating, which works fine, but I would like to update my system again eventually.
Also, what is a good way to get the logging files from my broken PC to post them here on my other PC where a UI is working. ![]()
Manjaro 20.2.1 LTS
Graphics Card: Geforce GTX 980 Ti
Driver: Nvidia 460.39 → installed by system update
Kernel: 5.4
Things I already tried.
- creating a new user
- installing latest driver from nvidia homepage
UPDATE:
I got the 390xx driver working with actually seeing the GUI. But the old problem remains unsolved, after entering the password, the splash screen is shown and the system is freezing with the loading bar. However there is a new error showing up within journalctl:
pam_systemd(login:session): Failed to relase session: Interrupted system call
System Information
Kernel: 5.4.95-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=f6844603-8641-478e-b175-14cbc9a0133d rw quiet apparmor=1
security=apparmor resume=UUID=91162dee-f583-42ad-9424-0692b53fd90a
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
serial: <filter>
Mobo: Gigabyte model: X570 AORUS ELITE serial: <filter>
UEFI: American Megatrends v: F31e date: 10/29/2020
RAM: total: 31.37 GiB used: 6.22 GiB (19.8%)
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 4 MiB bogomips: 115016
Speed: 2195 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2195 2: 2195 3: 2194 4: 2196 5: 2072 6: 2056 7: 2070 8: 4217 9: 2195
10: 2195 11: 2072 12: 2057 13: 2061 14: 3593 15: 2190 16: 2196
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdrand rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
conditional, RSB filling
Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: eVga.com. driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 08:00.0 chip ID: 10de:17c8
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 216 s-size: 903x254mm (35.6x10.0")
s-diag: 938mm (36.9")
Monitor-1: DP-2 res: 3840x2160 hz: 60 dpi: 157 size: 621x341mm (24.4x13.4")
diag: 708mm (27.9")
Monitor-2: DP-4 res: 3840x2160 hz: 60 dpi: 157 size: 621x341mm (24.4x13.4")
diag: 708mm (27.9")
OpenGL: renderer: GeForce GTX 980 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel bus ID: 04:00.0 chip ID: 1102:0012
class ID: 0403
Device-2: NVIDIA GM200 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus ID: 08:00.1 chip ID: 10de:0fb0
class ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 0a:00.4 chip ID: 1022:1487
class ID: 0403
Sound Server: ALSA v: k5.4.95-1-MANJARO
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.6.0-k
port: f000 bus ID: 03:00.0 chip ID: 8086:1539 class ID: 0200
IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
IF-ID-1: br-1b809eb4bcd6 state: up speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth39ad9ee state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: vethacfabb6 state: up speed: 10000 Mbps duplex: full mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 7.86 TiB used: 2.44 TiB (31.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000VX007-2DT166
size: 3.64 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5980 rpm serial: <filter> rev: CV11 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000VX007-2DT166
ID-4: /dev/sdi maj-min: 8:128 type: USB vendor: SanDisk model: Ultra Fit
size: 115.69 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NS95 rev: RN01
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
Optical-2: /dev/sr1 vendor: HL-DT-ST model: BD-RE BH16NS40 rev: 1.03
dev-links: N/A
ID-1: / raw size: 467.84 GiB size: 459.5 GiB (98.22%)
used: 356.64 GiB (77.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: f6844603-8641-478e-b175-14cbc9a0133d
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F6B6-9A1C
ID-3: /mnt/internal/data raw size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 2.09 TiB (58.5%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: Data
uuid: 26f59645-9144-40c1-bf88-492391a497a6
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 91162dee-f583-42ad-9424-0692b53fd90a
ID-1: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 3.64 TiB fs: ntfs label: Backup
uuid: A2D69D79D69D4F03
ID-3: /dev/sdi1 maj-min: 8:129 size: 115.69 GiB fs: exfat label: Volume
uuid: 5C6C-4F04
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0608 class ID: 0900
Device-1: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s chip ID: 048d:8297 class ID: 0301
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-5: 3-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: Genesys Logic All-in-One Cardreader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 05e3:0732
class ID: 0806 serial: <filter>
Device-2: 4-4:3 info: SanDisk Ultra Fit type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 0781:5583
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-8: 5-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 05e3:0610 class ID: 0900
Device-1: 5-2.2:3 info: Logitech Corded Keyboard K280e type: Keyboard,HID
chip ID: 046d:c328 class ID: 0300
Device-2: 5-2.4:4 info: Trust B.V. Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 15d9:0a33 class ID: 0301
Hub-9: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-10: 6-2:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip ID: 05e3:0612 class ID: 0900
System Temperatures: cpu: 48.1 C mobo: 16.8 C gpu: nvidia temp: 65 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 8%
Processes: 474 Uptime: 3m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1517 pacman: 1507 lib: 422 flatpak: 0 snap: 10
Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
Update log:
grep -iE 'installed|upgraded' /var/log/pacman.log
[2021-03-05T18:58:09+0100] [ALPM] upgraded manjaro-system (20210217-1 -> 20210302-1)
[2021-03-05T18:58:41+0100] [ALPM] upgraded alsa-card-profiles (1:0.3.21-1 -> 1:0.3.22-1)
[2021-03-05T18:58:41+0100] [ALPM] upgraded amd-ucode (20210119.r1813.0578970-1 -> 20210211.r1830.f7915a0-1)
[2021-03-05T18:58:41+0100] [ALPM] upgraded iana-etc (20201229-1 -> 20210202-1)
[2021-03-05T18:58:41+0100] [ALPM] upgraded glibc (2.33-3 -> 2.33-4)
[2021-03-05T18:58:44+0100] [ALPM] upgraded aom (2.0.1-1 -> 2.0.2-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded util-linux-libs (2.36.1-4 -> 2.36.2-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded glib2 (2.66.6-1 -> 2.66.7-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded e2fsprogs (1.46.0-1 -> 1.46.1-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded openssl (1.1.1.i-2 -> 1.1.1.j-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded libgcrypt (1.9.1-1 -> 1.9.2-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded libcap (2.47-1 -> 2.48-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded nettle (3.7-1 -> 3.7.1-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded appstream (0.14.0-4 -> 0.14.1-2)
[2021-03-05T18:58:44+0100] [ALPM] upgraded ca-certificates-mozilla (3.61-1 -> 3.62-1)
[2021-03-05T18:58:44+0100] [ALPM] upgraded libelf (0.182-1 -> 0.183-3)
[2021-03-05T18:58:45+0100] [ALPM] upgraded llvm-libs (11.0.1-2 -> 11.1.0-1)
[2021-03-05T18:58:45+0100] [ALPM] upgraded lm_sensors (3.6.0-2 -> 1:3.6.0.r41.g31d1f125-1)
[2021-03-05T18:58:45+0100] [ALPM] upgraded vulkan-icd-loader (1.2.166-1 -> 1.2.169-1)
[2021-03-05T18:58:45+0100] [ALPM] upgraded device-mapper (2.02.187-3 -> 2.03.11-4)
[2021-03-05T18:58:45+0100] [ALPM] upgraded cryptsetup (2.3.4-1 -> 2.3.4-2)
[2021-03-05T18:58:45+0100] [ALPM] upgraded util-linux (2.36.1-4 -> 2.36.2-1)
[2021-03-05T18:58:45+0100] [ALPM] upgraded hwids (20200813.1-1 -> 20201207-1)
[2021-03-05T18:58:45+0100] [ALPM] upgraded kbd (2.3.0-2 -> 2.4.0-2)
[2021-03-05T18:58:45+0100] [ALPM] upgraded libinput (1.16.4-1 -> 1.17.0-1)
[2021-03-05T18:58:45+0100] [ALPM] upgraded xkeyboard-config (2.31-1 -> 2.32-1)
[2021-03-05T18:58:45+0100] [ALPM] upgraded nvidia-utils (460.39-1 -> 460.39-2)
[2021-03-05T18:58:45+0100] [ALPM] upgraded mesa (20.3.4-1 -> 20.3.4-3)
[2021-03-05T18:58:46+0100] [ALPM] upgraded gdbm (1.19-1 -> 1.19-2)
[2021-03-05T18:58:46+0100] [ALPM] upgraded qt5-base (5.15.2-2 -> 5.15.2-3)
[2021-03-05T18:58:46+0100] [ALPM] upgraded appstream-qt (0.14.0-4 -> 0.14.1-2)
[2021-03-05T18:58:46+0100] [ALPM] upgraded archlinux-appstream-data (20210125-1 -> 20210218-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded python (3.9.1-1 -> 3.9.1-2)
[2021-03-05T18:58:46+0100] [ALPM] upgraded asciidoc (9.0.5-1 -> 9.1.0-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded attica (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded ki18n (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded karchive (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded kconfig (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded kcoreaddons (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded taglib (1.11.1-4 -> 1.12-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded dav1d (0.8.1-1 -> 0.8.1-2)
[2021-03-05T18:58:46+0100] [ALPM] upgraded lcms2 (2.11-2 -> 2.12-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded libsndfile (1.0.28-3 -> 1.0.31-1)
[2021-03-05T18:58:46+0100] [ALPM] upgraded libsamplerate (0.1.9-3 -> 0.2.1-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded libibus (1.5.23+3+gaa558de8-3 -> 1.5.24-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded nss (3.61-1 -> 3.62-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kfilemetadata (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kidletime (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded btrfs-progs (5.10-1 -> 5.10.1-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded dosfstools (4.1-3 -> 4.1-3.0)
[2021-03-05T18:58:47+0100] [ALPM] upgraded dmraid (1.0.0.rc16.3-12 -> 1.0.0.rc16.3-13)
[2021-03-05T18:58:47+0100] [ALPM] upgraded libbytesize (2.4-4 -> 2.5-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded lvm2 (2.02.187-3 -> 2.03.11-4)
[2021-03-05T18:58:47+0100] [ALPM] upgraded parted (3.4-1 -> 3.4-2)
[2021-03-05T18:58:47+0100] [ALPM] upgraded xfsprogs (5.10.0-1 -> 5.10.0-2)
[2021-03-05T18:58:47+0100] [ALPM] upgraded libassuan (2.5.4-1 -> 2.5.4-2)
[2021-03-05T18:58:47+0100] [ALPM] upgraded npth (1.6-2 -> 1.6-3)
[2021-03-05T18:58:47+0100] [ALPM] upgraded libblockdev (2.25-1 -> 2.25-2)
[2021-03-05T18:58:47+0100] [ALPM] upgraded js78 (78.7.1-1 -> 78.8.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded udisks2 (2.9.1-1 -> 2.9.2-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded solid (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kwidgetsaddons (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kjobwidgets (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kdbusaddons (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kwindowsystem (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kcrash (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kglobalaccel (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kauth (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kcodecs (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kguiaddons (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kconfigwidgets (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kitemviews (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kiconthemes (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kxmlgui (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kbookmarks (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded tar (1.33-1 -> 1.34-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded graphene (1.10.2-1 -> 1.10.4-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded pango (1:1.48.1-1 -> 1:1.48.2-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded knotifications (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kservice (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kwallet (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kcompletion (5.78.0-2 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded sonnet (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded ktextwidgets (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kded (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:47+0100] [ALPM] upgraded kio (5.78.0-3 -> 5.79.0-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded baloo (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded elfutils (0.182-1 -> 0.183-3)
[2021-03-05T18:58:48+0100] [ALPM] upgraded binutils (2.36-3 -> 2.36.1-2)
[2021-03-05T18:58:48+0100] [ALPM] upgraded bluez (5.55-1 -> 5.55-3)
[2021-03-05T18:58:48+0100] [ALPM] upgraded bluez-qt (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded kpackage (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded kdeclarative (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded bluedevil (1:5.20.5-1 -> 1:5.21.1-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded bluez-libs (5.55-1 -> 5.55-3)
[2021-03-05T18:58:48+0100] [ALPM] upgraded knewstuff (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded frameworkintegration (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:48+0100] [ALPM] upgraded kdecoration (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded breeze-icons (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded kwayland (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded breeze (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded procps-ng (3.3.16-3 -> 3.3.17-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded brltty (6.2-4 -> 6.3-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded cifs-utils (6.11-3 -> 6.12-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded libuv (1.40.0-1 -> 1.41.0-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded cmake (3.19.4-1 -> 3.19.5-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded cpupower (5.10-2 -> 5.11-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded docker (1:20.10.3-1 -> 1:20.10.3-3)
[2021-03-05T18:58:49+0100] [ALPM] upgraded python-packaging (20.8-2 -> 20.9-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded python-cffi (1.14.4-1 -> 1.14.5-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded python-docker (4.4.1-1 -> 4.4.3-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded docker-compose (1.28.2-1 -> 1.28.4-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded extra-cmake-modules (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:49+0100] [ALPM] upgraded fakeroot (1.25.3-1 -> 1.25.3-2)
[2021-03-05T18:58:50+0100] [ALPM] upgraded foomatic-db (3:20210205-1 -> 3:20210222-1)
[2021-03-05T18:58:50+0100] [ALPM] upgraded fuse-common (3.10.1-1 -> 3.10.2-1)
[2021-03-05T18:58:50+0100] [ALPM] upgraded fuse3 (3.10.1-1 -> 3.10.2-1)
[2021-03-05T18:58:50+0100] [ALPM] upgraded json-glib (1.6.0-1 -> 1.6.2-1)
[2021-03-05T18:58:50+0100] [ALPM] upgraded fwupd (1.5.5-1 -> 1.5.6-2)
[2021-03-05T18:58:50+0100] [ALPM] upgraded ghostscript (9.53.3-2 -> 9.53.3-3)
[2021-03-05T18:58:50+0100] [ALPM] upgraded perl (5.32.0-3 -> 5.32.1-1)
[2021-03-05T18:58:50+0100] [ALPM] upgraded git (2.30.0-1 -> 2.30.1-1)
[2021-03-05T18:58:50+0100] [ALPM] upgraded grub (2.04-15 -> 2.04-16)
[2021-03-05T18:58:50+0100] [ALPM] upgraded gtk-update-icon-cache (1:4.0.2-1 -> 1:4.0.3-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded gtk3 (1:3.24.24-2 -> 1:3.24.26-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded hdparm (9.58-3 -> 9.60-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded imagemagick (7.0.10.61-1 -> 7.0.11.1-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded jasper (2.0.24-1 -> 2.0.25-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded jre8-openjdk-headless (8.u275-1 -> 8.u282-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded jre8-openjdk (8.u275-1 -> 8.u282-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded jdk8-openjdk (8.u275-1 -> 8.u282-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kactivities (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kactivities-stats (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kactivitymanagerd (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kcmutils (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kcontacts (1:5.78.0-1 -> 1:5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kpty (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kdesu (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kde-cli-tools (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kde-gtk-config (5.20.5-2 -> 5.21.1-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kunitconversion (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kitemmodels (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kemoticons (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kparts (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kdelibs4support (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded knotifyconfig (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded ttf-liberation (2.1.2-1 -> 2.1.3-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded libksysguard (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded syntax-highlighting (5.78.0-1 -> 5.79.1-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded ktexteditor (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded libqalculate (3.16.1-1 -> 3.17.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kholidays (1:5.78.0-1 -> 1:5.79.0-1)
[2021-03-05T18:58:51+0100] [ALPM] upgraded kirigami2 (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded plasma-framework (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded threadweaver (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded krunner (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded milou (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded prison (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded qqc2-desktop-style (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded plasma-integration (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kpeople (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded libkscreen (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kquickcharts (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kscreenlocker (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kwayland-server (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded sbc (1.5-1 -> 1.5-2)
[2021-03-05T18:58:52+0100] [ALPM] upgraded pipewire (1:0.3.21-1 -> 1:0.3.22-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded plasma-workspace (5.20.5-2 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kdeplasma-addons (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kdnssd (5.78.0-1 -> 5.79.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kdoctools (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded systemsettings (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kgamma5 (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded khotkeys (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kjs (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded khtml (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kimageannotator (0.4.0-2 -> 0.4.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kimageformats (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kinfocenter (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:52+0100] [ALPM] upgraded kinit (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded kmenuedit (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded kscreen (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded ksshaskpass (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded ksysguard (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded kwallet-pam (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded kwayland-integration (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded kwrited (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-glibc (2.33-3 -> 2.33-4)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-util-linux (2.36.1-1 -> 2.36.2-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-e2fsprogs (1.46.0-1 -> 1.46.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-glib2 (2.66.6-1 -> 2.66.7-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-lcms2 (2.11-1 -> 2.12-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-openssl (1:1.1.1.i-1 -> 1:1.1.1.j-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-libcap (2.47-1 -> 2.48-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-libelf (0.182-1 -> 0.183-3)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-libgcrypt (1.9.1-1 -> 1.9.2-1)
[2021-03-05T18:58:53+0100] [ALPM] installed lib32-opus (1.3.1-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-libsndfile (1.0.28-3 -> 1.0.31-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-libunwind (1.3.1-1 -> 1.4.0-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-llvm-libs (11.0.1-2 -> 11.1.0-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-libva-mesa-driver (20.3.4-1 -> 20.3.4-2)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-lm_sensors (3.6.0-1 -> 1:3.6.0.r41.g31d1f125-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded pacman (5.2.2-3 -> 5.2.2-4)
[2021-03-05T18:58:53+0100] [ALPM] upgraded perl-http-message (6.27-1 -> 6.28-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-mesa (20.3.4-1 -> 20.3.4-2)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-mesa-vdpau (20.3.4-1 -> 20.3.4-2)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-nss (3.61-1 -> 3.62-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-pango (1:1.48.1-1 -> 1:1.48.2-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.166-1 -> 1.2.169-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-vulkan-intel (20.3.4-1 -> 20.3.4-2)
[2021-03-05T18:58:53+0100] [ALPM] upgraded lib32-vulkan-radeon (20.3.4-1 -> 20.3.4-2)
[2021-03-05T18:58:53+0100] [ALPM] upgraded libburn (1.5.2-2 -> 1.5.4-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded libgexiv2 (0.12.1-4 -> 0.12.2-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded libgphoto2 (2.5.26-1 -> 2.5.27-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded libmm-glib (1.14.10-1 -> 1.16.0-1)
[2021-03-05T18:58:53+0100] [ALPM] upgraded libnm (1.28.1dev+16+gdaad4e2fee-1 -> 1.30.0-1)
[2021-03-05T18:58:54+0100] [ALPM] upgraded osinfo-db (20201015-1 -> 20210202-1)
[2021-03-05T18:58:54+0100] [ALPM] upgraded libosinfo (1.8.0-1 -> 1.9.0-1)
[2021-03-05T18:58:54+0100] [ALPM] installed libqrtr-glib (1.0.0-1)
[2021-03-05T18:58:54+0100] [ALPM] upgraded libqmi (1.26.8-1 -> 1.28.0-1)
[2021-03-05T18:58:54+0100] [ALPM] upgraded libupnp (1.14.0-1 -> 1.14.1-1)
[2021-03-05T18:58:54+0100] [ALPM] upgraded libva-mesa-driver (20.3.4-1 -> 20.3.4-3)
[2021-03-05T18:58:55+0100] [ALPM] upgraded libvirt (1:7.0.0-2 -> 1:7.0.0-3)
[2021-03-05T18:58:55+0100] [ALPM] upgraded linux-firmware (20210119.r1813.0578970-1 -> 20210211.r1830.f7915a0-1)
[2021-03-05T18:58:56+0100] [ALPM] upgraded linux419 (4.19.173-1 -> 4.19.177-1)
[2021-03-05T18:58:58+0100] [ALPM] upgraded linux419-headers (4.19.173-1 -> 4.19.177-1)
[2021-03-05T18:58:58+0100] [ALPM] upgraded linux419-nvidia (460.39-4 -> 460.39-8)
[2021-03-05T18:59:02+0100] [ALPM] upgraded linux419-virtualbox-host-modules (6.1.18-5 -> 6.1.18-9)
[2021-03-05T18:59:07+0100] [ALPM] upgraded linux54 (5.4.95-1 -> 5.4.100-1)
[2021-03-05T18:59:09+0100] [ALPM] upgraded linux54-headers (5.4.95-1 -> 5.4.100-1)
[2021-03-05T18:59:09+0100] [ALPM] upgraded linux54-nvidia (460.39-4 -> 460.39-9)
[2021-03-05T18:59:13+0100] [ALPM] upgraded linux54-virtualbox-host-modules (6.1.18-5 -> 6.1.18-10)
[2021-03-05T18:59:18+0100] [ALPM] upgraded man-db (2.9.3-1 -> 2.9.4-1)
[2021-03-05T18:59:18+0100] [ALPM] upgraded mariadb-libs (10.5.8-1 -> 10.5.9-1)
[2021-03-05T18:59:18+0100] [ALPM] upgraded mariadb-clients (10.5.8-1 -> 10.5.9-1)
[2021-03-05T18:59:18+0100] [ALPM] upgraded mariadb (10.5.8-1 -> 10.5.9-1)
[2021-03-05T18:59:18+0100] [ALPM] upgraded mesa-vdpau (20.3.4-1 -> 20.3.4-3)
[2021-03-05T18:59:18+0100] [ALPM] upgraded modemmanager (1.14.10-1 -> 1.16.0-1)
[2021-03-05T18:59:18+0100] [ALPM] upgraded modemmanager-qt (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:59:18+0100] [ALPM] upgraded mpd (0.22.4-2 -> 0.22.6-1)
[2021-03-05T18:59:18+0100] [ALPM] upgraded wpa_supplicant (2:2.9-7 -> 2:2.9-8)
[2021-03-05T18:59:19+0100] [ALPM] upgraded networkmanager (1.28.1dev+16+gdaad4e2fee-1 -> 1.30.0-1)
[2021-03-05T18:59:19+0100] [ALPM] upgraded networkmanager-qt (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:59:19+0100] [ALPM] upgraded nfsidmap (2.5.2-2 -> 2.5.2-3)
[2021-03-05T18:59:19+0100] [ALPM] upgraded nfs-utils (2.5.2-2 -> 2.5.2-3)
[2021-03-05T18:59:19+0100] [ALPM] upgraded nodejs (15.8.0-1 -> 15.10.0-1)
[2021-03-05T18:59:19+0100] [ALPM] upgraded openexr (2.5.4-1 -> 2.5.5-1)
[2021-03-05T18:59:19+0100] [ALPM] upgraded openjdk8-doc (8.u275-1 -> 8.u282-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded openjdk8-src (8.u275-1 -> 8.u282-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded oxygen (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded oxygen-icons (1:5.78.0-1 -> 1:5.79.0-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded vte-common (0.62.2-1 -> 0.62.3-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded vte3 (0.62.2-1 -> 0.62.3-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded pamac-common (10.0.4-2 -> 10.0.4-3.1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded pamac-cli (10.0.4-2 -> 10.0.4-3.1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded xdg-desktop-portal-kde (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded pamac-flatpak-plugin (10.0.4-2 -> 10.0.4-3.1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded pamac-gtk (10.0.4-2 -> 10.0.4-3.1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded snapd (2.48.2-1 -> 2.49-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded pamac-snap-plugin (10.0.4-2 -> 10.0.4-3.1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded perl-path-tiny (0.114-1 -> 0.118-1)
[2021-03-05T18:59:20+0100] [ALPM] upgraded polkit-kde-agent (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded plasma-desktop (5.20.5-2 -> 5.21.1-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded plasma-nm (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded plasma-pa (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded plasma-workspace-wallpapers (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded postgresql-libs (13.1-3 -> 13.2-1)
[2021-03-05T18:59:21+0100] [ALPM] installed ddcutil (1.0.1-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded powerdevil (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded psmisc (23.3-4 -> 23.4-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded purpose (5.78.0-1 -> 5.79.0-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded python-shiboken2 (5.15.2-4 -> 5.15.2-6)
[2021-03-05T18:59:21+0100] [ALPM] upgraded pyside2 (5.15.2-2 -> 5.15.2-3)
[2021-03-05T18:59:21+0100] [ALPM] upgraded python-pygments (2.7.4-1 -> 2.8.0-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded python-tabulate (0.8.7-3 -> 0.8.8-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded qemu (5.2.0-2 -> 5.2.0-3)
[2021-03-05T18:59:21+0100] [ALPM] upgraded qpdf (10.1.0-1 -> 10.2.0-1)
[2021-03-05T18:59:21+0100] [ALPM] upgraded qt5-tools (5.15.2-2 -> 5.15.2-3)
[2021-03-05T18:59:21+0100] [ALPM] warning: /etc/sane.d/canon_lide70.conf installed as /etc/sane.d/canon_lide70.conf.pacnew
[2021-03-05T18:59:22+0100] [ALPM] warning: /etc/sane.d/escl.conf installed as /etc/sane.d/escl.conf.pacnew
[2021-03-05T18:59:22+0100] [ALPM] upgraded sane (1.0.31-3 -> 1.0.32-3)
[2021-03-05T18:59:22+0100] [ALPM] upgraded sddm-kcm (5.20.5-1 -> 5.21.1-1)
[2021-03-05T18:59:22+0100] [ALPM] upgraded spectacle (20.12.2-1 -> 20.12.2-2)
[2021-03-05T18:59:22+0100] [ALPM] upgraded spirv-tools (2020.4-1 -> 2020.6-1)
[2021-03-05T18:59:22+0100] [ALPM] upgraded telegram-desktop (2.5.8.r48.g9b70f24e9-1 -> 2.6.0-1)
[2021-03-05T18:59:22+0100] [ALPM] upgraded thunderbird (78.7.1-0.3 -> 78.8.0-0.3)
[2021-03-05T18:59:22+0100] [ALPM] upgraded tlpui (1.3.1.7-1 -> 1.3.1.8-1)
[2021-03-05T18:59:22+0100] [ALPM] upgraded virtualbox (6.1.18-1 -> 6.1.18-2)
[2021-03-05T18:59:22+0100] [ALPM] upgraded vulkan-intel (20.3.4-1 -> 20.3.4-3)
[2021-03-05T18:59:22+0100] [ALPM] upgraded vulkan-radeon (20.3.4-1 -> 20.3.4-3)
[2021-03-05T18:59:23+0100] [ALPM] upgraded webkit2gtk (2.30.4-3 -> 2.30.5-1)
[2021-03-05T18:59:23+0100] [ALPM] upgraded wine-staging (6.1-1 -> 6.2-1)
[2021-03-05T18:59:23+0100] [ALPM] upgraded wireless-regdb (2020.04.29-1 -> 2020.11.20-1)
[2021-03-05T18:59:23+0100] [ALPM] installed python-websockets (8.1-3)
[2021-03-05T18:59:23+0100] [ALPM] installed python-h11 (0.12.0-1)
[2021-03-05T18:59:23+0100] [ALPM] installed python-aiofiles (0.6.0-3)
[2021-03-05T18:59:23+0100] [ALPM] installed python-httptools (0.1.1-4)
[2021-03-05T18:59:23+0100] [ALPM] installed python-uvloop (0.15.1-1)
[2021-03-05T18:59:23+0100] [ALPM] installed python-wsproto (1.0.0-1)
[2021-03-05T18:59:23+0100] [ALPM] installed uvicorn (0.13.3-1)
[2021-03-05T18:59:23+0100] [ALPM] installed python-starlette (0.13.8-3)
[2021-03-05T19:00:43+0100] [ALPM] installed python-json-rpc (1.13.0-1)
[2021-03-05T19:00:43+0100] [ALPM] upgraded google-chrome (88.0.4324.150-1 -> 89.0.4389.72-1)
[2021-03-05T19:01:11+0100] [ALPM] upgraded platformio (5.1.0-2 -> 5.1.0-3)
[2021-03-05T19:01:12+0100] [ALPM] upgraded visual-studio-code-bin (1.53.1-1 -> 1.54.1-1)
Journalctl after update → do_IRQ errors are already there since the first system installation
-- Journal begins at Fri 2020-08-21 20:19:02 CEST, ends at Sat 2021-03-06 11:32:43 CET. --
Mär 05 23:10:48 Polly kernel: do_IRQ: 1.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 2.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 3.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 4.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 5.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 6.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 7.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 8.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 9.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: do_IRQ: 10.55 No irq handler for vector
Mär 05 23:10:48 Polly kernel: proc: Bad value for 'hidepid'
Mär 05 23:10:49 Polly kernel: proc: Bad value for 'hidepid'
Mär 05 23:10:52 Polly libvirtd[950]: nl_recv returned with error: No buffer space available
Mär 05 23:10:55 Polly nmbd[1452]: [2021/03/05 23:10:55.311809, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
Mär 05 23:10:55 Polly nmbd[1452]: daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Mär 05 23:10:55 Polly smbd[1466]: [2021/03/05 23:10:55.430136, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
Mär 05 23:10:55 Polly smbd[1466]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Mär 05 23:10:59 Polly systemd[1]: Failed to start TLP system startup/shutdown.
Mär 05 23:11:18 Polly nmbd[1452]: [2021/03/05 23:11:18.339775, 0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Mär 05 23:11:18 Polly nmbd[1452]: *****
Mär 05 23:11:18 Polly nmbd[1452]: Samba name server POLLY is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.76
Mär 05 23:11:22 Polly agetty[2142]: tty2: invalid character 0x1b in login name
Mär 05 23:15:50 Polly [2324]: /usr/lib/systemd/system-sleep/tlp failed with exit status 1.
Mär 06 11:22:44 Polly [2484]: /usr/lib/systemd/system-sleep/tlp failed with exit status 1.
Mär 06 11:23:06 Polly nmbd[1452]: [2021/03/06 11:23:06.513657, 0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Mär 06 11:23:06 Polly nmbd[1452]: *****
Mär 06 11:23:06 Polly nmbd[1452]: Samba name server POLLY is now a local master browser for workgroup WORKGROUP on subnet 172.19.0.1
Mär 06 11:23:06 Polly nmbd[1452]: [2021/03/06 11:23:06.513766, 0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Mär 06 11:23:06 Polly nmbd[1452]: Samba name server POLLY is now a local master browser for workgroup WORKGROUP on subnet 172.17.0.1
Mär 06 11:28:17 Polly nmbd[1452]: [2021/03/06 11:28:17.955484, 0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Mär 06 11:28:17 Polly nmbd[1452]: *****
Mär 06 11:28:17 Polly nmbd[1452]: Samba name server POLLY is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.111
