gegham
March 4, 2023, 2:25pm
1
My system is slow and lagging sometimes.
Lagging happens when I use chrome or firefox, vs code or webstorm, have multiple http servers running or running unit tests (100+) at the same time. Also, I have docker installed and usually during work I have minimum 2 containers running. Usually when system starts lagging it kills webstorm, vs code and chrome processes.
Previously I was using ubuntu and never had problem with the same workload.
I think problem is related to GPUs and drivers but not sure.
System info:
memory: 16.0 GiB
cpu: Intel® Core™ i7-10750H × 12
gpu: Mesa Intel® UHD Graphics (CML GT2), NVIDIA GeForce RTX 3060 Laptop GPU
disk: SSD 512.1 GB
OS build ID: rolling
Kernel: linux61
Gnome version: 43.3
Windowing system: X11
sudo inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d65156d0-e65e-40b9-85ef-3d1d60dbf387 rw nouveau.modeset=0 quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Acer product: Predator PH315-53 v: V2.00
serial: <filter>
Mobo: CML model: QX50_CMS v: V2.00 serial: <filter> UEFI: Insyde v: 2.00
date: 01/08/2021
RAM: total: 15.46 GiB used: 4.96 GiB (32.1%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1.2 min: 1.35 max: 1.35
width (bits): data: 64 total: 64 manufacturer: Micron
part-no: 8ATF1G64HZ-3G2J1 serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
Info: model: Intel Core i7-10750H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2588 high: 2801 min/max: 800/5000 base/boost: 2574/8300
scaling: driver: intel_pstate governor: powersave volts: 0.8 V
ext-clock: 100 MHz cores: 1: 2725 2: 2600 3: 2801 4: 2600 5: 2000 6: 2800
7: 2532 8: 2600 9: 2600 10: 2600 11: 2600 12: 2600 bogomips: 62431
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2520
class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
Display: server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x08b3 built: 2019 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 398mm (15.7")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Local Storage: total: 476.94 GiB used: 40.04 GiB (8.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
rev: 11101100 temp: 24.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 40.04 GiB (8.6%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: d65156d0-e65e-40b9-85ef-3d1d60dbf387
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 7A81-0D03
p.s. when lagging happens, it does not seem that CPU, GPU, RAM utilization is very high (I monitor using nvtop)
gegham
March 4, 2023, 2:33pm
2
my linux/arch knowledge is not advanced and idk how to approach these kind of issues. I am just a backend dev. Would appreciate if you can advice how to debug and understand what causing the issue.
Thanks
Dump question, but do you have a swapfile/partition? That kinda happens when your ram is full and oomd decides to kill some applications for stability reasons.
Maybe you had a swapfile?
maybe the first line of argument after all others are extinguished is checking if manjaro vs. ubuntu have different default priorities on processes.
Having something at 0 or -20 can make all the difference. Especially when under load.
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information.
[HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi
in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading )
gegham
March 4, 2023, 10:19pm
6
actually idk, how to check that?
gegham
March 4, 2023, 10:24pm
8
I’m not using dual system, just Manjaro
qruqs
March 4, 2023, 10:29pm
10
…or
$ lsblk
“There’s more than one way to skin a cat.”
@gegham Please don’t be lazy and use copy&paste for terminal outputs. Markdown is supported here. thanks
So there is no swap as expected. If your system is running at full load, then it needs a swap. Maybe have look at systemd-swap
which dynamically creates and activates swap files if needed.
gegham
March 4, 2023, 10:51pm
12
@megavolt sure it’s not hard for me to do that. will start systemd-swap
deamon. Thanks.
gegham
March 4, 2023, 10:54pm
13
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 55.6M 1 loop /var/lib/snapd/snap/core18/2697
loop1 7:1 0 116.8M 1 loop /var/lib/snapd/snap/core/14784
loop2 7:2 0 65.1M 1 loop /var/lib/snapd/snap/sublime-text/116
loop3 7:3 0 63.3M 1 loop /var/lib/snapd/snap/core20/1822
loop4 7:4 0 49.8M 1 loop /var/lib/snapd/snap/snapd/18357
loop5 7:5 0 198.1M 1 loop /var/lib/snapd/snap/postman/196
loop6 7:6 0 605.5M 1 loop /var/lib/snapd/snap/webstorm/298
loop7 7:7 0 4K 1 loop /var/lib/snapd/snap/bare/5
loop8 7:8 0 91.7M 1 loop /var/lib/snapd/snap/gtk-common-themes/1535
loop9 7:9 0 68.7M 1 loop /var/lib/snapd/snap/notion-snap/16
loop10 7:10 0 164.8M 1 loop /var/lib/snapd/snap/gnome-3-28-1804/161
nvme0n1 259:0 0 476.9G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
└─nvme0n1p2 259:2 0 476.6G 0 part /
gegham
March 4, 2023, 10:59pm
14
@megavolt I followed this guide and configured systemd-swap
. Will let you know about the results.
Thanks man.
gegham
March 6, 2023, 9:30am
15
@megavolt Swap file is created but the issue still exists
swapon --show
NAME TYPE SIZE USED PRIO
/var/lib/systemd-swap/swapfc/1 file 256M 0B 50
df -h ✔
Filesystem Size Used Avail Use% Mounted on
dev 7.8G 0 7.8G 0% /dev
run 7.8G 2.2M 7.8G 1% /run
/dev/nvme0n1p2 469G 42G 404G 10% /
tmpfs 7.8G 87M 7.7G 2% /dev/shm
tmpfs 7.8G 43M 7.7G 1% /tmp
/dev/loop0 128K 128K 0 100% /var/lib/snapd/snap/bare/5
/dev/loop5 56M 56M 0 100% /var/lib/snapd/snap/core18/2697
/dev/loop4 69M 69M 0 100% /var/lib/snapd/snap/notion-snap/16
/dev/loop9 50M 50M 0 100% /var/lib/snapd/snap/snapd/18357
/dev/loop2 165M 165M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
/dev/loop1 92M 92M 0 100% /var/lib/snapd/snap/gtk-common-themes/1535
/dev/loop6 199M 199M 0 100% /var/lib/snapd/snap/postman/196
/dev/loop7 64M 64M 0 100% /var/lib/snapd/snap/core20/1822
/dev/loop3 117M 117M 0 100% /var/lib/snapd/snap/core/14784
/dev/loop10 606M 606M 0 100% /var/lib/snapd/snap/webstorm/298
/dev/loop8 198M 198M 0 100% /var/lib/snapd/snap/postman/197
/dev/loop11 66M 66M 0 100% /var/lib/snapd/snap/sublime-text/116
/dev/nvme0n1p1 300M 312K 300M 1% /boot/efi
tmpfs 1.6G 124K 1.6G 1% /run/user/1000
@gegham So if swapping wasn’t the issue, see what @varikonniemi has already said about priorities. It could be perfectly legitimate for a process to have a high priority and make the lower priority applications wait a long time and causing it to crash.
I cannot say what the difference between Ubuntu and Manjaro is, but at least it must be the default kernel version, which is, when I remember correctly, version 5.15. You run v6.1.
Also check with iotop
or iotop-c
if the Input/Output performance let it crash.
There are tools like nice
, renice
or ionice
which can adjust the priorities to your needs. Docker has its own parameters for that.
Maybe, I am not sure, it could be also a snap issue. While you can run snaps on Manjaro, it is not optimized for that. Snaps are generally optimized and tested for Ubuntu and for sure, it has always a delay when computing.
You can replace sublime-text
, postman
, webstorm
with Flatpaks or just install it natively from the official repo or the AUR.
Get rid of the snaps - each end every one.
Then disable snap.
postman can be build from AUR using
pamac build postman-bin
sublime-text has their own repo you install from
curl -O https://download.sublimetext.com/sublimehq-pub.gpg && sudo pacman-key --add sublimehq-pub.gpg && sudo pacman-key --lsign-key 8A8F901A && rm sublimehq-pub.gpg
echo -e "\n[sublime-text]\nServer = https://download.sublimetext.com/arch/stable/x86_64" | sudo tee -a /etc/pacman.conf
sudo pacman -Syu sublime-text
Webstorm can be setup to run in your home
curl -O https://download.jetbrains.com/webstorm/WebStorm-2022.3.2.tar.gz
tar -xf WebStorm-2022.3.2.tar.gz
./WebStorm-223.8617.44/bin/.webstorm.sh
gegham
March 6, 2023, 8:06pm
18
@megavolt @linux-aarhus thanks for answers. I removed all snap apps and also removed snapd
itself.
Will let you know if it solves the problem. Thanks!
with systemd snap and flatpak linux is quickly becoming a mess similar to windows, with huge effort going into working around complex configuration and problems arising from containerization
gegham
March 7, 2023, 10:09am
20
seems removing snaps solved the problem… I have been working with the same workload for couple of hours and didn’t experience any lagging. Thank you all!
