A. “Introduction”.
Hello everybody! I’m pretty new to using Linux systems and my knowledge of this topic is not very good yet. I am trying to install Manjaro KDE Plasma Edition version 21.0.2 from a USB 2.0 stick in UEFI mode, which was burned with belenaEtcher v1.5.117 on Windows 10 Enterprise LTSC x64 (SHA1 hash and GPG signature of ISO file are correct and were verified by me). I want to manually create the required for Manjaro installation disk partitions and, if possible, manually encrypt the future “root” partition with some custom encryption options.
B. “Disk Partitioning”.
For this purpose, I booted into a live system on USB flash drive in UEFI mode and installed “gparted” via Console:
sudo pacman -Sy gparted
In gparted I created:
- 512 MiB GPT disk partition with the FAT32 file system and assigned “boot” and “esp” flags to it, label “EFI”, for Grub bootloader;
- 256 GiB GPT disk partition with the BTRFS file system, label “Manjaro”, for Manjaro installation.
In my disks configuration EFI partition is /dev/sdb3
and Manjaro partition is /dev/sdb4
C. “Encryption”.
After that, I ran the following commands via Console to encrypt Manjaro partition with some custom options and create BTRFS file system:
sudo cryptsetup luksFormat --type luks1 -c aes-xts-plain64 --key-size 512 --hash whirlpool --iter-time 10000 --use-urandom /dev/sdb4
#Encrypts /dev/sdb4
to LUKS1 partition with aes-xts chiper, 512b key size and Whirlpool hash algorithm;
sudo cryptsetup open /dev/sdb4 Manjaro
#Opens encrypted LUKS1 partition /dev/sdb4
sudo mkfs.btrfs /dev/mapper/Manjaro
#Creates BTRFS file system inside encrypted LUKS1 partition /dev/sdb4
And now I want to install the system via Calamares v3.2.37-1, but I don’t know how to do it.
D. “Installation”.
I) In the first case, when LUKS partition is opened via Console, Calamares sees BTRFS partition in /dev/sdb4
- exactly the partition where I want to install Manjaro.
In Calamares I’m using “Manual Partitioning” option and assign following Mountpoints to my partitions:
/boot/efi
fordev/sdb3
(as recommended in Manjaro User Guide); -
fordev/sdb4
After completing the setup configuration and proceeding to the system installation (pressing “Install” button in latest overview dashboard where changes not yet applied), almost instantly, I got error message:
Boost.Python error in job "mount". Command '['btrfs', 'subvolume', 'create', '/tmp/calamares-root-opi6ewy8/@']' returned non-zero exit status 1. None.
After pressing “OK” button Calamares closes without completing the installation, and LUKS partition closes too.
II) In the second case, when LUKS partition is not opened via Console, Calamares sees LUKS partition in /dev/sdb4
, but not BTRFS file system - this is logical, but I’m not sure if the installation can be continued this way, because the partition is encrypted (I have not tried this).
E. “Conclusion”.
All described above has led me to a dead end and I do not know what to do. Please, explain to me what I must do to achieve the described goals, maybe in some other way than that I tried to do it. Thank you so much if you have read up to this point! I will be very grateful for any help in solving my problem. If you want to help me, please try to describe everything in as simple and understandable language as possible (I’m very new to Linux). I understand English and Russian languages, here is my Telegram username, in case if it is more convenient for you to write to me in it: @hotcapy.
F. “The Purpose”.
I want to install Manjaro Linux to BTRFS file system inside encrypted LUKS1 partition with aes-xts-plain64 chiper, 512b key size, Whirlpool hash algorithm and the number of iterations corresponding ~10 seconds passphrase decrypt time.
