Hi!
According to the following thread @Yochanan dropped the package i3status-manjaro
from the repos.
i3status
should be installed in order to replace i3status-manjaro
This can’t be done because the package manjaro-i3-settings
(in the extra
repo) still depends on i3status-manjaro
$ pacman -Qi i3status-manjaro | grep -i "required"
Required By : manjaro-i3-settings
and
$ pacman -Qi manjaro-i3-settings | grep -i "depends"
Depends On : adapta-maia-theme conky-i3 dmenu-manjaro dunst gsfonts i3-default-artwork i3exit i3-scripts i3-scrot i3-gaps i3-help i3status-manjaro manjaro-base-skel ttf-terminus-nerd nitrogen papirus-maia-icon-theme picom urxvt-perls xcursor-breeze xorg-fonts-misc xorg-mkfontscale
manjaro-i3-settings
should be also updated to not include i3status-manjaro
as a dependency.
Thanks in advance!
