Manjaro is a bit slow for me. Especially when I use brave, on youtube videos it gets choppy. In visual studio when I write it goes slow. What I can do?
inxi -Fza :
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=c60dcd42-54e9-48f8-9358-1f314c41043b ro quiet apparmor=1
security=apparmor resume=UUID=24a6f42d-81d5-4841-bab0-d1c143e72686
udev.log_priority=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TOSHIBA product: Satellite S845 v: PSKF6P-002001
serial: <filter>
Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1
v: Type2 - Board Version serial: <filter> UEFI-[Legacy]: Insyde
v: 6.30 date: 10/31/2012
ID-1: BAT1 charge: 10.1 Wh (45.9%) condition: 22.0/47.5 Wh (46.3%)
volts: 10.4 min: 10.8 model: LGC PA5024U-1BRS type: Li-ion serial: N/A
status: Discharging cycles: 221
Info: Single Core model: Intel Core i5-3210M bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 4990
Speed: 2494 MHz min/max: 1200/2500 MHz Core speed (MHz): 1: 2494
Type: l1tf
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, RSB filling
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Toshiba
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166
class-ID: 0300
Device-2: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 04f2:b307 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 112
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Toshiba driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.22 running: no
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 3040 bus-ID: 02:00.0
chip-ID: 168c:0032 class-ID: 0280
Device-2: Qualcomm Atheros AR8152 v2.0 Fast Ethernet vendor: Toshiba
driver: atl1c v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 1969:2062
class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 223.57 GiB used: 53.25 GiB (23.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0010 scheme: MBR
ID-1: / raw-size: 215.34 GiB size: 210.96 GiB (97.97%)
used: 53.23 GiB (25.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.23 GiB used: 22 MiB (0.3%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 177 Uptime: 11m wakeups: 1 Memory: 3.75 GiB
used: 1.67 GiB (44.5%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1368 pacman: 1351 lib: 407 flatpak: 0 snap: 17
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.02 ```
