Hello everyone. I’m trying to boot the official Manjaro GNOME for ARM 21.06 image on a Raspberry Pi 4 Model B 8GB, made by Raspberry Pi Imager, but after the first Manjaro logo screen, all hardware / monitor activity suddenly ceases with only a command prompt cursor blinking. I tried 3 different SD cards and 3 different USB-C AC power adaptors to eliminate some common issues with Raspberry Pi’s before coming here, as well as waited 30 minutes for the initial boot to start, just in case.
I don’t know whether I’m supposed to post a journal output, but there’s literally nothing I can do or type after the boot hangs. I’m really new to Linux / Raspberry Pi, so any suggestions would be graciously appreciated. Thank you!
I can’t even make it to the initial setup screen. Right after the very first Manjaro logo screen with the loading circle under it, the screen goes black and hangs on a blinking cursor…
Seems there have been some issues with earlier builds of the 21.06 for RPi4… MANJARO Arm , No First Boot - #4 by Darksky. could you please check if you use the latest version of the image (uploaded some days ago)
I haven’t tried any other OS yet, I’ll give it a shot if I see there’s no other way to solve this… Even though that makes me think, my Raspberry Pi 4 came bundled with an SD card w/ NOOBS in it, so this could be an older RP model?
Depending on what pi bundle you order the Noobs and sdcard come with some bundles. Most likely if you just received the pi4 the eeprom should boot with usb boot. The other firmware in the boot partition is the latest in the stable branch so should be good.
I downloaded the Gnome image and it appears to be have issues with loading GDM on the first boot. @Strit / @appelgriebsch I was able to get to the terminal and login as root and looked at journalctl:
looks like it tries to read a boolean value from the config file, but got some unexpected input instead… will have to verify the autostart configuration that got introduced for the new calamares OEM installer
Thank you and Darksky for taking a look at this… if I understand correctly, is this a bug on the existing image? Is this something I have to fix manually or do we have to wait for a new revision of the image to be compiled and published? Thanks again fellas, I really appreciate all your help.
EDIT: (also, I have no idea how to disable TTY mode now!)
