Back then it’s plug and play and it detect correct monitor and calibrate in correct monitor.
I’m not sure since when, I haven’t been drawing for awhile. But probably It’s after the last stable update because few weeks ago I remember I can still draw because it’s still mapped to the correct monitor
BUT
it might be since the second last stable update because few weeks ago, while the setting is still mapped to correct monitor, I cannot map it to other monitor and calibration is actually shown on wrong monitor.
the problem now that, it’s mapped to all of my monitors. So if I put my pen in the middle of the screen, it will be either in the bottom of my first monitor or on top of second monitor.
And when I want to set it up, these things happened:
Wrong calibrated monitor
I have 3 monitor in my laptop. Built in, external (dell) then wacom one.
First time I did calibration with similar setup it works fine, the calibration sceen appeared in wacom monitor. But now if I did it, the calibration only show in external dell monitor.
But I think maybe it’s because I set primary monitor to my dell monitor. So I tried to change my primary monitor to my wacom one (no pun intended). And it’s somehow still only appeared in my dell monitor.
WHYYYYYY -
Cannot map to monitor.
When I tried to map to monitor, It’s always grey. I cannot click anything. Cannot choose output. The only thing I can click in that popup window is Close button
hmm what’s the next thing I could try?
UPDATE:
Okay, I restart the laptop. Now the calibration is appeared in correct monitor, BUT I STILL CANNOT CALIBRATE because it’s still mapped to BOTH of my monitors. If i tap the correct spot in my tablet, it will click outside the calibration screen because it’s calibrated to two monitors.
I wonder why is the map to single monitor checkbox is grey and unclickable @.@
Other people bug:
I found this: Cannot map Wacom tablet to single display via GNOME settings (#1476) · Issues · GNOME / mutter · GitLab
It sounds similar but it seems like he is able to check the map to single monitor while I cannot.
here is when I tried to use solution in there:
xsetwacom set 13 MapToOutput DP-1 Sab 07 Nov 2020 09:06:18
Unable to find an output 'DP-1'.
~ xsetwacom set 13 MapToOutput 1920x1080+0+0 Sab 07 Nov 2020 09:06:21
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 131 (XInputExtension)
Minor opcode of failed request: 37 (X_ChangeDeviceProperty)
Serial number of failed request: 19
Current serial number in output stream: 22
hmm maybe it’s hdmi-2
! ~ xsetwacom set 13 MapToOutput HDMI-2 Sab 07 Nov 2020 09:06:26
Unable to find an output 'HDMI-2'.
~ xsetwacom set 13 MapToOutput 1920x1080+0+1080 Sab 07 Nov 2020 09:10:04
this is the output of xsetwacom --list-devices and xrandr
~ xsetwacom --list devices Sab 07 Nov 2020 09:03:44
Wacom One Pen Display 13 Pen stylus id: 17 type: STYLUS
Wacom One Pen Display 13 Pen eraser id: 18 type: ERASER
~ xrandr Sab 07 Nov 2020 09:04:06
Screen 0: minimum 320 x 200, current 1920 x 2160, maximum 16384 x 16384
eDP-1 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+
1600x900 60.00
1280x1024 75.02 60.02
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
640x480 75.00 59.94
720x400 70.08
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 connected 1920x1080+0+1080 (normal left inverted right x axis y axis) 294mm x 166mm
1920x1080 60.00*+ 59.94
1600x1200 60.00
1280x1024 60.02
1280x720 60.00 59.94
1024x768 60.00
800x600 60.32
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
