Prime-run from terminal is working fine. So i decided to install the this switcheroo-control.
I did right click from the application launcher but no option there like switch the gpus.
I’m just guessing that you have to reboot the system after installing it. Did you?
yeah i did still not showing
Have you tried to contact the developer Bastien Nocera / switcheroo-control · GitLab
File an issue. They clearly state they tested it on MacBook Pro (8,2) and Thinkpad T430s. What is your hardware. Make sure you share inxi -Fazy
and mhwd -li
Also you can open Issues · Bastien Nocera / switcheroo-control · GitLab and ask for more assistance.
inxi -Fazy
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=891f8736-3b80-49a6-b6bb-1b93bfe8afd2 rw rootflags=subvol=@ quiet
cryptdevice=UUID=38b217b0-d4c3-4c74-a64c-a5abeda1acb4:luks-38b217b0-d4c3-4c74-a64c-a5abeda1acb4
root=/dev/mapper/luks-38b217b0-d4c3-4c74-a64c-a5abeda1acb4 splash apparmor=1
security=apparmor
resume=/dev/mapper/luks-bbe98d8d-4ae8-4702-a451-68636aec59a8
udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512FL_X512FL
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X512FL v: 1.0 serial: <filter>
UEFI: American Megatrends v: X512FL.303 date: 08/26/2019
ID-1: BAT0 charge: 29.3 Wh (100.0%) condition: 29.3/37.1 Wh (78.9%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 299
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 6 MiB
bogomips: 28808
Speed: 700 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 700 2: 700 3: 732
4: 655 5: 600 6: 688 7: 600 8: 654
Type: srbds mitigation: TSX disabled
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
chip-ID: 10de:1d13 class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:56d3 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 462.05 GiB used: 45.12 GiB (9.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3256GJ3
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: E8FK11.T temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 052 scheme: GPT
ID-1: / raw-size: 225.47 GiB size: 225.47 GiB (100.00%)
used: 45.12 GiB (20.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-38b217b0-d4c3-4c74-a64c-a5abeda1acb4
used: 712 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 225.47 GiB size: 225.47 GiB (100.00%)
ID-4: /var/log raw-size: 225.47 GiB size: 225.47 GiB (100.00%)
ID-1: swap-1 type: partition size: 12.7 GiB used: 768 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-bbe98d8d-4ae8-4702-a451-68636aec59a8
System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
Processes: 302 Uptime: 1h 31m wakeups: 1 Memory: 11.55 GiB
used: 2.14 GiB (18.5%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1294 lib: 408 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.06
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2021.07.28 false PCI
Checking the list of iGPU ID, makes me think that yours in not there data/30-pci-intel-gpu.hwdb · master · Bastien Nocera / switcheroo-control
So, you can contact the developer and ask for assistance in that regard.
yeah my igpu is there, Intel UHD 620.(check at line number 758)
well thanks for your time, i fixed it by these two commands.
systemctl start switcheroo-control.service```
systemctl enable switcheroo-control.service
