I’m running Manjaro and Windows 10 dual boot from an SSD and also have a HDD for storage. Its on an HP laptop with integrated graphics. I’m getting this error on shutdown, which the computer freezes and i have to shutdown by hard pressing the power button.
This happens around 10% of the times normally but when I don’t wait for 60 seconds to finish while turning off and click on power off again, it happens almost every time.
I’m not able to upload picture here, but the code says
Failed to unmount /oldroot
Failed to unmount /oldroot/dev/pts
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=791aff02-67f3-45ce-97c6-9b71024bcb30 rw apparmor=1
security=apparmor resume=UUID=dcc97cbf-9f1e-42f4-87fe-80f5c831181c
udev.log_priority=3
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: HP 15 Notebook PC
v: 0976100000405F10000610180 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Hewlett-Packard model: 218F v: 39.15 serial: <filter> UEFI: Insyde
v: F.0C date: 01/08/2013
ID-1: BAT0 charge: 14.9 Wh condition: 20.7/20.7 Wh (100%) volts: 17.1/14.8
model: HP type: Li-ion serial: N/A status: Charging
Info: Dual Core model: Intel Core i3-3110M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19166
Speed: 2395 MHz min/max: 1200/2400 MHz Core speeds (MHz): 1: 2395 2: 2395
3: 2395 4: 2395
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Realtek HP Truevision HD integrated webcam type: USB
driver: uvcvideo bus ID: 2-3:2 chip ID: 0bda:5776 serial: <filter>
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: i915
note: display driver n/a - try sudo/root display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1e20
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus ID: 01:00.0 chip ID: 10ec:8136
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Hewlett-Packard driver: ath9k v: kernel port: 3000 bus ID: 02:00.0
chip ID: 168c:0036
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 2-4:4
chip ID: 0cf3:3121
Local Storage: total: 577.55 GiB used: 55.69 GiB (9.6%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 2C scheme: GPT
ID-2: /dev/sdb vendor: Crucial model: CT120BX500SSD1 size: 111.79 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: R013 scheme: GPT
ID-1: / raw size: 32.67 GiB size: 31.91 GiB (97.66%) used: 8.24 GiB (25.8%)
fs: ext4 dev: /dev/sdb5
ID-1: swap-1 type: partition size: 1.95 GiB used: 1.2 MiB (0.1%)
priority: -2 dev: /dev/sdb4
System Temperatures: cpu: 66.0 C mobo: N/A
Processes: 205 Uptime: 1h 41m Memory: 3.74 GiB used: 1.57 GiB (42.0%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1184 lib: 329
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.08
