Manjaro Gnome 20.2 Installer incomplete
Hello everyone!!
I have this problem trying to install Manjaro; I do not see the options to create user, language, region, etc.
(The editor of the post does not let me attach images)
I do it from a usb pendrive, I use the universal usb installer, the same thing appears to me when using the full ISO or the minimal one, it is not the case with the KDE ISO.
Am I doing something wrong or …?
I read them, a hug!
What is this?
The installer on Manjaro is Calamares - or the Architect bash script.
Manjaro has a couple of proven concepts to create bootable USB sticks
The Manjaro Gnome Edition uses now a so called “OEM style installation”.
Which means you do this after install and reboot with “gnome-initial-setup”. The setup is started automatically.
Universal USB Installer is Linux USB flash drive creation software, works only on Windows.
I will try the other options that appear in the post, thanks.
Apparently the setup I have creates a conflict between my GTX 760, Cuda 11 and Gnome. After installing with or without the Nvidia drivers, it starts with a black screen, when I access the command lines, it asks me for a user and pass that does not exist
I know, it’s weird, I’m still investigating
Hi, I have the same problem, did you find a solution to it ?
I’ve the same issue. Did a fresh install of Manjaro Gnome on an optimus laptop. Restarts. Then greeted with a black screen. Did open a tty using Ctrl+Alt+F2, but requires a login, which the installer didn’t provide.
Hey did you fixed that???
