material-shell, touch friendly and efficient tiling interface
pop-shell, unintrusive and intuitive tiling system (enabled by default)
OEM-style installation with gnome-initial-setup. Installing Manjaro to your friends computer is easier than ever
improved terminal fonts (read: better icons in ranger and better looking powerline if you enable it)
improved bmenu for system management in terminal
plymouth for boot animation (optional graphical password dialogs coming later). Enabled only for installed system, live system still shows the console output.
Anyone else suffering from slow mirrors/slow pacman download speed? Getting around 50-80kbps and I have tried almost all the options of pacman-mirrors
âfasttrack, India, Bangladesh, --continent, --geoip⌠Even reset it as well
More Info: I have tried this in Qemu/Virt Manager and the host machine is Manjaro KDE where the speed is around expected 5-6 MBps
try this sudo pacman-mirrors --fasttrack 0 --timeout 30 && sudo pacman -Syyu this will check all the mirrors and then refresh pacman to use the fastest. for me ones that are outside my contry are faster then the ones near me
Hi to everyone! In my case the gnome calendar has a bug. When i am switching to a different year than 2020 closes unexpectedly. I have my gmail synced.
I installed the rc on my ThinkPad X1 Extreme Gen 2. I noticed the differences right from the 1st screen of the installer. The installer is now more in PopOS/Fedora style. It looks great on the 4k screen and itâs simpler and faster than the previous version of installer.
Most of changes are positive to me. I quite like the Layout Switcher. But under Modern layout, when I open Files or Terminal, the app title on top bar shows âUnknownâ instead of app name. I think this is a bug.
if i do âpacman-mirrors --get-branchâ in the rc1 installation it says stable branchâŚso why should i change branch afterwards?? isnât it already in stable??
yep! Installed the gnome desktop. Got through the amazing looking new installer too.
But TLP service is also disabled when installed. When I install the latest Manjaro Gnome, not this release candidate but the official latest TLP is enabled.
But with this one it is disabled.
@oberon it seems that there is a bug in the new version of manjaro-tools. Services in systemd_disable_live get disabled also for the installed system, it seems.
I installed the RC on my Lenovo Yoga Slim7 AMD Ryzen 4800u laptop. After enabling amdgpu module, 2 baclkight service not loading warnings disappeared. It also fixed the problem that brightness settings could not be saved with Manjaro on this laptop. Now everything works great with Manjaro Gnome on this laptop .
