Yeno
9 March 2024 20:23
1
Hello there,
It seems, that my laptop is freezing every time I start it.
It is bootig quite fine but after a view minutes of usage (no matter if I open Thunar, Firefox or the Terminal), it seems it is so busy with something else, that it can’t react on any of my commands. Can’t even move the mouse. Plus it is getting super noisy.
I did do a hard shutdown and changed to TTY3, where I clened the cache and cleared the journal.
But then, while removon foreign packages it froze again.
How can I find out, what the problem is?
I am still not an expert and I thank everyone for their tips!
6x12
9 March 2024 20:57
2
That was the emergency help you’ve got when you run out of space because your 20GB system partition was full. Is it still the same issue?
If not let us see your hardware info and post the output of:
inxi -Fazy
Yeno
9 March 2024 21:28
3
No, it shouldn’t be the same issue, I did a new setup with different partition sizes. But I thought it could help anyways…
[ruiliri@manjaro-iris ~]$ inxi -Fazy
Kernel: 5.15.133-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e12fc4a7-f402-4516-aedd-a78ee88b5c34 rw quiet apparmor=1
security=apparmor resume=UUID=15b40c24-6bd1-43ad-8428-5d7f8752de59
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 80Q2 v: Lenovo ideapad 500S-13ISK
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 500S-13ISK
Mobo: LENOVO model: Lenovo ideapad 5 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: DCCN34WW(V2.03) date: 12/01/2015
ID-1: BAT1 charge: 16.0 Wh (99.4%) condition: 16.1/35.0 Wh (45.9%) volts: 8.3
min: 7.6 model: LENOVO PABAS0241231 type: Li-ion serial: <filter> status: N/A
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 855 high: 1923 min/max: 400/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 500 2: 500 3: 500 4: 1923
bogomips: 19204
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: gather_data_sampling status: Vulnerable: No microcode
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: Chicony Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b50f
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x048c built: 2014 res: 1920x1080 hz: 60
dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k5.15.133-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 0cf3:e360
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 51.82 GiB (5.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPCX-24HWST1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 13.37 GiB (14.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 825.55 GiB size: 811.52 GiB (98.30%)
used: 38.46 GiB (4.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 39.0 C pch: 37.5 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 190 Uptime: 17m wakeups: 1 Memory: total: 8 GiB
available: 7.62 GiB used: 947.6 MiB (12.1%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1195 libs: 402 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.30
Sounds like an overheat issue to me. Either one of the processes heavily uses your CPU or cooling system doesn’t do it’s job properly.
Try to monitor CPU usage and temperature.
Yeno
9 March 2024 23:45
5
is that the right for CPU?
Temperature I don’t know, how to monitor.
BG405
10 March 2024 00:19
6
In terminal: sensors (you might need to install i2c-tools; used to be a part of lm-sensors).
Maybe leave a terminal window set to “always above” running e.g. watch -n 10 sensors
6x12
10 March 2024 00:45
7
This looks very cool for older hardware, can’t see anything weird. Next time it freezes please reboot and show the output of:
journalctl -b-1 | tail -n150
One possibility might be an issue with your drive if it’s an old spinner. If you have ‘Disks’ installed open it, pick your drive on the left then hit the 3 vertical dots and have a look at ‘SMART Data&Self Tests’.
Yeno
10 March 2024 11:15
8
Thanks for all your help.
I don’t quite know, how, but the bug is gone (for the moment)
What I did:
After clearing cache and journal it worked so far, I could make an update (after changing timedate setup by timedatectl set-time "yyyy-MM-dd hh:mm:ss ), reboot and now it works.
It seems that the problems occured, because the last update was quite long ago… is that possible?
I used: https://wiki.archlinux.org/index.php/System_time#Time_standard
for help.
