Manjaro freezes when running backintime (rsync)
I encounter freezes for a system which was running pretty stable beforehand. It appears that a freeze occurs more often, when I conduct backups on an external HDD. I tried to track this down, to no avail.
This is the output of inxi --admin --verbosity=7 --filter --no-host --width:
  Kernel: 6.1.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=4c2ea2f1-3cfa-4377-8778-97f19f2453fe rw quiet
    cryptdevice=UUID=ac37595d-5b67-408c-82b8-547a678e97e6:luks-ac37595d-5b67-408c-82b8-547a678e97e6
    root=/dev/mapper/luks-ac37595d-5b67-408c-82b8-547a678e97e6
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop System: MSI product: MS-7798 v: 1.0
    serial: <superuser required>
  Mobo: MSI model: B75MA-P45 (MS-7798) v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: 1.9 date: 09/30/2013
  Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
    status: discharging
  System RAM: total: 8 GiB available: 7.69 GiB used: 3.35 GiB (43.6%)
  Info: model: Intel Core i5-3450S bits: 64 type: MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 1605 high: 1619 min/max: 1600/2800 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1601 2: 1619 3: 1600
    4: 1600 bogomips: 22409
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave
    xsaveopt xtopology xtpr
    disabled
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: NVIDIA GF108 [GeForce GT 430] driver: nvidia v: 390.157
    alternate: nouveau,nvidia_drm non-free: series: 390.xx+
    status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
    xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
    gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0de1
    class-ID: 0300
  Device-2: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5.1:4
    chip-ID: 046d:081b class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
    s-diag: 692mm (27.26")
  Monitor-1: DVI-I-1 res: 2560x1440 hz: 60 dpi: 109
    size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: kms_swrast x11:
    egl: 1.4 drv: nvidia inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
    glx-v: 1.4 direct-render: yes renderer: GeForce GT 430/PCIe/SSE2
    memory: 1000 MiB
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Micro-Star MSI 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:0bea class-ID: 0403
  Device-3: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.1.60-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.83 status: off with: pipewire-media-session
    status: active tools: pw-cli
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573]
    driver: rt2800usb type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 3-4:4 chip-ID: 0846:9012 class-ID: 0000 serial: <filter>
  IF: wlp0s20u4 state: up mac: <filter>
  Device-1: bitlk_mobi_stick maj-min: 254:3 type: Crypto dm: dm-3
  Components:
  p-1: sde1 maj-min: 8:65 size: 119.01 GiB
  Device-2: bitlk_daniel_stick maj-min: 254:4 type: Crypto dm: dm-4
  Components:
  p-1: sde2 maj-min: 8:66 size: 30 GiB
  Device-3: bitlk_bibliothek_stick maj-min: 254:5 type: Crypto dm: dm-5
  Components:
  p-1: sde3 maj-min: 8:67 size: 30 GiB
  Device-4: bitlk_wiki_stick maj-min: 254:6 type: Crypto dm: dm-6
  Components:
  p-1: sde4 maj-min: 8:68 size: 30 GiB
  Device-5: luks-ac37595d-5b67-408c-82b8-547a678e97e6 maj-min: 254:0
    type: LUKS dm: dm-0 size: 232.59 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 232.59 GiB
  Device-6: luks-aa7c5077-2732-494c-8f37-9d6d9852f1d5 maj-min: 254:2
    type: LUKS dm: dm-2 size: 465.76 GiB
  Components:
  p-1: sdb1 maj-min: 8:17 size: 465.76 GiB
  Device-7: luks-97478fb5-267e-493d-8774-49eef2f55050 maj-min: 254:1
    type: LUKS dm: dm-1 size: 465.76 GiB
  Components:
  p-1: sdc1 maj-min: 8:33 size: 465.76 GiB
  Local Storage: total: 2.28 TiB used: 583.48 GiB (25.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD5000AZRX-00A8LB0 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
    scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: JMicron Tech model: N/A
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 0213 scheme: GPT
  ID-5: /dev/sde maj-min: 8:64 vendor: Samsung model: Flash Drive FIT
    size: 239.02 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: 1100 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NS90 rev: IN01
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 75.22 GiB (33.0%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ac37595d-5b67-408c-82b8-547a678e97e6 label: System
    uuid: 4c2ea2f1-3cfa-4377-8778-97f19f2453fe
    used: 472 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 04E7-F02F
  ID-3: /run/media/schatzi/Bibliothek raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 7.47 GiB (24.9%) fs: ntfs3 dev: /dev/dm-5 maj-min: 254:5
    mapped: bitlk_bibliothek_stick label: N/A uuid: N/A
  ID-4: /run/media/schatzi/Daniel raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 8.97 GiB (29.9%) fs: ntfs3 dev: /dev/dm-4 maj-min: 254:4
    mapped: bitlk_daniel_stick label: N/A uuid: N/A
  ID-5: /run/media/schatzi/Data raw-size: 465.76 GiB
    size: 457.38 GiB (98.20%) used: 271.63 GiB (59.4%) fs: ext4 dev: /dev/dm-1
    maj-min: 254:1 mapped: luks-97478fb5-267e-493d-8774-49eef2f55050
    label: Data uuid: aea89950-6192-4055-8c45-0991f2477684
  ID-6: /run/media/schatzi/Extra raw-size: 465.76 GiB
    size: 457.38 GiB (98.20%) used: 215.16 GiB (47.0%) fs: ext4 dev: /dev/dm-2
    maj-min: 254:2 mapped: luks-aa7c5077-2732-494c-8f37-9d6d9852f1d5
    label: Extra uuid: 61a2cc0c-2b1f-46e2-a956-a42b5e447f2a
  ID-7: /run/media/schatzi/Mobi raw-size: 119.01 GiB
    size: 119.01 GiB (100.00%) used: 190.6 MiB (0.2%) fs: ntfs3 dev: /dev/dm-3
    maj-min: 254:3 mapped: bitlk_mobi_stick label: N/A uuid: N/A
  ID-8: /run/media/schatzi/Wiki raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 4.83 GiB (16.1%) fs: ntfs3 dev: /dev/dm-6 maj-min: 254:6
    mapped: bitlk_wiki_stick label: N/A uuid: N/A
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/sde1 maj-min: 8:65 size: 119.01 GiB fs: bitlocker label: N/A
    uuid: N/A
  ID-2: /dev/sde2 maj-min: 8:66 size: 30 GiB fs: bitlocker label: N/A
    uuid: N/A
  ID-3: /dev/sde3 maj-min: 8:67 size: 30 GiB fs: bitlocker label: N/A
    uuid: N/A
  ID-4: /dev/sde4 maj-min: 8:68 size: 30 GiB fs: bitlocker label: N/A
    uuid: N/A
  ID-5: /dev/sde5 maj-min: 8:69 size: 30 GiB fs: bitlocker label: N/A
    uuid: N/A
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-3: 1-1.5:3 info: Huasheng [] ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Device-1: 1-1.5.1:4 info: Logitech Webcam C310 type: video,audio
  Device-2: 1-1.5.2:5 info: OmniKey AG CardMan 3121 (HID ) type: smart card
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 076b:3022 class-ID: 0b00
  Hub-4: 1-1.5.3:6 info: Monterey BakkerElkhuizen Wired Keyboard S-board 840
    Design USB-Hub ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 0566:3020 class-ID: 0900
  Device-1: 1-1.5.3.1:8 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-1.5.3.2:9 info: GreenAsia [] type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 0e8f:00a8 class-ID: 0301
  Device-3: 1-1.5.3.3:10 info: Monterey BakkerElkhuizen Wired Keyboard
    S-board 840 Design type: keyboard,HID driver: hid-generic,usbhid
    interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 0566:3013 class-ID: 0300
  Device-4: 1-1.5.4:7 info: Evoluent [] type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1a7c:0197 class-ID: 0301
  Hub-5: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-6: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-7: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: JMicron / USA JMS567 SATA 6Gb/s bridge
    type: mass storage driver: uas interfaces: 1 rev: 2.1
    chip-ID: 152d:0562 class-ID: 0806 serial: <filter>
  Hub-8: 3-3:3 info: Realtek [] ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5412
  Device-1: 3-4:4 info: NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573]
    type: Network driver: rt2800usb interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 450mA
  Hub-9: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  Device-1: 4-1:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 304mA
    chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
  Hub-10: 4-3:3 info: Realtek [] ports: 2 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0412
  System Temperatures: cpu: 34.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 302 Uptime: 25m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1619 libs: 419 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
Can someone please provide some hints about how to proceed from hereon?
How long is it since you checked your dives for consistency (fsck)?
I just did and they are all reported to be ok.
Example:
fsck von util-linux 2.39.2
e2fsck 1.47.0 (5-Feb-2023)
Extra: sauber, 206174/30531584 Dateien, 51236231/122095872 Blöcke
Moreover, system seems stable without touching rsync. This is really mad. Any other idea?
First, what does system freeze mean exactly? Locks up for good? Locks up for a time and then is usable again?
You need to look at logs from when it freezes. If it froze hard and you had to restart then journalctl -b -1 --no-pager is the log from previous boot, look at the end of it. If you didn’t reboot then journalctl -S -10m --no-pager shows the last 10 minutes (adjust number of minutes as needed).
It’s a freeze for good, restart required!
I’ve checked the journal, but there is a lot of information. I guess, I am looking for red entries, just before death. Is this correct? But there is nothing red.
I’d like to share here - is there some command removing the sensitive information?
This should be fine:
For the journal commands, yes, but I don’t remember which, right now.
Here it is:
journalctl --boot=-1 --priority=3 --catalog --no-pager
… and more use cases can be found in How to Find Error Logs.
Ok, this is the last greeting from the here and now:
Nov 12 22:45:42 <user> kernel: general protection fault, probably for non-canonical address 0xff97f59ca8a7b800: 0000 [#1] PREEMPT SMP PTI
Nov 12 22:45:42 <user> kernel: CPU: 2 PID: 2906 Comm: rsync Tainted: P           OE      6.1.60-1-MANJARO #1 bc39d7bff9ff278fc12a62411deb4fa501ac4ff5
Nov 12 22:45:42 <user> kernel: Hardware name: MSI MS-7798/B75MA-P45 (MS-7798), BIOS V1.9 09/30/2013
Nov 12 22:45:42 <user> kernel: RIP: 0010:__schedule+0x1ba/0x12c0
Nov 12 22:45:42 <user> kernel: Code: 00 00 80 49 c7 84 24 70 0a 00 00 00 00 00 00 49 39 dd 0f 84 c2 0c 00 00 48 8b 45 88 49 83 44 24 70 01 49 89 9c 24 e0 09 00 00 <48> 83 00 01 66 41 83 bd 58 04 00 00 00 0f 85 23 0d 00 00 e9 95 08
Nov 12 22:45:42 <user> kernel: RSP: 0018:ffffb86e43fbfba8 EFLAGS: 00010002
Nov 12 22:45:42 <user> kernel: RAX: ff97f59ca8a7b800 RBX: ffff97f5050a0000 RCX: ffff97f615d33978
Nov 12 22:45:42 <user> kernel: RDX: ffff97f615d33978 RSI: ffff97f615d33978 RDI: ffff97f5050a00a8
Nov 12 22:45:42 <user> kernel: RBP: ffffb86e43fbfc37 R08: ffff97f59ca8a128 R09: 0000000000000000
Nov 12 22:45:42 <user> kernel: R10: 0000000000000f75 R11: 0000000000000000 R12: ffff97f615d32e80
Nov 12 22:45:42 <user> kernel: R13: ffff97f59ca8a080 R14: ffffb86e43fbfbf8 R15: 0000000000000000
Nov 12 22:45:42 <user> kernel: FS:  00007f303c58d740(0000) GS:ffff97f615d00000(0000) knlGS:0000000000000000
Nov 12 22:45:42 <user> kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Nov 12 22:45:42 <user> kernel: CR2: 000055f079dc8780 CR3: 000000019634a002 CR4: 00000000001706e0
Nov 12 22:45:42 <user> kernel: Call Trace:
Nov 12 22:45:42 <user> kernel:  <TASK>
Nov 12 22:45:42 <user> kernel:  ? __die_body.cold+0x1a/0x1f
Nov 12 22:45:42 <user> kernel:  ? die_addr+0x3c/0x60
Nov 12 22:45:42 <user> kernel:  ? exc_general_protection+0x1c1/0x380
Nov 12 22:45:42 <user> kernel:  ? asm_exc_general_protection+0x26/0x30
Nov 12 22:45:42 <user> kernel:  ? __schedule+0x1ba/0x12c0
Nov 12 22:45:42 <user> kernel:  ? __schedule+0x16c/0x12c0
Nov 12 22:45:42 <user> kernel:  ? read_pages+0x1b4/0x260
Nov 12 22:45:42 <user> kernel:  ? preempt_schedule_irq+0x43/0x60
Nov 12 22:45:42 <user> kernel:  ? asm_sysvec_reschedule_ipi+0x1a/0x20
Nov 12 22:45:42 <user> kernel:  ? touch_atime+0xfa/0x1b0
Nov 12 22:45:42 <user> kernel:  ? filemap_read+0x323/0x340
Nov 12 22:45:42 <user> kernel:  ? vfs_read+0x240/0x310
Nov 12 22:45:42 <user> kernel:  ? ksys_read+0x6f/0xf0
Nov 12 22:45:42 <user> kernel:  ? do_syscall_64+0x60/0x90
Nov 12 22:45:42 <user> kernel:  ? do_syscall_64+0x6c/0x90
Nov 12 22:45:42 <user> kernel:  ? entry_SYSCALL_64_after_hwframe+0x64/0xce
Nov 12 22:45:42 <user> kernel:  </TASK>
Nov 12 22:45:42 <user> kernel: Modules linked in: ntfs3 dm_zero ccm qrtr xt_hl ip6t_rt ip6t_REJECT nf_reject_ipv6 xt_LOG nf_log_syslog xt_multiport xt_limit xt_addrtype rt2800usb xt_tcpudp rt2x00usb xt_conntrack rt2800lib nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ipt_REJECT nf_reject_ipv4 rt2x00lib ip6table_filter intel_rapl_msr iTCO_wdt intel_pmc_bxt ip6_tables intel_rapl_common mei_wdt mei_hdcp mei_pxp at24 iTCO_vendor_support iptable_filter mac80211 uvcvideo videobuf2_vmalloc libarc4 x86_pkg_temp_thermal snd_hda_codec_realtek snd_hda_codec_hdmi snd_hda_codec_generic videobuf2_memops intel_powerclamp ledtrig_audio videobuf2_v4l2 nvidia_uvm(POE) snd_usb_audio cfg80211 snd_hda_intel videobuf2_common coretemp snd_usbmidi_lib snd_intel_dspcfg snd_intel_sdw_acpi rfkill videodev snd_rawmidi joydev snd_seq_device snd_hda_codec mc r8169 snd_hda_core kvm_intel kvm dm_multipath nvidia_drm(POE) snd_hwdep nvidia_modeset(POE) realtek mei_me irqbypass rapl mdio_devres snd_pcm snd_timer intel_cstate
Nov 12 22:45:42 <user> kernel:  i2c_i801 intel_uncore pcspkr i2c_smbus mousedev snd mei lpc_ich libphy nvidia(POE) soundcore vfat fat intel_smartconnect mac_hid video wmi ipmi_devintf ipmi_msghandler vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) i2c_dev crypto_user fuse loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_logitech_hidpp hid_logitech_dj usbhid uas usb_storage dm_crypt cbc encrypted_keys trusted asn1_encoder tee dm_mod crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic gf128mul ghash_clmulni_intel sha512_ssse3 aesni_intel crypto_simd cryptd sr_mod cdrom xhci_pci xhci_pci_renesas
Nov 12 22:45:42 <user> kernel: ---[ end trace 0000000000000000 ]---
Nov 12 22:45:42 <user> kernel: note: rsync[2906] exited with irqs disabled
Nov 12 22:45:42 <user> kernel: note: rsync[2906] exited with preempt_count 2
Looks like something has crashed to me, does it?
Indeed.
Is your backup location formatted as NTFS?
The source drives are mixed, i.e. some ext4 and some ntfs (all encrypted). Target drive is luks/ext4.
OK. As some are NTFS, a failure with the ntfs3 kernel module might be complicating things. A few people are experiencing that of late. Try this:
sudo pacman -S ntfs-3g
echo 'blacklist ntfs3' | sudo tee /etc/modprobe.d/disable-ntfs3.conf
… and try running the backup again.
Further to this, you might also consider checking your disks for consistency, if you havent already (fsck). For the NTFS filesystems, chkdsk is best suited, from within a Windows environment.
Ok, this seems to help: Ran the complete backup twice on empty target drives, both time successfully.
(One remark: I assume a restart is required in order to blacklist the ntfs3 package.)
With procedure above, we’ve restored the previous ntfs-driver, which was upgraded with my kernel upgrade to 6.1.xx. What should I do from hereon? Do you need additional tests from my end?
If blacklisting the kernel ntfs3 driver (and restarting) has solved your problem then you’re done. Future updates won’t re-enable it.
