Hello.
After an update, manjaro refuses to start. I select the kernel I want to boot, and see only a blinking cursor.
But I do have access to tty. Startx-command tells me “no screens found”.
Please see the output in the image below.
- Kernel: 5.15
- Nvidia driver: 2021.11.04
- gdm
Any help appreciated.
you had already this issue and nothing worked except downgrading kernel and nvidia … so why would you again update them and end up with the same issue after the downgrade that fixed the issue ??
I set the nvidia-driver to “ignore” in the manjaro’s software-manager, as well as the kernel. But I now realize that other nvidia-packages get update nethertheless. Thanks for pointing out the obvious…
wait till the next system update and then update them, hopefully the issue will be resolved …
If not, you are likely to read from me again
