Hello!
I want to give a shot to Manjaro so I decided to install it.
I have both Windows 11 and deepin OSes.
I’ve made a partition from Windows, and the boot USB worked fine in the installation.
The problem is that when I boot Manjaro, I just see motherboard logo (DELL laptop), and I can’t continue unless I reboot in Windows or Deepin.
Thanks for help!
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading
You can also use Maxi
to collect information about the boot process. This works,
- when you are in your running system (with CTRL+ALT+F2).
- And also in a live environment
Hi! Thanks for warm welcome!
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2137 quiet systemd.show_status=1
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude E5470 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0VHKV0 v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.23.3 date: 08/04/2020
ID-1: BAT0 charge: 9.3 Wh (39.7%) condition: 23.4/47.0 Wh (49.7%)
volts: 11.0 min: 11.4 model: SMP DELL JY8D64C type: Li-ion serial: <filter>
status: discharging
RAM: total: 7.58 GiB used: 2.14 GiB (28.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78)
stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2942 high: 3000 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2900 2: 2970 3: 2901
4: 3000 bogomips: 20004
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-2:2 chip-ID: 1bcf:28b8 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1490 built: 2014 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-8:6 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 267.54 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: X400 M.2 2280 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0012 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Glide
3.0 size: 29.06 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 5205-1C9A
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 79.18 GiB fs: ntfs
label: Phoenix LiteOS uuid: 08500C2C500C22D4
ID-4: /dev/sda4 maj-min: 8:4 size: 510 MiB fs: ext4 label: N/A
uuid: 092e5f53-673b-4cc5-ae1b-d15c6d9ee957
ID-5: /dev/sda5 maj-min: 8:5 size: 119.18 GiB fs: ext4 label: N/A
uuid: b5eb0dde-9635-41b5-9e7f-23c0ba75b87c
ID-6: /dev/sda6 maj-min: 8:6 size: 39.5 GiB fs: ext4 label: N/A
uuid: 44d870f5-d38b-4b0a-be76-fa9928447b44
ID-7: /dev/sdb1 maj-min: 8:17 size: 3.32 GiB fs: iso9660
ID-8: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Sunplus Innovation Integrated_Webcam_HD type: Video
Hub-2: 1-3:3 info: Dell USB 2.0 Hub [MTT] ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 413c:1010 class-ID: 0900
Device-1: 1-3.1:5 info: Logitech Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-3.4:7 info: Dell Wired Multimedia Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 413c:2110 class-ID: 0301
Device-3: 1-7:4 info: Broadcom 5880 type: Smart Card driver: N/A
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0a5c:5832
class-ID: 0b00 serial: <filter>
Device-4: 1-8:6 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 2-1:2 info: SanDisk Cruzer Glide 3.0 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5597 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 63.0 C pch: 51.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2509
Processes: 201 Uptime: 2m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1209
lib: 318 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
