Manjaro does not boot after installing a new Kernel-dropped Into emergency shell, for people who think they have a big problem but are actually just noobs
Hello,
I have Manjaro KDE Plasma on my Dell XPS. Its 2 days since it happened, i did the new updates like usual and my Laptop then asked me to install a new Kernel, because something doesnt work with an update. I opened the Manjaro Settings and tried to install a newer Kernel, after it completed, I was told to reboot to finish the update. I did that, and received a terminal screen with this message:
8/psobject-251)
0.0355971 ACPI Exception: AE_NOT_FOUND, (SSDT:xh_Dell_) while loading table
(20170728/tbxfload-225)
t 0.0357931 ACPI Error: 1 table load failures, 12 successful (20170728/tbxflo
ad-244)
0.0388981 Spectre U2: WARNING: Unprivileged eBPF is enabled with eIBRS on,
data leaks possible via Spectre u2 BHB attacks!
0.0900421 hu perf events fixed 4 > max (3), clipping!
0.3496941 ACPI Error: [USP1] Namespace lookup failure, AE_NOT_FOUND (201707
28/psargs-364)
0.3497001 ACPI Error: Method parse/execution failed_SB.PCOO.LPCB.ECDU. TSK
N. STA, AE_NOT_FOUND (20170728/psparse-548)
[ 0.3497191 ACPI Error: [USP1] Namespace lookup failure, AE_NOT_FOUND (201707
28/psargs-364)
0.3497211 ACPI Error: Method parse/execution failed_SB.PC00.LPCB.ECDU.TSK
[ 0.6438421 ACPI Error: [USP11 Namespace lookup failure, AE_NOT_FOUND (201707
28/psargs-364)
0.6438461 ACPI Error: Method parse/execution failed_SB.PC00.LPCB.ECDU. TSK
N. STA, AE NOT FOUND (20170728/psparse-548)
[ 0.6751161 ACPI Error: [USP11 Namespace lookup failure, AE_NOT_FOUND (201707
28/psargs-364)
0.6751201 ACPI Error: Method parse/execution failed_SB.PC00.LPCB.ECDU.TSK
ERROR: device UUID-4b2b26ab-f541-466e-a7f6-fe7c5b45957e' not found. Skipping fsck.
mount: /neuroot: can't find UUID-4b2b26ab-f541-466e-a7f6-fe7c5b45957e.
You are now being dropped into an emergency shell.
sh: can't access tty: job control turned off
[rootfs #
I searched for a bit online, and in all related threads people seem to be able to run commands. I failed, its not working at all, i really dont understand the problem. I mounted my partitions from a live OS but it did nothing. The commands didn’t work. I’m sorry I’m very desperate, also because I normally am probably lucky and although i have no idea, I get things working somehow. I would really appreciate any help.
So, my questions are these:
What is the problem, and how can I avoid this in future?
How can I fix this issue for now? (I really don’t want to format and reinstall)
Is all my data gone? If not, how can I recover those?
I’m pretty new to Linux, so I’ll much appreciate if you answer in a easy to understand way.
Thank you!
this is the issue:
it cant find one of your partitions…
do you have a manjaro usb? if so boot into, chroot:
sudo manjaro-chroot -a
then post formatted output from these commands:
cat /etc/fstab
blkid
And please use preformatted text, my eyes hurt. (isn’t there some guide to read or something when you register on the forum?)
You should be able to.
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
[manjaro /]# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=B510-2088                            /boot/efi      vfat    umask=0077 0 2
UUID=4b2b26ab-f541-466e-a7f6-fe7c5b45957e /              ext4    defaults,noatime 0 1
[manjaro /]# blkid
/dev/loop1: TYPE="squashfs"
/dev/nvme0n1p1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="B510-2088" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="49a85659-a6eb-0c44-8cfc-2a9dd978e07d"
/dev/nvme0n1p2: UUID="4b2b26ab-f541-466e-a7f6-fe7c5b45957e" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="15745598-3d43-9c46-8c05-93d46ef6271a"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="C5CD-B119" BLOCK_SIZE="512" TYPE="vfat"
/dev/sda1: BLOCK_SIZE="2048" UUID="2021-10-08-17-46-47-00" LABEL="MANJARO_KDE_2115" TYPE="iso9660"
/dev/loop3: TYPE="squashfs"
it looks good … can you access your manjaro partition?
What do you mean by ā€œaccessā€
from live usb use dolphin or whatever file manager and open for example your home folder where you have your files…
no i cant do that
is there some error/warning? is it even detected?
When i open dolphin or my folders from live usb?
It’s just empty
i mean on the left side in dolphin under devices, if you click on your manjaro installation, can you access that, not live usbs folders…
im rly sry for giving you a hard time
An error occurred while accessing ā€˜Home’, the system responded: The requested operation has failed: Error mounting /dev/sda1 at /run/media/manjaro/MANJARO_KDE_2115: /dev/sda1 already mounted or mount point busy
thats what i get
its ok… but i dont know whats with it… post output from:
mhwd-kernel -li
Currently running: 5.13.19-2-MANJARO (linux513)
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
   * linux513
you are running an old kernel…
run this:
pacman-mirrors --fasttrack 5 && pacman -Syyu
.: ERROR Must have root privileges
are you chrooted?
ok did it
should i reboot now
what do you mean you did it, what did you did? no dont reboot
