i ran the command
which one? this:
pacman-mirrors --fasttrack 5 && pacman -Syyu
yessir
and did you have any errors?
post again output from:
mhwd-kernel -li
No errors
Currently running: 5.13.19-2-MANJARO (linux513)
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
* linux513
but its the same right
so close the terminal, open it again and run again this:
sudo manjaro-chroot -a
then run this:
and post output from this command
good, now lets install a kernel:
sudo mhwd-kernel -i linux515
core 166.6 KiB 980 KiB/s 00:00 [#####################################################################] 100%
extra 1859.8 KiB 16.5 MiB/s 00:00 [#####################################################################] 100%
community 7.0 MiB 22.6 MiB/s 00:00 [#####################################################################] 100%
multilib 174.5 KiB 7.41 MiB/s 00:00 [#####################################################################] 100%
error: no targets specified (use -h for help)
* linux414
where did the 414 come fromā¦
and if you install with this:
pacman -S linux515
idk, should i type this
run that command, and see if it installs the kernel
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
linux515-5.15.46-1-x86_64 is up to date
(1/1) checking keys in keyring [#####################################################################] 100%
(1/1) checking package integrity [#####################################################################] 100%
(1/1) loading package files [#####################################################################] 100%
(1/1) checking for file conflicts [#####################################################################] 100%
(1/1) checking available disk space [#####################################################################] 100%
(1/1) installing linux515 [#####################################################################] 100%
Optional dependencies for linux515
wireless-regdb: to set the correct wireless channels of your country [installed]
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.46-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qla1280
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
(4/5) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.14-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
i dunno, probably did
looks like itā¦
run these:
exit
systemctl reboot
and hopefully you boot normally
Thank you so so much. I mean it. Youāre a lifesaver. Have a great day.
so did it worked?
go to system settings/ kernel and uninstall the 4.14 kernel, its too oldā¦ and install the 5.10LTS as a backup kernel
Do you have a command for that because if I do it manually it just says changes successfully made but itās still installed
you mean the 4.14?
provide output again from:
mhwd-kernel -li
And now I know again how this happened. Exactly like this. I installed it because the newer Kernel didnāt work for anything and then I wanted to remove it, but I didnāt work. Then the message with the restart and there we were.
