@Victor
I tried restarting NetworkManager and this is what i got
$ systemctl stop NetworkManager.service
$ systemctl start NetworkManager.service
$ systemctl status NetworkManager.service
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
└─NetworkManager-ovs.conf
Active: active (running) since Fri 2021-09-03 02:52:55 PST; 13s ago
Docs: man:NetworkManager(8)
Main PID: 29771 (NetworkManager)
Tasks: 4 (limit: 38319)
Memory: 4.5M
CPU: 129ms
CGroup: /system.slice/NetworkManager.service
└─29771 /usr/bin/NetworkManager --no-daemon
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0618] manager: (60:F4:45:72:5A:E3): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/13)
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0621] device (60:F4:45:72:5A:E3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0628] device (BC:4C:C4:99:FC:90): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0631] device (60:F4:45:72:5A:E3): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0642] device (tun0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0644] device (tun0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0647] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0651] device (tun0): Activation: successful, device activated.
Sep 03 02:52:56 franz NetworkManager[29771]: <info> [1630608776.0697] agent-manager: agent[d97c8eea80b97dd9,:1.37/org.freedesktop.nm-applet/1000]: agent registered
Sep 03 02:53:02 franz NetworkManager[29771]: <info> [1630608782.0378] manager: startup complete
Then i did nmcli dev show again and got this
$ nmcli dev show
GENERAL.DEVICE: BC:4C:C4:99:FC:90
GENERAL.TYPE: bt
GENERAL.HWADDR: BC:4C:C4:99:FC:90
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.CONNECTION: My iPhone Network
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/2
IP4.ADDRESS[1]: 172.20.10.2/28
IP4.GATEWAY: 172.20.10.1
IP4.ROUTE[1]: dst = 0.0.0.0/0, nh = 172.20.10.1, mt = 750
IP4.ROUTE[2]: dst = 172.20.10.0/28, nh = 0.0.0.0, mt = 750
IP4.ROUTE[3]: dst = 34.227.143.107/32, nh = 172.20.10.1, mt = 0
IP4.DNS[1]: 172.20.10.1
IP6.ADDRESS[1]: fe80::2d3d:603c:df1f:7c56/64
IP6.GATEWAY: --
IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 750
GENERAL.DEVICE: tun0
GENERAL.TYPE: tun
GENERAL.HWADDR: (unknown)
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected (externally))
GENERAL.CONNECTION: tun0
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/3
IP4.ADDRESS[1]: 172.27.243.160/24
IP4.GATEWAY: --
IP4.ROUTE[1]: dst = 172.27.243.0/24, nh = 0.0.0.0, mt = 0
IP4.ROUTE[2]: dst = 172.27.224.0/20, nh = 172.27.243.1, mt = 0
IP4.ROUTE[3]: dst = 10.0.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[4]: dst = 10.2.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[5]: dst = 10.5.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[6]: dst = 10.8.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[7]: dst = 10.10.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[8]: dst = 10.14.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[9]: dst = 10.20.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[10]: dst = 10.30.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[11]: dst = 10.31.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[12]: dst = 10.32.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[13]: dst = 10.33.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[14]: dst = 10.35.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[15]: dst = 10.40.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[16]: dst = 10.41.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[17]: dst = 10.46.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[18]: dst = 10.47.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[19]: dst = 10.50.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[20]: dst = 10.58.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[21]: dst = 10.60.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[22]: dst = 10.64.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[23]: dst = 10.65.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[24]: dst = 10.66.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[25]: dst = 10.67.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[26]: dst = 10.68.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[27]: dst = 10.69.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[28]: dst = 10.70.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[29]: dst = 10.77.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[30]: dst = 10.80.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[31]: dst = 10.81.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[32]: dst = 10.82.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[33]: dst = 10.84.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[34]: dst = 10.88.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[35]: dst = 10.89.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[36]: dst = 10.90.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[37]: dst = 10.92.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[38]: dst = 10.94.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[39]: dst = 10.95.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[40]: dst = 10.96.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[41]: dst = 10.97.0.0/16, nh = 172.27.243.1, mt = 0
IP4.ROUTE[42]: dst = 10.100.0.0/16, nh = 172.27.243.1, mt = 0
IP6.GATEWAY: --
GENERAL.DEVICE: 60:F4:45:72:5A:E3
GENERAL.TYPE: bt
GENERAL.HWADDR: 60:F4:45:72:5A:E3
GENERAL.MTU: 0
GENERAL.STATE: 30 (disconnected)
GENERAL.CONNECTION: --
GENERAL.CON-PATH: --
GENERAL.DEVICE: eth0
GENERAL.TYPE: ethernet
GENERAL.HWADDR: 98:28:A6:42:C8:5B
GENERAL.MTU: 1500
GENERAL.STATE: 20 (unavailable)
WIRED-PROPERTIES.CARRIER: off
GENERAL.DEVICE: br-17da583b3d25
GENERAL.TYPE: bridge
GENERAL.HWADDR: 02:42:3F:89:C8:08
GENERAL.MTU: 1500
GENERAL.STATE: 10 (unmanaged)
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: br-47b21b11bbf2
GENERAL.HWADDR: 02:42:CC:E1:7F:E4
GENERAL.MTU: 1500
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: br-5b8ab1e8084d
GENERAL.HWADDR: 02:42:36:E9:52:61
GENERAL.MTU: 1500
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: br-6b96ce764012
GENERAL.HWADDR: 02:42:3B:2E:DC:4E
GENERAL.MTU: 1500
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: br-78acf6f03097
GENERAL.HWADDR: 02:42:A6:38:29:F7
GENERAL.MTU: 1500
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: br-d0f4392df459
GENERAL.HWADDR: 02:42:93:71:3E:49
GENERAL.MTU: 1500
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: br-e8da5bb35b04
GENERAL.HWADDR: 02:42:C3:B6:EE:99
GENERAL.MTU: 1500
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: docker0
GENERAL.HWADDR: 02:42:7E:34:E4:5C
GENERAL.MTU: 1500
IP4.GATEWAY: --
IP6.GATEWAY: --
GENERAL.DEVICE: lo
GENERAL.TYPE: loopback
GENERAL.HWADDR: 00:00:00:00:00:00
GENERAL.MTU: 65536
IP4.ADDRESS[1]: 127.0.0.1/8
IP4.GATEWAY: --
IP6.GATEWAY: --
I dont see anything that might indicate wifi from nmcli dev show
