Hi all, first time here.
I’m hoping I’m posting in the correct category, let me know if I need to post this some where else.
I have been using Manjaro Budgie for some time with no issues.
I have recently installed a SSD and freshly installed Manjaro Budgie and struck a few problems.
I have managed to work through most of these by following solutions in the forums (thanks everyone
The one remaining issue is every time I boot I end up with a blank screen as the desktop environment doesn’t load.
I’m able to press ctrl alt f2 to login and startx to load the desktop.
Some posts indicate this maybe a lightdm issue, but I haven’t found a solution that works yet.
I’m a bit of a newbie on the terminal but I’m happy to follow instructions ![]()
Inixi output:
Kernel: 5.15.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f3301357-5028-45c3-b9f9-ccfefe38cddb rw quiet apparmor=1
security=apparmor resume=UUID=ad9a5701-e967-4058-b869-0c9b7eb78a8f
udev.log_priority=3
Desktop: Budgie v: 10.6.1 info: budgie-panel wm: budgie-wm dm: LightDM
v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-bw0xx v: Type1ProductConfigId
Mobo: HP model: 8330 v: 27.32 serial: <superuser required> UEFI: Insyde
v: F.22 date: 03/09/2018
ID-1: BAT1 charge: 26.0 Wh (79.0%) condition: 32.9/41.6 Wh (78.9%)
volts: 16.5 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: charging
RAM: total: 3.72 GiB used: 1.47 GiB (39.6%)
RAM Report:
Info: model: AMD E2-9000e RADEON R2 4 COMPUTE CORES 2C+2G bits: 64 type: MCP
arch: Excavator built: 2015 process: GF 28nm family: 0x15 (21)
model-id: 0x70 (112) stepping: 0 microcode: 0x6006704
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1264 high: 1323 min/max: 1100/1500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1323 2: 1206
bogomips: 5990
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm lwp mca mce
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload
vgif vmcb_clean vme vmmcall wdt xop xsave xsaveopt
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN 2 process: GF/TSMC 16-28nm built: 2013-17
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:01.0
chip-ID: 1002:98e4 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 2-1:2 chip-ID: 05c8:03ac class-ID: 0e02
serial: <filter>
Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: budgie-wm driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x06a4 built: 2015
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
class-ID: 0403
Sound Server-1: ALSA v: k5.15.46-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:24fb class-ID: 0280
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 167.68 GiB used: 10.92 GiB (6.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BW180A4
size: 167.68 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: DC12 scheme: GPT
ID-1: / raw-size: 159.2 GiB size: 155.64 GiB (97.77%) used: 10.92 GiB (7.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: f3301357-5028-45c3-b9f9-ccfefe38cddb
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 3F28-D9DF
ID-1: swap-1 type: partition size: 8.19 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: ad9a5701-e967-4058-b869-0c9b7eb78a8f
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.1:3 info: Maxxter Telink Wireless Receiver
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 50mA chip-ID: 248a:8367 class-ID: 0301
Device-2: 1-1.4:4 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 2-1:2
info: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03ac class-ID: 0e02 serial: <filter>
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 61.0 C mobo: 20.0 C gpu: amdgpu temp: 60.0 C
Processes: 199 Uptime: 1m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1096
lib: 346 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.17```
