Hello, after a full system upgrade the system got broken at least partially as I am not able to see the Desktop or open System preferences, etc. I can still open some programs and it seems that all my files and data are stil there as I can list them on Terminal.
❯ inxi -v7azy
Kernel: 5.15.93-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=6b56245f-395b-43c0-9684-80317a72d90d rw quiet iomem=relaxed
iomem=relaxed apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2
Type: Laptop System: Star Labs product: StarBook v: 1.0
serial: <superuser required>
Mobo: Star Labs model: StarBook v: 1.0 serial: <superuser required>
UEFI: coreboot v: 7.96 date: 03/14/2022
ID-1: BAT0 charge: 57.8 Wh (96.5%) condition: 59.9/65.3 Wh (91.7%)
volts: 12.6 min: 11.6 model: DGFGE 597077-3S type: Unknown serial: <filter>
status: discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse PID:0038
serial: N/A charge: 55% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard PID:0057
serial: N/A charge: 70% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 15.48 GiB used: 3.68 GiB (23.8%)
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 841 high: 1076 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 853 2: 485 3: 842 4: 915
5: 716 6: 1076 7: 895 8: 948 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB driver: uvcvideo
bus-ID: 3-4:2 chip-ID: 0c45:6366 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.7
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Realtek
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound API: ALSA v: k5.15.93-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel modules: wl
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 447.13 GiB used: 376.43 GiB (84.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: Star Drive PCIe SSD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM32.2 temp: 23.9 C scheme: GPT
ID-1: / raw-size: 446.83 GiB size: 438.75 GiB (98.19%)
used: 376.43 GiB (85.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 6b56245f-395b-43c0-9684-80317a72d90d
label: NO_LABEL uuid: FBCC-96A4
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-4:2 info: Microdia Webcam Vitade AF type: Video
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-6.3:5 info: Logitech MX3000 Cordless Desktop Receiver
type: Keyboard,Mouse driver: logitech-djreceiver,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c513 class-ID: 0301
Device-2: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 28.0 C mobo: N/A
Processes: 257 Uptime: 7m wakeups: 10 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1747
pm: pacman pkgs: 1728 libs: 408 tools: pamac,yay pm: appimage pkgs: 0
pm: flatpak pkgs: 9 pm: snap pkgs: 10 Shell: Zsh v: 5.9 running-in: yakuake
inxi: 3.3.25
These are some errors I got while upgrading. Hopefully you can give me some help
❯ sudo pacman -Syyu
:: Synchronising package databases...
core 164.9 KiB 837 KiB/s 00:00 [###########################################################] 100%
extra 1856.1 KiB 11.5 MiB/s 00:00 [###########################################################] 100%
community 7.6 MiB 28.3 MiB/s 00:00 [###########################################################] 100%
multilib 170.0 KiB 4.49 MiB/s 00:00 [###########################################################] 100%
resolving dependencies...
Packages (173) akonadi-contacts-22.12.2-1 alsa-card-profiles-1:0.3.65-6 aom-3.6.0-1 ark-22.12.2-1 baloo-widgets-22.12.2-1 binutils-2.40-4 blas-3.11.0-2
cairo-1.17.8-2 cblas-3.11.0-2 cdrdao-1.2.5-1 cups-1:2.4.2-5 debuginfod-0.188-3 discount-2.2.7.c-1 dnsmasq-2.89-1 dolphin-22.12.2-1
dolphin-plugins-22.12.2-1 e2fsprogs-1.46.6-1 elfutils-0.188-3 elisa-22.12.2-1 erlang-nox-25.2-2 fakeroot-1.31-1 ffmpegthumbs-22.12.2-1
filelight-22.12.2-1 flatpak-1:1.15.2-1 gcc-12.2.1-2 gcc-libs-12.2.1-2 glibc-2.37-2 gmic-3.2.0-2 grantleetheme-22.12.2-1 gwenview-22.12.2-1
htop-3.2.2-1 hwinfo-22.2-2 imagemagick-7.1.0.61-1 k3b-1:22.12.2-1 kaccounts-integration-22.12.2-1 kaccounts-providers-22.12.2-1 kamera-22.12.2-1
kate-22.12.2-1 kcalc-22.12.2-1 kdeconnect-22.12.2-1 kdegraphics-mobipocket-22.12.2-1 kdegraphics-thumbnailers-22.12.2-1
kdenetwork-filesharing-22.12.2-1 keditbookmarks-22.12.2-1 kfind-22.12.2-1 kget-22.12.2-1 khelpcenter-22.12.2-1 kio-extras-22.12.2-1
kmime-22.12.2-1 konsole-22.12.2-1 kpmcore-22.12.2-1 ksanecore-22.12.2-1 ksystemlog-22.12.2-1 kwalletmanager-22.12.2-1 lapack-3.11.0-2
less-1:608-2 lib32-e2fsprogs-1.46.6-1 lib32-gcc-libs-12.2.1-2 lib32-glibc-2.37-2 lib32-libva-mesa-driver-22.3.5-1 lib32-mesa-22.3.5-1
lib32-openssl-1:3.0.8-0.1 lib32-vulkan-intel-22.3.5-1 lib32-vulkan-mesa-layers-22.3.5-1 libakonadi-22.12.2-1 libcamera-0.0.4-1 libcups-1:2.4.2-5
libelf-0.188-3 libgphoto2-2.5.30-2 libgusb-0.4.5-1 libimobiledevice-1.3.0-6 libjxl-0.8.1-1 libkcddb-22.12.2-1 libkdcraw-22.12.2-1
libkexiv2-22.12.2-1 libksane-22.12.2-1 libktorrent-22.12.2-1 libmspack-1:0.11alpha-1 libnl-3.7.0-3 libreoffice-still-7.4.5-1
libsidplayfp-2.4.2-1 libsysprof-capture-3.46.0-4 libtool-2.4.7+4+g1ec8fa28-2 libva-mesa-driver-22.3.5-1 libwpe-1.14.1-1 linux-api-headers-6.1.9-1
linux515-5.15.93-1 linux515-acpi_call-1.2.2-96 linux515-bbswitch-0.8-111 linux515-broadcom-wl-6.30.223.271-111 linux515-headers-5.15.93-1
linux515-r8168-8.050.03-42 linux515-rtl8723bu-20220818-32 linux515-tp_smapi-0.43-111 linux515-vhba-module-20211218-92 linux515-zfs-2.1.9-1
linux54-5.4.231-1 linux54-acpi_call-1.2.2-77 linux54-bbswitch-0.8-251 linux54-broadcom-wl-6.30.223.271-252 linux54-headers-5.4.231-1
linux54-r8168-8.050.03-31 linux54-rtl8723bu-20220818-25 linux54-tp_smapi-0.43-251 linux54-vhba-module-20211218-73 linux54-zfs-2.1.9-1
lmdb-0.9.30-1 manjaro-release-22.0.3-1 marble-common-22.12.2-1 memtest86+-6.10-1 mesa-22.3.5-1 mhwd-nvidia-525.89.02-1
mhwd-nvidia-470xx-470.161.03-2 mpfr-4.2.0-3 neovim-0.8.3-1 nodejs-19.6.0-1 noto-fonts-20230201-1 okular-22.12.2-1 openal-1.23.0-1
opencolorio-2.2.1-3 openpmix-4.2.3-1 openshadinglanguage-1.12.9.0-1 openssh-9.2p1-1 openssl-3.0.8-1 openssl-1.1-1.1.1.t-1 pamac-cli-10.4.3-3
pamac-gtk-10.4.3-3 partitionmanager-22.12.2-1 perl-html-parser-3.81-1 pipewire-1:0.3.65-6 poppler-23.02.0-1 poppler-data-0.4.12-1
poppler-glib-23.02.0-1 poppler-qt5-23.02.0-1 print-manager-22.12.2-1 python-cairo-1.23.0-3 python-cryptography-39.0.1-1
python-jaraco.context-4.3.0-1 python-jaraco.text-3.11.1-1 python-packaging-23.0-1 python-pylint-2.16.1-1 python-pyqt5-5.15.9-1
python-setuptools-1:67.2.0-1 python-tenacity-8.2.1-1 python-trove-classifiers-2023.2.8-1 python-zipp-3.13.0-1 qt5-base-5.15.8+kde+r181-1
qt5-wayland-5.15.8+kde+r58-1 re2-1:20230201-1 sdl2-2.26.3-1 signon-kwallet-extension-22.12.2-1 skanlite-22.12.2-1 spectacle-22.12.2-1
suitesparse-7.0.1-2 telegram-desktop-4.6.1-1 texinfo-7.0.2-2 thunderbird-102.7.2-1 tigervnc-1.13.0-1 upower-1.90.0-3 valgrind-3.19.0-7
vulkan-intel-22.3.5-1 vulkan-mesa-layers-22.3.5-1 webkit2gtk-2.38.4-1 webkit2gtk-4.1-2.38.4-1 wxwidgets-common-3.2.2-1 wxwidgets-gtk3-3.2.2-1
xorg-server-21.1.7-1 xorg-server-common-21.1.7-1 xorg-xwayland-22.1.7-2 yakuake-22.12.2-1 zfs-utils-2.1.9-1 zsh-5.9-3 zvbi-0.2.40-1
Total Download Size: 1109.18 MiB
Total Installed Size: 3315.57 MiB
Net Upgrade Size: -3.10 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
libreoffice-still-7.4.5-1-x86_64 144.3 MiB 37.4 MiB/s 00:04 [###########################################################] 100%
linux515-5.15.93-1-x86_64 100.2 MiB 39.5 MiB/s 00:03 [###########################################################] 100%
linux54-5.4.231-1-x86_64 72.3 MiB 39.4 MiB/s 00:02 [###########################################################] 100%
thunderbird-102.7.2-1-x86_64 51.5 MiB 39.0 MiB/s 00:01 [###########################################################] 100%
marble-common-22.12.2-1-x86_64 45.4 MiB 39.0 MiB/s 00:01 [###########################################################] 100%
gcc-12.2.1-2-x86_64 44.8 MiB 39.0 MiB/s 00:01 [###########################################################] 100%
erlang-nox-25.2-2-x86_64 44.3 MiB 38.6 MiB/s 00:01 [###########################################################] 100%
gcc-libs-12.2.1-2-x86_64 33.9 MiB 38.6 MiB/s 00:01 [###########################################################] 100%
linux515-headers-5.15.93-1-x86_64 31.8 MiB 38.3 MiB/s 00:01 [###########################################################] 100%
lib32-gcc-libs-12.2.1-2-x86_64 29.8 MiB 38.4 MiB/s 00:01 [###########################################################] 100%
telegram-desktop-4.6.1-1-x86_64 29.7 MiB 38.5 MiB/s 00:01 [###########################################################] 100%
linux54-headers-5.4.231-1-x86_64 26.7 MiB 38.5 MiB/s 00:01 [###########################################################] 100%
noto-fonts-20230201-1-any 26.5 MiB 38.0 MiB/s 00:01 [###########################################################] 100%
mesa-22.3.5-1-x86_64 26.3 MiB 38.2 MiB/s 00:01 [###########################################################] 100%
webkit2gtk-4.1-2.38.4-1-x86_64 24.0 MiB 37.7 MiB/s 00:01 [###########################################################] 100%
webkit2gtk-2.38.4-1-x86_64 23.9 MiB 38.3 MiB/s 00:01 [###########################################################] 100%
lib32-mesa-22.3.5-1-x86_64 23.8 MiB 37.9 MiB/s 00:01 [###########################################################] 100%
suitesparse-7.0.1-2-x86_64 20.8 MiB 38.1 MiB/s 00:01 [###########################################################] 100%
linux515-zfs-2.1.9-1-x86_64 13.7 MiB 16.4 MiB/s 00:01 [###########################################################] 100%
nodejs-19.6.0-1-x86_64 13.2 MiB 36.3 MiB/s 00:00 [###########################################################] 100%
qt5-base-5.15.8+kde+r181-1-x86_64 13.0 MiB 35.9 MiB/s 00:00 [###########################################################] 100%
linux515-rtl8723bu-20220818-32-x86_64 12.5 MiB 15.7 MiB/s 00:01 [###########################################################] 100%
linux54-zfs-2.1.9-1-x86_64 11.6 MiB 20.4 MiB/s 00:01 [###########################################################] 100%
valgrind-3.19.0-7-x86_64 11.4 MiB 35.7 MiB/s 00:00 [###########################################################] 100%
linux54-rtl8723bu-20220818-25-x86_64 11.0 MiB 10.7 MiB/s 00:01 [###########################################################] 100%
k3b-1:22.12.2-1-x86_64 11.0 MiB 35.6 MiB/s 00:00 [###########################################################] 100%
glibc-2.37-2-x86_64 9.9 MiB 36.1 MiB/s 00:00 [###########################################################] 100%
kate-22.12.2-1-x86_64 9.2 MiB 36.1 MiB/s 00:00 [###########################################################] 100%
imagemagick-7.1.0.61-1-x86_64 8.3 MiB 34.5 MiB/s 00:00 [###########################################################] 100%
binutils-2.40-4-x86_64 7.6 MiB 34.3 MiB/s 00:00 [###########################################################] 100%
gmic-3.2.0-2-x86_64 7.4 MiB 35.2 MiB/s 00:00 [###########################################################] 100%
okular-22.12.2-1-x86_64 7.1 MiB 34.2 MiB/s 00:00 [###########################################################] 100%
gwenview-22.12.2-1-x86_64 6.8 MiB 33.4 MiB/s 00:00 [###########################################################] 100%
neovim-0.8.3-1-x86_64 6.0 MiB 24.3 MiB/s 00:00 [###########################################################] 100%
kget-22.12.2-1-x86_64 5.7 MiB 32.7 MiB/s 00:00 [###########################################################] 100%
lib32-vulkan-intel-22.3.5-1-x86_64 5.6 MiB 33.7 MiB/s 00:00 [###########################################################] 100%
vulkan-intel-22.3.5-1-x86_64 5.3 MiB 31.7 MiB/s 00:00 [###########################################################] 100%
cups-1:2.4.2-5-x86_64 5.2 MiB 32.9 MiB/s 00:00 [###########################################################] 100%
openssl-3.0.8-1-x86_64 5.1 MiB 31.9 MiB/s 00:00 [###########################################################] 100%
khelpcenter-22.12.2-1-x86_64 4.8 MiB 31.4 MiB/s 00:00 [###########################################################] 100%
wxwidgets-gtk3-3.2.2-1-x86_64 4.6 MiB 31.7 MiB/s 00:00 [###########################################################] 100%
python-pyqt5-5.15.9-1-x86_64 4.3 MiB 32.5 MiB/s 00:00 [###########################################################] 100%
dolphin-22.12.2-1-x86_64 4.3 MiB 32.4 MiB/s 00:00 [###########################################################] 100%
libva-mesa-driver-22.3.5-1-x86_64 4.2 MiB 31.7 MiB/s 00:00 [###########################################################] 100%
lib32-libva-mesa-driver-22.3.5-1-x86_64 4.2 MiB 31.5 MiB/s 00:00 [###########################################################] 100%
lib32-glibc-2.37-2-x86_64 3.4 MiB 28.0 MiB/s 00:00 [###########################################################] 100%
libakonadi-22.12.2-1-x86_64 3.3 MiB 29.4 MiB/s 00:00 [###########################################################] 100%
zfs-utils-2.1.9-1-x86_64 3.0 MiB 4.47 MiB/s 00:01 [###########################################################] 100%
wxwidgets-common-3.2.2-1-x86_64 2.9 MiB 12.8 MiB/s 00:00 [###########################################################] 100%
aom-3.6.0-1-x86_64 2.7 MiB 14.5 MiB/s 00:00 [###########################################################] 100%
openshadinglanguage-1.12.9.0-1-x86_64 2.5 MiB 16.5 MiB/s 00:00 [###########################################################] 100%
lapack-3.11.0-2-x86_64 2.5 MiB 20.4 MiB/s 00:00 [###########################################################] 100%
skanlite-22.12.2-1-x86_64 2.4 MiB 20.3 MiB/s 00:00 [###########################################################] 100%
tigervnc-1.13.0-1-x86_64 2.3 MiB 20.0 MiB/s 00:00 [###########################################################] 100%
zsh-5.9-3-x86_64 2.2 MiB 24.8 MiB/s 00:00 [###########################################################] 100%
lib32-openssl-1:3.0.8-0.1-x86_64 2.2 MiB 23.7 MiB/s 00:00 [###########################################################] 100%
partitionmanager-22.12.2-1-x86_64 2.2 MiB 22.3 MiB/s 00:00 [###########################################################] 100%
linux515-r8168-8.050.03-42-x86_64 2.1 MiB 11.2 MiB/s 00:00 [###########################################################] 100%
ksystemlog-22.12.2-1-x86_64 2.1 MiB 26.2 MiB/s 00:00 [###########################################################] 100%
opencolorio-2.2.1-3-x86_64 2.0 MiB 23.9 MiB/s 00:00 [###########################################################] 100%
libjxl-0.8.1-1-x86_64 2041.4 KiB 24.0 MiB/s 00:00 [###########################################################] 100%
poppler-data-0.4.12-1-any 2014.5 KiB 23.7 MiB/s 00:00 [###########################################################] 100%
elisa-22.12.2-1-x86_64 1898.4 KiB 22.3 MiB/s 00:00 [###########################################################] 100%
openssl-1.1-1.1.1.t-1-x86_64 1803.6 KiB 24.1 MiB/s 00:00 [###########################################################] 100%
konsole-22.12.2-1-x86_64 1800.6 KiB 23.1 MiB/s 00:00 [###########################################################] 100%
flatpak-1:1.15.2-1-x86_64 1783.2 KiB 22.9 MiB/s 00:00 [###########################################################] 100%
xorg-server-21.1.7-1-x86_64 1770.1 KiB 22.4 MiB/s 00:00 [###########################################################] 100%
texinfo-7.0.2-2-x86_64 1607.5 KiB 22.4 MiB/s 00:00 [###########################################################] 100%
poppler-23.02.0-1-x86_64 1563.7 KiB 21.8 MiB/s 00:00 [###########################################################] 100%
ark-22.12.2-1-x86_64 1489.4 KiB 24.2 MiB/s 00:00 [###########################################################] 100%
linux515-broadcom-wl-6.30.223.271-111-x86_64 1452.6 KiB 12.9 MiB/s 00:00 [###########################################################] 100%
linux54-broadcom-wl-6.30.223.271-252-x86_64 1429.6 KiB 11.6 MiB/s 00:00 [###########################################################] 100%
spectacle-22.12.2-1-x86_64 1405.0 KiB 24.1 MiB/s 00:00 [###########################################################] 100%
libgphoto2-2.5.30-2-x86_64 1364.7 KiB 24.7 MiB/s 00:00 [###########################################################] 100%
kio-extras-22.12.2-1-x86_64 1255.7 KiB 21.5 MiB/s 00:00 [###########################################################] 100%
linux-api-headers-6.1.9-1-any 1225.1 KiB 23.9 MiB/s 00:00 [###########################################################] 100%
e2fsprogs-1.46.6-1-x86_64 1222.7 KiB 23.9 MiB/s 00:00 [###########################################################] 100%
linux54-r8168-8.050.03-31-x86_64 1134.5 KiB 17.6 MiB/s 00:00 [###########################################################] 100%
libgusb-0.4.5-1-x86_64 1128.3 KiB 20.8 MiB/s 00:00 [###########################################################] 100%
openssh-9.2p1-1-x86_64 1124.6 KiB 19.6 MiB/s 00:00 [###########################################################] 100%
qt5-wayland-5.15.8+kde+r58-1-x86_64 1121.4 KiB 21.9 MiB/s 00:00 [###########################################################] 100%
pipewire-1:0.3.65-6-x86_64 1030.4 KiB 20.1 MiB/s 00:00 [###########################################################] 100%
hwinfo-22.2-2-x86_64 1022.4 KiB 20.0 MiB/s 00:00 [###########################################################] 100%
kdeconnect-22.12.2-1-x86_64 1009.7 KiB 19.7 MiB/s 00:00 [###########################################################] 100%
kwalletmanager-22.12.2-1-x86_64 988.2 KiB 16.9 MiB/s 00:00 [###########################################################] 100%
sdl2-2.26.3-1-x86_64 987.4 KiB 20.5 MiB/s 00:00 [###########################################################] 100%
python-pylint-2.16.1-1-any 972.3 KiB 19.0 MiB/s 00:00 [###########################################################] 100%
xorg-xwayland-22.1.7-2-x86_64 908.6 KiB 17.7 MiB/s 00:00 [###########################################################] 100%
python-cryptography-39.0.1-1-x86_64 858.8 KiB 16.8 MiB/s 00:00 [###########################################################] 100%
openpmix-4.2.3-1-x86_64 837.7 KiB 16.4 MiB/s 00:00 [###########################################################] 100%
akonadi-contacts-22.12.2-1-x86_64 779.8 KiB 16.2 MiB/s 00:00 [###########################################################] 100%
filelight-22.12.2-1-x86_64 779.3 KiB 15.2 MiB/s 00:00 [###########################################################] 100%
libktorrent-22.12.2-1-x86_64 709.2 KiB 15.1 MiB/s 00:00 [###########################################################] 100%
kpmcore-22.12.2-1-x86_64 667.4 KiB 15.2 MiB/s 00:00 [###########################################################] 100%
openal-1.23.0-1-x86_64 655.1 KiB 12.8 MiB/s 00:00 [###########################################################] 100%
kcalc-22.12.2-1-x86_64 654.1 KiB 14.9 MiB/s 00:00 [###########################################################] 100%
cdrdao-1.2.5-1-x86_64 650.0 KiB 13.5 MiB/s 00:00 [###########################################################] 100%
cairo-1.17.8-2-x86_64 636.8 KiB 2.59 MiB/s 00:00 [###########################################################] 100%
python-setuptools-1:67.2.0-1-any 588.7 KiB 11.5 MiB/s 00:00 [###########################################################] 100%
elfutils-0.188-3-x86_64 575.2 KiB 12.8 MiB/s 00:00 [###########################################################] 100%
libkcddb-22.12.2-1-x86_64 560.7 KiB 13.7 MiB/s 00:00 [###########################################################] 100%
libelf-0.188-3-x86_64 549.6 KiB 12.5 MiB/s 00:00 [###########################################################] 100%
libcamera-0.0.4-1-x86_64 532.6 KiB 13.0 MiB/s 00:00 [###########################################################] 100%
kfind-22.12.2-1-x86_64 494.5 KiB 12.1 MiB/s 00:00 [###########################################################] 100%
print-manager-22.12.2-1-x86_64 455.0 KiB 11.1 MiB/s 00:00 [###########################################################] 100%
yakuake-22.12.2-1-x86_64 428.0 KiB 10.4 MiB/s 00:00 [###########################################################] 100%
mpfr-4.2.0-3-x86_64 427.3 KiB 10.4 MiB/s 00:00 [###########################################################] 100%
libtool-2.4.7+4+g1ec8fa28-2-x86_64 412.5 KiB 9.37 MiB/s 00:00 [###########################################################] 100%
libnl-3.7.0-3-x86_64 409.3 KiB 9.99 MiB/s 00:00 [###########################################################] 100%
dnsmasq-2.89-1-x86_64 409.2 KiB 9.29 MiB/s 00:00 [###########################################################] 100%
lib32-vulkan-mesa-layers-22.3.5-1-x86_64 408.3 KiB 4.58 MiB/s 00:00 [###########################################################] 100%
dolphin-plugins-22.12.2-1-x86_64 403.5 KiB 9.85 MiB/s 00:00 [###########################################################] 100%
vulkan-mesa-layers-22.3.5-1-x86_64 384.9 KiB 5.61 MiB/s 00:00 [###########################################################] 100%
zvbi-0.2.40-1-x86_64 373.7 KiB 9.12 MiB/s 00:00 [###########################################################] 100%
libimobiledevice-1.3.0-6-x86_64 356.9 KiB 8.71 MiB/s 00:00 [###########################################################] 100%
keditbookmarks-22.12.2-1-x86_64 349.5 KiB 8.53 MiB/s 00:00 [###########################################################] 100%
poppler-glib-23.02.0-1-x86_64 289.6 KiB 7.07 MiB/s 00:00 [###########################################################] 100%
linux515-tp_smapi-0.43-111-x86_64 279.0 KiB 6.34 MiB/s 00:00 [###########################################################] 100%
libcups-1:2.4.2-5-x86_64 275.4 KiB 6.72 MiB/s 00:00 [###########################################################] 100%
kmime-22.12.2-1-x86_64 275.2 KiB 7.26 MiB/s 00:00 [###########################################################] 100%
lib32-e2fsprogs-1.46.6-1-x86_64 236.0 KiB 6.23 MiB/s 00:00 [###########################################################] 100%
linux54-tp_smapi-0.43-251-x86_64 225.9 KiB 3.29 MiB/s 00:00 [###########################################################] 100%
poppler-qt5-23.02.0-1-x86_64 223.7 KiB 5.90 MiB/s 00:00 [###########################################################] 100%
pamac-gtk-10.4.3-3-x86_64 193.6 KiB 4.73 MiB/s 00:00 [###########################################################] 100%
kamera-22.12.2-1-x86_64 182.5 KiB 4.95 MiB/s 00:00 [###########################################################] 100%
libksane-22.12.2-1-x86_64 165.7 KiB 4.37 MiB/s 00:00 [###########################################################] 100%
kdenetwork-filesharing-22.12.2-1-x86_64 163.9 KiB 4.33 MiB/s 00:00 [###########################################################] 100%
re2-1:20230201-1-x86_64 159.2 KiB 4.20 MiB/s 00:00 [###########################################################] 100%
linux515-vhba-module-20211218-92-x86_64 154.0 KiB 2.84 MiB/s 00:00 [###########################################################] 100%
htop-3.2.2-1-x86_64 147.3 KiB 3.89 MiB/s 00:00 [###########################################################] 100%
upower-1.90.0-3-x86_64 146.5 KiB 4.33 MiB/s 00:00 [###########################################################] 100%
libsidplayfp-2.4.2-1-x86_64 144.3 KiB 3.92 MiB/s 00:00 [###########################################################] 100%
debuginfod-0.188-3-x86_64 136.8 KiB 3.11 MiB/s 00:00 [###########################################################] 100%
libkexiv2-22.12.2-1-x86_64 136.6 KiB 3.61 MiB/s 00:00 [###########################################################] 100%
linux54-vhba-module-20211218-73-x86_64 133.9 KiB 1557 KiB/s 00:00 [###########################################################] 100%
linux515-bbswitch-0.8-111-x86_64 131.0 KiB 3.88 MiB/s 00:00 [###########################################################] 100%
blas-3.11.0-2-x86_64 130.5 KiB 3.54 MiB/s 00:00 [###########################################################] 100%
kaccounts-integration-22.12.2-1-x86_64 123.8 KiB 3.66 MiB/s 00:00 [###########################################################] 100%
less-1:608-2-x86_64 121.7 KiB 3.30 MiB/s 00:00 [###########################################################] 100%
baloo-widgets-22.12.2-1-x86_64 116.8 KiB 2.65 MiB/s 00:00 [###########################################################] 100%
linux54-bbswitch-0.8-251-x86_64 116.4 KiB 1819 KiB/s 00:00 [###########################################################] 100%
python-cairo-1.23.0-3-x86_64 94.0 KiB 2.78 MiB/s 00:00 [###########################################################] 100%
lmdb-0.9.30-1-x86_64 92.0 KiB 2.49 MiB/s 00:00 [###########################################################] 100%
linux515-acpi_call-1.2.2-96-x86_64 90.3 KiB 2.20 MiB/s 00:00 [###########################################################] 100%
perl-html-parser-3.81-1-x86_64 81.3 KiB 2.15 MiB/s 00:00 [###########################################################] 100%
pamac-cli-10.4.3-3-x86_64 78.9 KiB 2.08 MiB/s 00:00 [###########################################################] 100%
linux54-acpi_call-1.2.2-77-x86_64 77.1 KiB 1752 KiB/s 00:00 [###########################################################] 100%
kaccounts-providers-22.12.2-1-x86_64 76.4 KiB 2.02 MiB/s 00:00 [###########################################################] 100%
discount-2.2.7.c-1-x86_64 75.3 KiB 732 KiB/s 00:00 [###########################################################] 100%
ksanecore-22.12.2-1-x86_64 71.8 KiB 2.12 MiB/s 00:00 [###########################################################] 100%
fakeroot-1.31-1-x86_64 69.7 KiB 1935 KiB/s 00:00 [###########################################################] 100%
python-packaging-23.0-1-any 65.2 KiB 1977 KiB/s 00:00 [###########################################################] 100%
memtest86+-6.10-1-any 62.9 KiB 1748 KiB/s 00:00 [###########################################################] 100%
grantleetheme-22.12.2-1-x86_64 62.4 KiB 1559 KiB/s 00:00 [###########################################################] 100%
libmspack-1:0.11alpha-1-x86_64 54.6 KiB 1474 KiB/s 00:00 [###########################################################] 100%
libwpe-1.14.1-1-x86_64 53.8 KiB 1453 KiB/s 00:00 [###########################################################] 100%
libsysprof-capture-3.46.0-4-x86_64 45.4 KiB 1227 KiB/s 00:00 [###########################################################] 100%
libkdcraw-22.12.2-1-x86_64 43.5 KiB 1086 KiB/s 00:00 [###########################################################] 100%
kdegraphics-thumbnailers-22.12.2-1-x86_64 39.4 KiB 1158 KiB/s 00:00 [###########################################################] 100%
cblas-3.11.0-2-x86_64 35.6 KiB 962 KiB/s 00:00 [###########################################################] 100%
xorg-server-common-21.1.7-1-x86_64 31.6 KiB 930 KiB/s 00:00 [###########################################################] 100%
python-tenacity-8.2.1-1-any 30.6 KiB 899 KiB/s 00:00 [###########################################################] 100%
ffmpegthumbs-22.12.2-1-x86_64 28.3 KiB 944 KiB/s 00:00 [###########################################################] 100%
alsa-card-profiles-1:0.3.65-6-x86_64 27.7 KiB 749 KiB/s 00:00 [###########################################################] 100%
mhwd-nvidia-470xx-470.161.03-2-any 23.7 KiB 641 KiB/s 00:00 [###########################################################] 100%
mhwd-nvidia-525.89.02-1-any 23.6 KiB 591 KiB/s 00:00 [###########################################################] 100%
kdegraphics-mobipocket-22.12.2-1-x86_64 20.0 KiB 377 KiB/s 00:00 [###########################################################] 100%
python-jaraco.text-3.11.1-1-any 17.8 KiB 538 KiB/s 00:00 [###########################################################] 100%
manjaro-release-22.0.3-1-any 15.2 KiB 506 KiB/s 00:00 [###########################################################] 100%
python-trove-classifiers-2023.2.8-1-any 14.5 KiB 393 KiB/s 00:00 [###########################################################] 100%
signon-kwallet-extension-22.12.2-1-x86_64 14.0 KiB 411 KiB/s 00:00 [###########################################################] 100%
python-zipp-3.13.0-1-any 13.0 KiB 325 KiB/s 00:00 [###########################################################] 100%
python-jaraco.context-4.3.0-1-any 10.0 KiB 295 KiB/s 00:00 [###########################################################] 100%
Total (173/173) 1109.2 MiB 25.5 MiB/s 00:44 [###########################################################] 100%
(173/173) checking keys in keyring [###########################################################] 100%
(173/173) checking package integrity [###########################################################] 100%
(173/173) loading package files [###########################################################] 100%
(173/173) checking for file conflicts [###########################################################] 100%
(173/173) checking available disk space [###########################################################] 100%
warning: could not get file information for usr/share/locale/ca/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/cs/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/da/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/de/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/eo/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/es/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/fi/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/fr/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/hu/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/id/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/it/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/ms/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/nl/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/pl/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/pt/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/sr/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/sv/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/tr/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/uk/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/vi/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/locale/zh_CN/LC_MESSAGES/e2fsprogs.mo
warning: could not get file information for usr/share/cups/doc/da/
warning: could not get file information for usr/share/cups/doc/da/index.html
warning: could not get file information for usr/share/cups/doc/de/
warning: could not get file information for usr/share/cups/doc/de/index.html
warning: could not get file information for usr/share/cups/doc/es/
warning: could not get file information for usr/share/cups/doc/es/index.html
warning: could not get file information for usr/share/cups/doc/fr/
warning: could not get file information for usr/share/cups/doc/fr/index.html
warning: could not get file information for usr/share/cups/doc/ja/
warning: could not get file information for usr/share/cups/doc/ja/index.html
warning: could not get file information for usr/share/cups/doc/pt_BR/
warning: could not get file information for usr/share/cups/doc/pt_BR/index.html
warning: could not get file information for usr/share/cups/doc/ru/
warning: could not get file information for usr/share/cups/doc/ru/index.html
warning: could not get file information for usr/share/locale/ca/cups_ca.po
warning: could not get file information for usr/share/locale/cs/cups_cs.po
warning: could not get file information for usr/share/locale/da/cups_da.po
warning: could not get file information for usr/share/locale/de/cups_de.po
warning: could not get file information for usr/share/locale/es/cups_es.po
warning: could not get file information for usr/share/locale/fr/cups_fr.po
warning: could not get file information for usr/share/locale/it/cups_it.po
warning: could not get file information for usr/share/locale/ja/cups_ja.po
warning: could not get file information for usr/share/locale/pt_BR/cups_pt_BR.po
warning: could not get file information for usr/share/locale/ru/cups_ru.po
warning: could not get file information for usr/share/locale/zh_CN/cups_zh_CN.po
(1/4) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/4) Removing linux initcpios...
(3/4) Remove DKMS modules
==> dkms remove --no-depmod vmware-workstation/17.0.1_21139696 -k 5.4.230-1-MANJARO
==> dkms remove --no-depmod vmware-workstation/17.0.1_21139696 -k 5.15.91-1-MANJARO
==> depmod 5.4.230-1-MANJARO
==> depmod 5.15.91-1-MANJARO
(4/4) Remove Thunderbird Distribution Settings
( 1/173) upgrading libsysprof-capture [###########################################################] 100%
( 2/173) upgrading linux-api-headers [###########################################################] 100%
( 3/173) upgrading glibc [###########################################################] 100%
Generating locales...
en_GB.UTF-8... done
es_ES.UTF-8... done
Generation complete.
( 4/173) upgrading gcc-libs [###########################################################] 100%
( 5/173) upgrading e2fsprogs [###########################################################] 100%
( 6/173) upgrading openssl [###########################################################] 100%
( 7/173) upgrading libcups [###########################################################] 100%
( 8/173) upgrading libelf [###########################################################] 100%
( 9/173) upgrading lib32-glibc [###########################################################] 100%
( 10/173) upgrading mesa [###########################################################] 100%
( 11/173) upgrading libnl [###########################################################] 100%
( 12/173) upgrading qt5-base [###########################################################] 100%
( 13/173) upgrading libtool [###########################################################] 100%
( 14/173) upgrading openal [###########################################################] 100%
( 15/173) upgrading cairo [###########################################################] 100%
( 16/173) upgrading lib32-gcc-libs [###########################################################] 100%
( 17/173) upgrading lib32-e2fsprogs [###########################################################] 100%
( 18/173) upgrading lib32-openssl [###########################################################] 100%
( 19/173) upgrading qt5-wayland [###########################################################] 100%
( 20/173) upgrading signon-kwallet-extension [###########################################################] 100%
( 21/173) upgrading libimobiledevice [###########################################################] 100%
( 22/173) upgrading upower [###########################################################] 100%
( 23/173) upgrading mpfr [###########################################################] 100%
( 24/173) upgrading noto-fonts [###########################################################] 100%
( 25/173) upgrading re2 [###########################################################] 100%
( 26/173) upgrading aom [###########################################################] 100%
( 27/173) upgrading sdl2 [###########################################################] 100%
( 28/173) upgrading kaccounts-integration [###########################################################] 100%
( 29/173) upgrading libakonadi [###########################################################] 100%
( 30/173) upgrading kmime [###########################################################] 100%
( 31/173) upgrading grantleetheme [###########################################################] 100%
( 32/173) upgrading akonadi-contacts [###########################################################] 100%
( 33/173) upgrading alsa-card-profiles [###########################################################] 100%
( 34/173) upgrading ark [###########################################################] 100%
( 35/173) upgrading lmdb [###########################################################] 100%
( 36/173) upgrading poppler [###########################################################] 100%
( 37/173) upgrading poppler-qt5 [###########################################################] 100%
( 38/173) upgrading baloo-widgets [###########################################################] 100%
( 39/173) upgrading binutils [###########################################################] 100%
( 40/173) upgrading blas [###########################################################] 100%
( 41/173) upgrading cblas [###########################################################] 100%
( 42/173) upgrading cdrdao [###########################################################] 100%
New optional dependencies for cdrdao
gtkmm3: for gcdmaster [installed]
( 43/173) upgrading cups [###########################################################] 100%
New optional dependencies for cups
libusb: for usb printer backend [installed]
( 44/173) upgrading debuginfod [###########################################################] 100%
( 45/173) upgrading discount [###########################################################] 100%
( 46/173) upgrading dnsmasq [###########################################################] 100%
( 47/173) upgrading libkexiv2 [###########################################################] 100%
( 48/173) upgrading kio-extras [###########################################################] 100%
( 49/173) upgrading dolphin [###########################################################] 100%
( 50/173) upgrading dolphin-plugins [###########################################################] 100%
( 51/173) upgrading elfutils [###########################################################] 100%
( 52/173) upgrading elisa [###########################################################] 100%
( 53/173) upgrading erlang-nox [###########################################################] 100%
( 54/173) upgrading fakeroot [###########################################################] 100%
( 55/173) upgrading ffmpegthumbs [###########################################################] 100%
( 56/173) upgrading filelight [###########################################################] 100%
( 57/173) upgrading libcamera [###########################################################] 100%
( 58/173) upgrading pipewire [###########################################################] 100%
( 59/173) upgrading flatpak [###########################################################] 100%
( 60/173) upgrading gcc [###########################################################] 100%
( 61/173) upgrading openpmix [###########################################################] 100%
New optional dependencies for openpmix
openpmix-docs: for documentation
( 62/173) upgrading libgphoto2 [###########################################################] 100%
( 63/173) upgrading lapack [###########################################################] 100%
( 64/173) upgrading gmic [###########################################################] 100%
( 65/173) upgrading libkdcraw [###########################################################] 100%
( 66/173) upgrading gwenview [###########################################################] 100%
( 67/173) upgrading htop [###########################################################] 100%
( 68/173) upgrading perl-html-parser [###########################################################] 100%
( 69/173) upgrading hwinfo [###########################################################] 100%
( 70/173) upgrading imagemagick [###########################################################] 100%
( 71/173) upgrading libkcddb [###########################################################] 100%
( 72/173) upgrading k3b [###########################################################] 100%
( 73/173) upgrading kaccounts-providers [###########################################################] 100%
( 74/173) upgrading kamera [###########################################################] 100%
( 75/173) upgrading kate [###########################################################] 100%
( 76/173) upgrading kcalc [###########################################################] 100%
( 77/173) upgrading kdeconnect [###########################################################] 100%
( 78/173) upgrading kdegraphics-mobipocket [###########################################################] 100%
( 79/173) upgrading poppler-data [###########################################################] 100%
( 80/173) upgrading kdegraphics-thumbnailers [###########################################################] 100%
( 81/173) upgrading kdenetwork-filesharing [###########################################################] 100%
( 82/173) upgrading keditbookmarks [###########################################################] 100%
( 83/173) upgrading kfind [###########################################################] 100%
( 84/173) upgrading kget [###########################################################] 100%
( 85/173) upgrading khelpcenter [###########################################################] 100%
( 86/173) upgrading konsole [###########################################################] 100%
( 87/173) upgrading kpmcore [###########################################################] 100%
( 88/173) upgrading poppler-glib [###########################################################] 100%
( 89/173) upgrading ksanecore [###########################################################] 100%
( 90/173) upgrading ksystemlog [###########################################################] 100%
( 91/173) upgrading kwalletmanager [###########################################################] 100%
( 92/173) upgrading less [###########################################################] 100%
( 93/173) upgrading lib32-libva-mesa-driver [###########################################################] 100%
( 94/173) upgrading lib32-mesa [###########################################################] 100%
( 95/173) upgrading lib32-vulkan-intel [###########################################################] 100%
( 96/173) upgrading vulkan-mesa-layers [###########################################################] 100%
( 97/173) upgrading lib32-vulkan-mesa-layers [###########################################################] 100%
( 98/173) upgrading libgusb [###########################################################] 100%
( 99/173) upgrading libjxl [###########################################################] 100%
(100/173) upgrading libksane [###########################################################] 100%
(101/173) upgrading libktorrent [###########################################################] 100%
(102/173) upgrading libmspack [###########################################################] 100%
(103/173) upgrading libreoffice-still [###########################################################] 100%
New optional dependencies for libreoffice-still
gtk4: for GTK4 integration (experimental) [installed]
qt6-base: for QT6 desktop integration [installed]
(104/173) upgrading libsidplayfp [###########################################################] 100%
(105/173) upgrading libva-mesa-driver [###########################################################] 100%
(106/173) upgrading libwpe [###########################################################] 100%
(107/173) upgrading linux515 [###########################################################] 100%
(108/173) upgrading linux515-acpi_call [###########################################################] 100%
> Updating module dependencies...
(109/173) upgrading linux515-bbswitch [###########################################################] 100%
(110/173) upgrading linux515-broadcom-wl [###########################################################] 100%
(111/173) upgrading linux515-headers [###########################################################] 100%
(112/173) upgrading linux515-r8168 [###########################################################] 100%
(113/173) upgrading linux515-rtl8723bu [###########################################################] 100%
(114/173) upgrading linux515-tp_smapi [###########################################################] 100%
(115/173) upgrading linux515-vhba-module [###########################################################] 100%
(116/173) upgrading zfs-utils [###########################################################] 100%
New optional dependencies for zfs-utils
python: pyzfs and extra utilities [installed]
(117/173) upgrading linux515-zfs [###########################################################] 100%
(118/173) upgrading linux54 [###########################################################] 100%
(119/173) upgrading linux54-acpi_call [###########################################################] 100%
(120/173) upgrading linux54-bbswitch [###########################################################] 100%
(121/173) upgrading linux54-broadcom-wl [###########################################################] 100%
(122/173) upgrading linux54-headers [###########################################################] 100%
(123/173) upgrading linux54-r8168 [###########################################################] 100%
(124/173) upgrading linux54-rtl8723bu [###########################################################] 100%
(125/173) upgrading linux54-tp_smapi [###########################################################] 100%
(126/173) upgrading linux54-vhba-module [###########################################################] 100%
(127/173) upgrading linux54-zfs [###########################################################] 100%
(128/173) upgrading manjaro-release [###########################################################] 100%
(129/173) upgrading marble-common [###########################################################] 100%
(130/173) upgrading memtest86+ [###########################################################] 100%
(131/173) upgrading mhwd-nvidia [###########################################################] 100%
(132/173) upgrading mhwd-nvidia-470xx [###########################################################] 100%
(133/173) upgrading neovim [###########################################################] 100%
(134/173) upgrading nodejs [###########################################################] 100%
(135/173) upgrading okular [###########################################################] 100%
(136/173) upgrading opencolorio [###########################################################] 100%
(137/173) upgrading openshadinglanguage [###########################################################] 100%
(138/173) upgrading openssh [###########################################################] 100%
(139/173) upgrading openssl-1.1 [###########################################################] 100%
(140/173) upgrading pamac-cli [###########################################################] 100%
(141/173) upgrading pamac-gtk [###########################################################] 100%
(142/173) upgrading partitionmanager [###########################################################] 100%
(143/173) upgrading print-manager [###########################################################] 100%
(144/173) upgrading python-cairo [###########################################################] 100%
(145/173) upgrading python-cryptography [###########################################################] 100%
(146/173) upgrading python-jaraco.context [###########################################################] 100%
(147/173) upgrading python-jaraco.text [###########################################################] 100%
(148/173) upgrading python-packaging [###########################################################] 100%
(149/173) upgrading python-pylint [###########################################################] 100%
(150/173) upgrading python-pyqt5 [###########################################################] 100%
(151/173) upgrading python-trove-classifiers [###########################################################] 100%
(152/173) upgrading python-setuptools [###########################################################] 100%
(153/173) upgrading python-tenacity [###########################################################] 100%
(154/173) upgrading python-zipp [###########################################################] 100%
(155/173) upgrading skanlite [###########################################################] 100%
(156/173) upgrading spectacle [###########################################################] 100%
(157/173) upgrading suitesparse [###########################################################] 100%
(158/173) upgrading telegram-desktop [###########################################################] 100%
(159/173) upgrading texinfo [###########################################################] 100%
(160/173) upgrading thunderbird [###########################################################] 100%
(161/173) upgrading tigervnc [###########################################################] 100%
(162/173) upgrading valgrind [###########################################################] 100%
(163/173) upgrading vulkan-intel [###########################################################] 100%
(164/173) upgrading webkit2gtk [###########################################################] 100%
(165/173) upgrading webkit2gtk-4.1 [###########################################################] 100%
(166/173) upgrading wxwidgets-common [###########################################################] 100%
(167/173) upgrading wxwidgets-gtk3 [###########################################################] 100%
(168/173) upgrading xorg-server-common [###########################################################] 100%
(169/173) upgrading xorg-server [###########################################################] 100%
(170/173) upgrading xorg-xwayland [###########################################################] 100%
(171/173) upgrading yakuake [###########################################################] 100%
(172/173) upgrading zsh [###########################################################] 100%
(173/173) upgrading zvbi [###########################################################] 100%
( 1/26) Creating system user accounts...
( 2/26) Reloading system manager configuration...
( 3/26) Updating udev hardware database...
( 4/26) Creating temporary files...
( 5/26) Reloading device manager configuration...
( 6/26) Arming ConditionNeedsUpdate...
( 7/26) Updating the MIME type database...
( 8/26) Updating module dependencies...
( 9/26) Restoring locales
(10/26) Install DKMS modules
==> dkms install --no-depmod vmware-workstation/17.0.1_21139696 -k 5.4.231-1-MANJARO
==> dkms install --no-depmod vmware-workstation/17.0.1_21139696 -k 5.15.93-1-MANJARO
==> depmod 5.15.93-1-MANJARO
==> depmod 5.4.231-1-MANJARO
(11/26) Restarting cronie for libc upgrade...
(12/26) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.93-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.231-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
(13/26) Refreshing PackageKit...
(14/26) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Found Windows Boot Manager on /dev/sda1@/efi/Microsoft/Boot/bootmgfw.efi
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
(15/26) Reloading system bus configuration...
(16/26) Warn about old perl modules
(17/26) Updating fontconfig cache...
(18/26) Probing GDK-Pixbuf loader modules...
(19/26) Compiling GSettings XML schema files...
(20/26) Updating icon theme caches...
(21/26) Modifying 'locale-gen'
(22/26) Hiding redundant menu entries
(23/26) Updating the info directory file...
(24/26) Copy Thunderbird Distribution Settings
(25/26) Updating the desktop file MIME type cache...
(26/26) Updating X fontdir indices...
