Hello everyone,
I hope I posted in the correct category please correct if wrong.
First of all I love Linux and Manjaro and I don’t want to change back to windows. My problem is kinda hard to explain, because sometimes everything works just fine but often everything is kinda borked. If something crashes or hangs I try to access Ctrl+alt+F1-5. The problem is most of the time I cannot login. Username works but then it’s just a curser blinking and I cannot type anymore. Same is when I cann login to Manjaro at some point it just hangs I do not know why. But sometimes everything just works for hours. So here I am trying to fix manjaro but don’t know how or what to to do find the error.
If you need any more information please don’t hesitate to ask for any information you need I try to provide the information as possible. Because sometimes I cannot access anything because it gets stuck so often. Because of that Iam writing with my Smartphone.
Yeah I hope someone can help me.
Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=631e2465-8a38-4194-baf8-668e15b897b3 rw quiet
nvme_core.default_ps_max_latency_us=5500 apparmor=1 security=apparmor
resume=UUID=b087a8cd-0b68-4cee-a32a-3207805ef1cd udev.log_priority=3
acpi=force apm=power_off sysrq_always_enabled=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 3603 date: 03/19/2021
RAM: total: 31.27 GiB used: 2.61 GiB (8.4%)
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 4 MiB bogomips: 115233
Speed: 2195 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2195 2: 2055 3: 2056 4: 2056 5: 2199 6: 2079 7: 2202 8: 2198 9: 2119
10: 2056 11: 2437 12: 2199 13: 2201 14: 2200 15: 2826 16: 2199
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 0f:00.0 chip-ID: 1002:731f
class-ID: 0300
loaded: modesetting alternate: amdgpu,ati,fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 6400x1440 s-dpi: 96 s-size: 1693x381mm (66.7x15.0")
s-diag: 1735mm (68.3")
Monitor-1: DP-1 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-3: HDMI-1 res: 1920x1080 hz: 60 dpi: 69 size: 708x398mm (27.9x15.7")
diag: 812mm (32")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.41.0 5.13.12-1-MANJARO
LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: Creative Labs driver: snd_hda_intel v: kernel bus-ID: 06:00.0
chip-ID: 1102:0010 class-ID: 0403
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0f:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 11:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 07:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 08:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 09:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:5
Local Storage: total: 6.04 TiB used: 353.18 GiB (5.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 2TB
lanes: 4 type: SSD serial: <filter> rev: RKT401.2 temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 960 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 2B6QCXP7 temp: 26.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM000-2AE166
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5980 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: SMI (STMicroelectronics)
model: USB DISK size: 117.19 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 1100 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 353.18 GiB (19.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 631e2465-8a38-4194-baf8-668e15b897b3
label: NO_LABEL uuid: B60E-4C44
ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: b087a8cd-0b68-4cee-a32a-3207805ef1cd
ID-1: /dev/sda1 maj-min: 8:1 size: 3.64 TiB fs: ntfs label: Daten
uuid: 70F44C8FF44C598C
ID-2: /dev/sdb1 maj-min: 8:17 size: 37.16 GiB fs: exfat label: Ventoy
uuid: 4E21-0000
ID-3: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 3FAB-7709
ID-4: /dev/sdb3 maj-min: 8:19 size: 80 GiB fs: ntfs label: Daten
uuid: CECCCF45CCCF2695
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 1-4:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-4.3:4 info: Logitech G910 Orion Spectrum Mechanical Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 046d:c335 class-ID: 0300
serial: <filter>
Device-2: 1-4.4:7 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-3: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 1-5.1:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-5.2:8 info: Corsair Commander PRO type: HID
driver: corsair-cpro,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip-ID: 1b1c:0c10 class-ID: 0300 serial: <filter>
Device-2: 1-6:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 2-4:2 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Device-1: 2-4.1:3 info: Silicon Motion - Taiwan (formerly Feiya ) USB DISK
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 504mA chip-ID: 090c:2000 class-ID: 0806 serial: <filter>
Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 33.4 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 38.0 C
Fan Speeds (RPM): fan-2: 1244 fan-3: 1244 fan-4: 1253 fan-5: 1261
gpu: amdgpu fan: 0
Processes: 384 Uptime: 2m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: pacman: 1542 lib: 406
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
Welcome to the forum!
Seraph91P:
What you are describing would be consistent with a local denial of service, or otherwise put, one or multiple processes are getting stuck and are driving up the load on the CPU to such an extent that every key press and every move of the mouse becomes just one more CPU instruction to be added to the top of the pile of instructions that the CPU is trying to process.
Now, given the randomness of the occurrence of this phenomenon on your computer, I am personally inclined to suspect a hardware failure. I have experienced this type of behavior myself a few years ago, on a refurbished machine where both the power supply and the onboard graphics adapter were dying.
However, it could also be as simple as an intermittently failing memory module, or a connector that got dislodged somehow. So if possible, open up your computer housing and check whether your memory modules, drive connector and PCI(e) peripherals are still properly seated.
While you’re at it, also make sure there’s no dust in the fans, because overheating can do this too. Then next, if the problem returns, try booting up with memtest86+ and let it run for at least 6 hours.
If the problem then still returns, then we know it’s hardware ─ memtest86 doesn’t load anything other than itself into memory. But overheating, a failing memory module and/or a failing power supply are the three most likely culprits, in my experience.
Hello,
Thank you for your fast response. I will try memtest and post the results. The only thing I find cannot understand is. I only recently switched to linux and windows was running just fine no problem what so ever. So I will report back when I run memtest for 6+ hours.
Thank you again
Regards
Hello,
So let memtest run over night. It completed with no error over a time span of 5h22min. Since I cannot attach images or post links I don’t know how to upload the picture.
So I don’t think it’s a hardware issue. What else could it be?
Regards
Hi,
Here is the requestet output from: inxi --admin --verbosity=7 --filter --no-host --width
class-ID: 0300
screens: 1
diag: 685mm (27")
diag: 686mm (27")
diag: 812mm (32")
LLVM 12.0.1)
class-ID: 0403
uuid: 4E21-0000
uuid: 3FAB-7709
serial: <filter>
class-ID: e001
mem: 38.0 C
gpu: amdgpu fan: 0
inxi: 3.3.06
What should I do now?
Fabby
30 August 2021 16:33
7
Seraph91P:
5.13.12-1-MANJARO
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
(At a minimum the Linux has multiple kernels section, at a maximum everything but the “What’s this Upstream / Downstream business” section)
Then install at least one LTS kernel and boot from that. (If you don’t know how, shout out!)
If the problem persists in an LTS kernel, please read this:
Difficulty: ★★☆☆☆
This tutorial was created because people are using a hard power off during freezes, so this will teach you how to turn off your computer when everything is frozen using softer means.
So whenever you see someone saying they had to “Power Off” or “Hard Reset” their system without doing a REISUB, please send them here!
If you’re reading this in response to a question, please click the green link above this text to bring you to the full unabridged text of the tutorial…
Because every time you press the power button, your system gets damaged more and more and if you’re beyond 10 times doing that, you’re in for a reinstall with your new-found knowledge!
Hey,
Thank you for your fast response. REISUB is already enabled and used a few times.
LTS Kernel I will install if my pc lets me and test if that helps.
Is there anything else I could do to test or something to find the culprit?
Regards
Hey,
so REISUB is still my best friend. Tried the LTS Kernel 5.10. Atleast it boots completely but everything is running like its on drugs. The Settings app opens like in a split second but when I click on a menu point. You see that it has registered the click but nothing happens. After a minute or so the menu opens and I can correct my Screen Settings. Another example all the programs that are running should be visible in my taskbar? For example I can search for steam, but I can only find my chat window in search. This window opens up but its not shown in taskbar. So Steam is running in background somehow? This list goes on and on. Everything kinda seems off.
Btw, inxi --admin --verbosity=7 --filter --no-host --width got stuck here. Did not continue.
Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
RAM: total: 31.33 GiB used: 3.06 GiB (9.8%)
L2: 4 MiB bogomips: 115251
Speed: 3192 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3192 2: 2868 3: 1916 4: 1872 5: 2200 6: 2200 7: 2199 8: 2199 9: 2050
10: 2050 11: 2200 12: 2200 13: 2200 14: 2200 15: 3023 16: 2891
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Monitor-1: DisplayPort-0 res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-3: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 69
size: 708x398mm (27.9x15.7") diag: 812mm (32")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.40.0 5.10.60-1-MANJARO
LLVM 12.0.1)
class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
IP v6: <filter> type: tentative noprefixroute scope: link
Local Storage: total: 6.04 TiB used: 375.29 GiB (6.1%)
lanes: 4 type: SSD serial: <filter> rev: RKT401.2 temp: 40.9 C scheme: GPT
lanes: 4 type: SSD serial: <filter> rev: 2B6QCXP7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 375.29 GiB (20.9%)
uuid: 4E21-0000
uuid: 3FAB-7709
serial: <filter>
class-ID: e001
Dunno what to do next.
Thanks again for your help, please continue to guide me.
Fabby
31 August 2021 17:47
11
Seraph91P:
The constant power-downs have severely damaged your system:
Backup all your data and reinstall with your new-found knowledge from the N00b tutorial…
OMFG, THANK YOU.
I would never have gone to the UEFI but to reinstall. Now I found the culprit. Somehow FastBoot got enabled. Now since I have disabled it everything is running butter smooth. For now at least.
Thanks again.
system
Closed
4 September 2021 06:01
13
