Using 21.06 minimal.
Boots fine on rpi 4.
Unfortunately it does not boot rpi 3 B.
No led activity, no signal to screen, no ssh.
Obviously no logs to post here.
dietpi aarch64 boots fine on rpi 3 but I would like to stick to manjaro.
Could someone point me to right direction please?
Thanks in advance.
P.S. By mistake I posted same on the announcement of the release. Maybe an admin can remove it. Sorry for that.
Strit
22 June 2021 14:31
2
If there’s no LED activity, it means that the board has not even started it’s own rpi-eeprom, which is started before anything else, including OS, is started.
So that would mean a dead board, if there’s no LED’s lighting up when you give it power.
Thank you replying.
The board works fine. As I said it boots on dietpi with no issues.
Led’s come up but with no activity. Just leds on.
Any pointers?
Strit
22 June 2021 14:42
4
mjrus3r:
If this is true, at least 1 LED would turn on.
I am in the process of installing the minimal image here to test.
I am sorry. I edited my post since I was not clear with the leds.
LEDs turn on. But then nothing.
I waited for 10 mins, powered off, then on again.
Rewrote the sd card 3 times. Nothing.
An update. Rather confusing.
I’ve tried the rpi 3 with 21.06 XFCE. It boots.
But then hangs at …unwanted updates or something of the likes.
I am so sorry to bother you with all that.
Strit
22 June 2021 21:04
8
Okay. All the Raspberry Pi images have been rebuilt, which should fix this.
You can find them on the manjaro.org website. (still version 21.06)
Thank you so much for your actions.
I can confirm that the image is now booting the rpi3.
Be well.
system
Closed
8 July 2021 03:56
10
