Nmcli doesn’t work to identify the hardware, it was my mistake. We need something like lsusb but for sdio, but don’t know.
Anyone can help?
Anyone can help?
I just found out from this Q & A, that H96 Max RK3399 wifi module is QCA9377, Bluetooth 4.1
But I don’t know how to install that driver and change the dtb part.
Install this
sudo pacman -Syy kvim2-firmware
If x99.dtb is good your ap6255 will work.
I tried to install AP6255 but it didn’t work.
However, I used my Vim3 image with the u-boot nano-pc-t4. dtb Rockpro64, kernel 5.10 it seems wifi works out of the box. But I don’t know which driver that is being used.
How can I check which driver is being used by my internal wifi on Manjaro?
If I used nmcli,
wifi (ath10k_sdio)
Is this the driver?
I cannot find it in /lib/firmware/brcm/
EDIT:
I found “ath10k” folder in /lib/firmware
After transferring the folder to the other sd card now my internal wifi is activated
Now how can I activate the bluetooth? how to check if bluetooth is recognized?
what is the command similar to nmcli for bluetooth?
Your wifi driver is atheros and to know about Bluetooth
dmesg |grep -i Bluetooth
Will give you some info.
On Manjaro I didn’t get any result
but on Armbian I got this result (after installing bluetooth module via armbian-config, but bluetooth is not working)
$ dmesg |grep -i Bluetooth
[ 31.679004] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 31.679017] Bluetooth: BNEP filters: protocol multicast
[ 31.679038] Bluetooth: BNEP socket layer initialized
I don’t know what is the driver of this bluetooth?
Report these:
rfkill list
lsmod | grep -i blue
Lsmod
This is the result from Manjaro:
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
$ lsmod |grep -i blue
bluetooth 634880 13 btrtl,btqca,btintel,hci_uart,btbcm,bnep
ecdh_generic 16384 1 bluetooth
rfkill 36864 7 bluetooth,cfg80211
$ Lsmod
bash: Lsmod: command not found
$ lsmod
Module Size Used by
bnep 32768 2
joydev 32768 0
zram 36864 1
nls_ascii 16384 1
ath10k_sdio 36864 0
hantro_vpu 86016 0
ath10k_core 372736 1 ath10k_sdio
rockchip_rga 24576 0
ath 45056 1 ath10k_core
mac80211 561152 1 ath10k_core
v4l2_h264 16384 1 hantro_vpu
v4l2_mem2mem 40960 2 hantro_vpu,rockchip_rga
videobuf2_dma_contig 24576 1 hantro_vpu
videobuf2_vmalloc 20480 1 hantro_vpu
videobuf2_dma_sg 20480 1 rockchip_rga
videobuf2_memops 20480 3 videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_dma_sg
cfg80211 401408 3 ath,mac80211,ath10k_core
videobuf2_v4l2 32768 3 hantro_vpu,rockchip_rga,v4l2_mem2mem
hci_uart 147456 0
videobuf2_common 61440 4 videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem
btqca 20480 1 hci_uart
videodev 282624 5 videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,v4l2_mem2mem
btrtl 24576 1 hci_uart
btbcm 24576 1 hci_uart
btintel 28672 1 hci_uart
mc 61440 5 videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem
fusb302 28672 0
tcpm 53248 1 fusb302
rockchip_saradc 20480 0
dw_hdmi_cec 16384 0
typec 57344 1 tcpm
ecc 32768 1 ecdh_generic
snd_soc_simple_card 24576 0
snd_soc_audio_graph_card 24576 0
gpio_keys 20480 0
industrialio_triggered_buffer 16384 1 rockchip_saradc
snd_soc_simple_card_utils 28672 2 snd_soc_audio_graph_card,snd_soc_simple_card
snd_soc_es8316 45056 1
pwm_fan 20480 0
kfifo_buf 16384 1 industrialio_triggered_buffer
rtc_rk808 20480 1
sch_fq_codel 20480 2
crypto_user 16384 0
fuse 126976 3
ip_tables 32768 0
x_tables 45056 1 ip_tables
This is the result from Armbian:
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
$ lsmod | grep -i blue
bluetooth 630784 13 btrtl,btqca,btintel,hci_uart,btbcm,bnep
$ Lsmod
$ lsmod
Module Size Used by
aufs 245760 0
bnep 32768 2
governor_performance 16384 0
ath10k_sdio 32768 0
snd_soc_simple_card 24576 1
snd_soc_audio_graph_card 20480 2
snd_soc_rockchip_i2s 24576 4
ath10k_core 376832 1 ath10k_sdio
snd_soc_hdmi_codec 20480 1
hantro_vpu 86016 0
rockchip_vdec 28672 0
snd_seq_midi 20480 0
mac80211 884736 1 ath10k_core
snd_seq_midi_event 16384 1 snd_seq_midi
snd_soc_core 237568 6 snd_soc_hdmi_codec,snd_soc_audio_graph_card,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card,snd_soc_es8316
snd_rawmidi 40960 1 snd_seq_midi
v4l2_h264 16384 2 rockchip_vdec,hantro_vpu
snd_pcm_dmaengine 20480 1 snd_soc_core
videobuf2_dma_contig 24576 2 rockchip_vdec,hantro_vpu
hci_uart 143360 0
ath 40960 1 ath10k_core
snd_pcm 118784 4 snd_soc_hdmi_codec,snd_soc_core,snd_soc_es8316,snd_pcm_dmaengine
snd_seq 81920 2 snd_seq_midi,snd_seq_midi_event
v4l2_mem2mem 40960 3 rockchip_vdec,hantro_vpu,rockchip_rga
cfg80211 864256 3 ath,mac80211,ath10k_core
videobuf2_v4l2 32768 4 rockchip_vdec,hantro_vpu,rockchip_rga,v4l2_mem2mem
snd_seq_device 20480 3 snd_seq,snd_seq_midi,snd_rawmidi
videobuf2_common 61440 5 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem
rc_cec 16384 0
libarc4 16384 1 mac80211
snd_timer 40960 2 snd_seq,snd_pcm
videodev 299008 6 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,v4l2_mem2mem
panfrost 65536 6
fusb302 28672 0
dw_hdmi_i2s_audio 16384 0
dw_hdmi_cec 16384 0
snd 90112 13 snd_seq,snd_seq_device,snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm,snd_rawmidi
mc 61440 6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem
pwm_fan 20480 0
gpu_sched 40960 1 panfrost
typec 57344 1 tcpm
joydev 32768 0
soundcore 16384 1 snd
cpufreq_dt 20480 0
zram 36864 2
ip_tables 32768 0
autofs4 45056 2
realtek 24576 1
rockchipdrm 135168 12
analogix_dp 49152 1 rockchipdrm
dw_hdmi 53248 2 dw_hdmi_i2s_audio,rockchipdrm
dw_mipi_dsi 20480 1 rockchipdrm
drm_kms_helper 245760 4 dw_mipi_dsi,rockchipdrm,dw_hdmi,analogix_dp
cec 73728 3 drm_kms_helper,dw_hdmi_cec,dw_hdmi
rc_core 57344 3 rc_cec,cec
dwmac_rk 28672 0
stmmac_platform 24576 1 dwmac_rk
drm 573440 19 gpu_sched,drm_kms_helper,dw_mipi_dsi,rockchipdrm,dw_hdmi,panfrost,analogix_dp
stmmac 196608 2 stmmac_platform,dwmac_rk
pcs_xpcs 20480 1 stmmac
drm_panel_orientation_quirks 20480 1 drm
Ok
Rfkill reports is not blocked so no problems there but radio is not up. From second report seems you have rtl, Intel, qca and bcm drivers too many for just a device. Only last two could work.
Kill rtl and Intel if you know howto but better ask for support in general forum as this is not arm specific and I don’t know how to proceed.
Ok many thanks for your suggestion, I’ll ask in general forum
While waiting for cavalry you can try
Sudo modprobe -r btrtl btintel btbcm
dmesg | egrep -i ‘blue|firm’
$ sudo modprobe -r btrtl btintel btbcm
modprobe: FATAL: Module btrtl is in use.
$ dmesg | egrep -i ‘blue|firm’
bash: firm’: command not found
Have a look here
@SickOS You are amazing…!!!
Many Thanks for your link, finally I figure it out how to fix the Bluetooth. The answer is I have to change the dtb to dts, and then replace the bluetooth compatible driver to QCA9377. Now Bluetooth is working perfectly on my H96 Max - RK3399 Box.
Here’s the step by step:
dtc -I dtb -O dts /your/dtb/location/rk3399-rockpro64.dtb -o /your/dts/location/rk3399-rockpro64.dts
nano /your/dts/location/rk3399-rockpro64.dts
bluetooth {
compatible = "brcm,bcm43438-bt";
Into this:
bluetooth {
compatible = "qcom,qca9377-bt";
Now save your rk3399-rockpro64.dts
Rename “rk3399-rockpro64.dts” into “rk3399-H96Max.dts”
Let’s convert the dts back to dtb
dtc -I dts -O dtb /your/dts/location/rk3399-H96Max.dts -o /your/dtb/location/rk3399-H96Max.dtb
Now copy and paste your new dtb into your SDCard dtb folder
Now change the configuration text to your new “rk3399-H96Max.dtb”
Insert your SD Card to your RK3399-H96 Max Box
Your box should now be able to run bluetooth without a problem
Enjoy!
Big Thanks to maz-1 from Github:
https://github.com/maz-1/h96-pro-plus-armbian-stuff/search?q=QCA9377
If you need my dtb and dts, you can download it from my post on Armbian, I cannot attach any document here:
Now, my last question the only think that is not solved yet is how to make the Audio Jack working. @SickOS : Do you have any idea to fix the audio jack issue?
Happy to see the link worked.
No idea about sound, in fact I don’t have it in Manjaro. Check with alsamixer if audio-jack is muted.
Yes, it is muted. But I cannot change the Mute to unmute by pressing M and Up arrow
In Alsamixer, my Right Headphone Mixer RLIN is off, I cannot turn it on by pressing M
also the DAC Soft Ramp is off as well.
Just to let you know that I have two output in Volume Control:
The HDMI is working, but the Audio Jack isn’t.
I have Allwinner H5 box, it has those two outputs in Volume Control and both are working very well on Manjaro. Therefore, I am pretty sure that there must be a setting that is missing to activate those Audio Jack.
It seems that the ES8316 is muted by default.
There is this solution on github, but I don’t know how to apply it?
here’s my aplay report:
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: rockchiprk3399 [rockchip,rk3399], device 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 [ff890000.i2s-ES8316 HiFi ES8316 HiFi-0]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 1: hdmisound [hdmi-sound], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 [ff8a0000.i2s-i2s-hifi i2s-hifi-0]
Subdevices: 0/1
Help would be appreciated
It seems you have to use mixer to switch on with these commands
mixer $rockchiprk3399 ‘Right Headphone Mixer Right DAC’ on
mixer $rockchiprk3399 ‘Left Headphone Mixer Left DAC’ on
User can change it using amixer
instead of the commands.
