Manjaro ARM Beta9 of Phosh for PinePhone!
The Manjaro ARM project is proud to announce our nineth BETA release for the PinePhone running Phosh!
This image is running the 5.12 kernel from Megi, which is designed for the PinePhone.
Features:
- Firefox uses a dedicated configuration and plays videos on Youtube pretty well
- Camera app with access to back and front camera, including autofocus
- Auto-Rotate function we had to remove
- Welcome wizard for easy setup of the device
- We have now a working Torch in the quick-access-menu
- Prime phone functions working, including resume from deep-sleep and free speaking
- Recording of audio works
- Most applications got added to
scale-to-fit - Haptic feedback functions are given
- Optimized keyboard layout for terminal
- Maps working with geolocate
- Volume buttons working
- Sensors fully functional
- Easy access to Bluetooth, Wlan, Rotate and Mobile functions via quick settings
- Default branch is
arm-stable. This can be changed by editing/etc/pacman-mirrors.conf - usage of callaudiod for better audio experience with calls
- This image uses a Crust enabled uboot
Changes since Beta8
- we use now 5.12.2 kernel series with patches by Megi. This extends also battery-life once again
- uboot got updated to support 5.12 kernel
- Megapixels is now at v1.0.1
- Siglo is at 0.7.0
- fixes to atinout
- updates to callaudiod, calls, chatty, phosh
- feedbackd supports more fine theme adjustments
- pipewire updates
- mesa updated to 21.0.3
- Pamac 10.1 is now mobile ready
- we switched to Qt5 with KDE patches
- eg25-manager got enhanced gps management
- more Gnome 40.1 updates including Shell 40.1 and Mutter 40.1
A detailed list of package changes can be found here.
Currently broken:
- Mic-Mute function in calls not working
- GPS may not work as it should
Known issues
- it may take longer to wake up from deep-sleep mode when a call is incoming. Most of the time that call will vibrate only.
- UI becomes unresponsive after a while.
- Lots of apps are still missing or are not mobile friendly yet.
Download:
About the device:
PinePhone:
Perhaps youâre in a line of work where security is a must, or a hard-core Linux enthusiast, or perhaps youâve just got enough of Android and iOS and youâre ready for something else â the PinePhone may be the next Phone for you. Powered by the same Quad-Core ARM Cortex A53 64-Bit SOC used in our popular PINE A64 Single Board Computer, the PinePhone runs mainline Linux as well as anything else youâll get it to run.
The purpose of the PinePhone isnât only to deliver a functioning Linux phone to end-users, but also to actively create a market for such a device, as well as to support existing and well established Linux-on-Phone projects. All major Linux Phone-oriented projects, as well as other FOSS OSâ, are represented on the PinePhone and developers work together on our platform to bring support this this community driven device.
Order
Pinephones Beta Edition are still on stock. Visit the Pine64 Store
How to install:
Download the image/xz file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn the to an SD card (8 GB or larger).
The PinePhone should recognize the SD card as a bootable device and boot from it.
The premade users are:
User: manjaro
Password: 123456
User: root
password: root
Donate!
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Bugtracker
If you face issues with this editon, please open a new issue on our bug-tracker
Development Changelog
We will list our progress to Beta10 here
- Beta9 (2021-05-10) Download
- based on stable branch
