Manjaro ARM Beta27 of Phosh for PinePhone!
The Manjaro ARM project is proud to announce our twenty seventh BETA release for the PinePhone running Phosh!
Those images run the 5.19 kernel from Megi.
Features:
- Firefox uses a dedicated configuration and plays videos on Youtube pretty well
- Camera app with access to back and front camera, including autofocus
- Auto-Rotate function and manual rotate
- Welcome wizard for easy setup of the device
- We have now a working Torch in the quick-access-menu
- Prime phone functions working, including resume from deep-sleep and free speaking
- Recording of audio works
- Most applications got added to
scale-to-fit - Haptic feedback functions are given
- Optimized keyboard layout for terminal
- Maps working with geolocate
- Volume buttons working
- Sensors fully functional
- Easy access to Bluetooth, Wlan, Rotate and Mobile functions via quick settings
- Default branch is
arm-stable. This can be changed by editing/etc/pacman-mirrors.conf - usage of callaudiod for better audio experience with calls
- This image uses a Crust enabled uboot (Pinephone only)
Changes since Beta26
Kernel got updated to 5.19.8 which brings in the following fixes:
- fix breakage in 8723cs caused by Linux API changes in wireless stack in 5.19.2
- add reboot to maskrom support for Pinephone Pro
- fix various rt5640 codec issues: megi's PinePhone Development Log
- decouple camera ISP1 and DRM on RK3399 (fixes lack of display when rear camera is not probed)
- fix longstanding issue with 44.1kHz sample rate playback not working correctly after playing 48kHz audio on RK3399 (Pinephone Pro)
- Pamac got updated to 10.4.2
- Firefox got updated to 104.0.2
- Mesa got renewed to 22.1.7
- Phosh is now at 0.21.0
- Phoc got renewed to 0.21.1
- Phosh-Mobile-Settings got added
Megapixels gained initial PinephonePro support.
- older installs may want to install megapixels-ppp
A detailed list of package changes can be found here.
Currently broken:
- GPS may not work as it should
Known issues
- During a Call the Mic can’t be muted on Pinephone and PinephonePro
- UI becomes unresponsive after a while.
- Doing a recording may result in noisy audio savings
- Lots of apps are still missing or are not mobile friendly yet.
Download:
About the device:
PinePhone:
Perhaps you’re in a line of work where security is a must, or a hard-core Linux enthusiast, or perhaps you’ve just got enough of Android and iOS and you’re ready for something else – the PinePhone may be the next Phone for you. Powered by the same Quad-Core ARM Cortex A53 64-Bit SOC used in our popular PINE A64 Single Board Computer, the PinePhone runs mainline Linux as well as anything else you’ll get it to run.
The purpose of the PinePhone isn’t only to deliver a functioning Linux phone to end-users, but also to actively create a market for such a device, as well as to support existing and well established Linux-on-Phone projects. All major Linux Phone-oriented projects, as well as other FOSS OS’, are represented on the PinePhone and developers work together on our platform to bring support this this community driven device.
Order
Pinephones Beta Edition are still on stock. Visit the Pine64 Store
How to install:
Download the image/xz file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn the to an SD card (8 GB or larger).
The PinePhone should recognize the SD card as a bootable device and boot from it.
The premade users are:
User: manjaro
Password: 123456
User: root
password: root
Donate!
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Bugtracker
If you face issues with this editon, please open a new issue on our bug-tracker
Development Changelog
We will list our progress to Beta28 here
- Beta27 (2022-09-12) Download
- based on stable branch
- Dev (2022-09-21) Download
- based on unstable branch
- Pipewire got updated to 0.3.58
- eg25-manager now respects driver rules
- Firefox is now at 105.0
- Gnome-Calls got updated to 43.0 including a fix to not autostart into UI
- NetworkManager got renewed to 1.40.0
- Squeekboard is now at 1.20.0
- libcall-ui 0.0.5 includes the new round design
- We updated the kernel to 5.19.9
- Dev (2022-10-21) Download
- Pipewire got updated to 0.3.59
- Firefox is now at 106.0
- We updated the kernel to 6.0.2
- V4L2 apparently doesn’t have as strict backwards compatibility guarantees, and mainline changed the media graph for Rockchip ISPs, hence Megapixels support on PPP for cameras doesn’t work anymore
- eg25-manager got updated to 0.4.5
- gstreamer is now at 1.20.4
- modemmanager got renewed to 1.18.12
- Dev (2022-10-30) Download
- Dev (2022-11-04) Download
- based on *unstable branch
- Chatty is now at 0.7.0-rc1
- eg25-manager got updated to 0.4.6
- Firefox is now at 106.0.3
- modemmanager got renewed to 1.20.0
- networkmanager is now at 1.40.2
- We updated the kernel to 6.0.3
Gnome got updated to 43
- initial setup doesn’t launch anymore. 42 adaptive version is not supported due to libsoup3 incompability
- Pamac and libpamac got updated to support Gnome 43
