Freshly burned and tested DEV build from today also stuck and unusable at the “K” logo
The latest image (23-03-2021) boots from my PinePhone.
Why do I only see Dev (2021-02-11) and not the latest 23-03-2021 image? Shouldn’t it be listed next in the Development Changelog section?
Nightly changelogs/builds aren’t being updated on this page, you should check out the GitHub page.
Boots here also
Thanks muvori, that makes sense.
Same here. On the serial console I was expecting to see failed systemd units, but I found none, yet when I tried to restart sddm and then ran systemctl status sddm I noticed the message
Auth: sddm-helper exited with 11
I didn’t get any further than that yet. Anyway, I highly recommend a serial concole cable, it is litterally the only way of finding out what your pinephone is actually doing in such a situation.
With the help of pamac I did a complete upgrade including AUR packages. After that, the phone boots just fine. Obviously, the pinephone firmware depends on stuff that is in AUR. I haven’t investigated further, I have to admit.
We don’t install any AUR packages by default.
What packages did you have from the AUR?
