Here is one reason why you should update to 01.002 at least:
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="fast/poweroff"
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Response: [ERROR]
The 01.001 version doesn’t support that new feature, as it was added in 01.002 firmware.
Here a short snippet of the log for eg25-manager:
[manjaro@manjaro-arm ~]$ journalctl -b | grep eg25
Aug 29 11:48:49 manjaro-arm systemd[1]: /usr/lib/systemd/system/eg25-manager.service:15: Unknown key name 'ProtectedKernelModules' in section 'Service', ignoring.
Aug 29 11:48:49 manjaro-arm systemd[1]: /usr/lib/systemd/system/eg25-manager.service:20: Failed to parse /proc/ protection mode, ignoring: true
Aug 29 11:48:49 manjaro-arm systemd[1]: /usr/lib/systemd/system/eg25-manager.service:21: Unknown key name 'ProtectDevices' in section 'Service', ignoring.
Aug 29 11:48:49 manjaro-arm systemd[1]: /usr/lib/systemd/system/eg25-manager.service:26: Unknown key name 'ProtectKernelLog' in section 'Service', ignoring.
Aug 29 11:48:54 manjaro-arm eg25manager[3830]: Opening config file: /usr/share/eg25-manager/pine64,pinephone-1.2.toml
Aug 29 11:48:54 manjaro-arm eg25manager[3830]: Starting modem...
Aug 29 11:48:55 manjaro-arm eg25manager[3830]: Executed power-on/off sequence
Aug 29 11:48:55 manjaro-arm eg25manager[3830]: taking systemd sleep inhibitor
Aug 29 11:48:55 manjaro-arm dbus-daemon[3827]: [system] Activating via systemd: service name='org.freedesktop.ModemManager1' unit='dbus-org.freedesktop.ModemManager1.service' requested by ':1.7' (uid=0 pid=3830 comm="/usr/bin/eg25manager ")
Aug 29 11:48:55 manjaro-arm eg25manager[3830]: oFono vanished from D-Bus
Aug 29 11:48:55 manjaro-arm eg25manager[3830]: inhibitor sleep fd is 21
Aug 29 11:48:58 manjaro-arm eg25manager[3830]: ModemManager appeared on D-Bus
Aug 29 11:49:05 manjaro-arm eg25manager[3830]: Response: [RDY]
Aug 29 11:49:05 manjaro-arm eg25manager[3830]: taking systemd sleep inhibitor (blocking)
Aug 29 11:49:05 manjaro-arm eg25manager[3830]: inhibitor block fd is 22
Aug 29 11:49:05 manjaro-arm eg25manager[3830]: Response: [+CFUN: 1]
Aug 29 11:49:06 manjaro-arm eg25manager[3830]: Response: [+CPIN: READY
Aug 29 11:49:08 manjaro-arm eg25manager[3830]: Response: [+QIND: SMS DONE]
Aug 29 11:49:08 manjaro-arm eg25manager[3830]: Response: [+QIND: PB DONE]
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager object `/org/freedesktop/ModemManager1/Modem/0' added
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Modem3gpp.ProfileManager' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Firmware' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Modem3gpp' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Time' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Voice' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Adding new modem `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Sending command: AT+QGMR
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Messaging' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Modem3gpp.Ussd' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Signal' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Location' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Adding new modem with location capabilities `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Simple' found on object `/org/freedesktop/ModemManager1/Modem/0'
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Response: [EG25GGBR07A08M2G_01.001.01.001
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Sending command: AT+QDAI?
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Response: [+QDAI: 1,1,0,1,0,0,1,1
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="risignaltype"
Aug 29 11:49:15 manjaro-arm eg25manager[3830]: Response: [+QCFG: "risignaltype","physical"
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="ims"
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Response: [+QCFG: "ims",1,1
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="apready"
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Response: [+QCFG: "apready",1,0,500
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="urc/ri/ring"
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Response: [+QCFG: "urc/ri/ring","pulse",120,1000,5000,"off",1
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="urc/ri/smsincoming"
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Response: [+QCFG: "urc/ri/smsincoming","pulse",120,1
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="urc/ri/other"
Aug 29 11:49:16 manjaro-arm eg25manager[3830]: Response: [+QCFG: "urc/ri/other","off",1,1
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="urc/delay"
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Response: [+QCFG: "urc/delay",0
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="urc/cache"
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Response: [+QCFG: "urc/cache",0
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="urc/ri/pin"
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Response: [+QCFG: "urc/ri/pin",uart_ri
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Sending command: AT+QURCCFG="urcport"
Aug 29 11:49:17 manjaro-arm eg25manager[3830]: Response: [+QURCCFG: "urcport","all"
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Sending command: AT+QSCLK=1
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Response: [OK]
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSXTRA?
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Response: [+QGPSXTRA: 1
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="gnssconfig"
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "gnssconfig",4
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="odpcontrol"
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "odpcontrol",0
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="dpoenable"
Aug 29 11:49:18 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "dpoenable",1
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="gpsnmeatype"
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "gpsnmeatype",31
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="glonassnmeatype"
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "glonassnmeatype",7
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="galileonmeatype"
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "galileonmeatype",0
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="beidounmeatype"
Aug 29 11:49:19 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "beidounmeatype",0
Aug 29 11:49:20 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:20 manjaro-arm eg25manager[3830]: Sending command: AT+QGPSCFG="autogps"
Aug 29 11:49:20 manjaro-arm eg25manager[3830]: Response: [+QGPSCFG: "autogps",0
Aug 29 11:49:20 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="fast/poweroff"
Aug 29 11:49:20 manjaro-arm eg25manager[3830]: Response: [ERROR]
Aug 29 11:49:21 manjaro-arm eg25manager[3830]: Response: [ERROR]
Aug 29 11:49:21 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:21 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="fast/poweroff"
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Command QCFG retried 4 times, aborting...
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="sleepind/level"
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Response: [+QCFG: "sleepind/level",0
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="wakeupin/level"
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Response: [+QCFG: "wakeupin/level",0
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Got a different result than expected, changing value...
Aug 29 11:49:22 manjaro-arm eg25manager[3830]: Expected: [0,0]
Aug 29 11:49:23 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:23 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="wakeupin/level",0,0
Aug 29 11:49:23 manjaro-arm eg25manager[3830]: Response: [ERROR]
Aug 29 11:49:24 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:24 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="wakeupin/level",0,0
Aug 29 11:49:24 manjaro-arm eg25manager[3830]: GNSS assistance upload started...
Aug 29 11:49:24 manjaro-arm eg25manager[3830]: GNSS assistance upload step (1/9): disabling GNSS engine through ModemManager
Aug 29 11:49:24 manjaro-arm eg25manager[3830]: GNSS assistance upload step (2/9): disabling GNSS engine through AT+QGPS
Aug 29 11:49:24 manjaro-arm eg25manager[3830]: Response: [ERROR
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="wakeupin/level",0,0
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Response: [ERROR]
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Command QCFG retried 4 times, aborting...
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="ApRstLevel"
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Response: [+QCFG: "ApRstLevel",1
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Sending command: AT+QCFG="ModemRstLevel"
Aug 29 11:49:25 manjaro-arm eg25manager[3830]: Response: [+QCFG: "ModemRstLevel",1
Aug 29 11:49:26 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:26 manjaro-arm eg25manager[3830]: Sending command: AT+QGPS?
Aug 29 11:49:26 manjaro-arm eg25manager[3830]: Response: [+QGPS: 0
Aug 29 11:49:26 manjaro-arm eg25manager[3830]: Executed soft sleep sequence
Aug 29 11:49:26 manjaro-arm eg25manager[3830]: GNSS assistance upload step (3/9): fetching assistance data
Aug 29 11:49:26 manjaro-arm eg25manager[3830]: GNSS assistance data contains 0 bytes,check network connection.
Aug 29 11:49:26 manjaro-arm eg25manager[3830]: Rescheduling upload because of failure in 30s
Aug 29 11:49:56 manjaro-arm eg25manager[3830]: GNSS assistance upload started...
Aug 29 11:49:56 manjaro-arm eg25manager[3830]: GNSS assistance upload step (1/9): disabling GNSS engine through ModemManager
Aug 29 11:49:56 manjaro-arm eg25manager[3830]: GNSS assistance upload step (2/9): disabling GNSS engine through AT+QGPS
Aug 29 11:49:56 manjaro-arm eg25manager[3830]: Executed soft wake sequence
Aug 29 11:49:56 manjaro-arm eg25manager[3830]: Sending command: AT+QGPS?
Aug 29 11:49:56 manjaro-arm eg25manager[3830]: Response: [+QGPS: 0
