Manjaro ARM Beta12 with Phosh (PinePhone)
@Planter : which version of lxc are you using currently? I’m not too familiar with Arch Linux and I’m trying to find out which version I need and how I can replace my current version with the older one.
I used tardis.tiny-vps to download lxc-1:4.0.6-1aarch64.pkg.tar.xz and then install via sudo pacman -U PATHTODOWNLOAD.tar.xz
I think i had to restart afterwords for anbox to work.
sudo pacman -U http://tardis.tiny-vps.com/aarm/packages/l/lxc/lxc-1%3A4.0.6-1-aarch64.pkg.tar.xz
Thank you @Planter. Anbox is starting up again. Currently running apps fails. Trying another shutdown and startup. I’m hopeful. Without your help I don’t think I’ld find this solution. Thanks @Darksky too for a shorter command. I used Planter’s method though, but others can use your command.
I’m using Anbox for Whatsapp. Anbox doesn’t start as it did before the upgrade that broke it. The splash screen seems to hang. Closing it and clicking the Anbox icon again brings the apps screen. F-Droid works, but Whatsapp fails and seems to kill Anbox. Giving up for now and wait until it is fixed by Manjaro.
And now suddenly it works! Thanks all!
I had the same issue, no calls after deep sleep. The way I fixed it was to upgrade to the latest modem firmware: Release Yocto 3.3.2 update + USB Audio support · Biktorgj/pinephone_modem_sdk · GitHub
Yes, the alternative firmware is more flexible than stock. I just pushed some fixes to our unstable branch. Tomorrows daily build might ship those, so people can test.
It looks like https://danctnix.arikawa-hi.me/waydroid-20210730-1-aarch64.pkg.tar.xz page doesn’t exist anymore.
Simply install it via waydroid from our repos.
