Manjaro ARM Beta 24 with Phosh (PinePhone / PinePhonePro)
Manjaro ARM Beta24 of Phosh for PinePhone!
The Manjaro ARM project is proud to announce our twenty fourth BETA release for the PinePhone running Phosh!
Those images run the 5.18 kernel from Megi.
Features:
  • Firefox uses a dedicated configuration and plays videos on Youtube pretty well
  • Camera app with access to back and front camera, including autofocus (only PinePhone)
  • Auto-Rotate function and manual rotate
  • Welcome wizard for easy setup of the device
  • We have now a working Torch in the quick-access-menu
  • Prime phone functions working, including resume from deep-sleep and free speaking
  • Recording of audio works
  • Most applications got added to scale-to-fit
  • Haptic feedback functions are given
  • Optimized keyboard layout for terminal
  • Maps working with geolocate
  • Volume buttons working
  • Sensors fully functional
  • Easy access to Bluetooth, Wlan, Rotate and Mobile functions via quick settings
  • Default branch is arm-stable. This can be changed by editing /etc/pacman-mirrors.conf
  • usage of callaudiod for better audio experience with calls
  • This image uses a Crust enabled uboot
Changes since Beta23
  • Kernel is now at 5.18.0
  • Chatty got updated to 0.6.4
  • We updated the ALSA UCM profile for PP
  • Pipewire is at 0.3.51
  • callaudiod got updated to 0.1.4
  • gnome-calls is now at 42.0
  • most Gnome packages got updated to 42.1
  • Firefox is at 100.0.2
  • Pamac got updated to support Gnome 42
    • libpamac got needed AUR fixes
  • Phosh and Phoc support now gestures
  • Mesa got updated to 22.0.4
  • Systemd is at 251
A detailed list of package changes can be found here.
Currently broken:
  • GPS may not work as it should
Known issues
  • Cameras are not accessible to users on PinephonePro
  • UI becomes unresponsive after a while.
  • Doing a recording may result in noisy audio savings
  • Lots of apps are still missing or are not mobile friendly yet.
Download:
Device Phosh
PinePhone Beta24
PinePhone Nightly
About the device:
PinePhone:
Perhaps you’re in a line of work where security is a must, or a hard-core Linux enthusiast, or perhaps you’ve just got enough of Android and iOS and you’re ready for something else – the PinePhone may be the next Phone for you. Powered by the same Quad-Core ARM Cortex A53 64-Bit SOC used in our popular PINE A64 Single Board Computer, the PinePhone runs mainline Linux as well as anything else you’ll get it to run.
The purpose of the PinePhone isn’t only to deliver a functioning Linux phone to end-users, but also to actively create a market for such a device, as well as to support existing and well established Linux-on-Phone projects. All major Linux Phone-oriented projects, as well as other FOSS OS’, are represented on the PinePhone and developers work together on our platform to bring support this this community driven device.
Order
Pinephones Beta Edition are still on stock. Visit the Pine64 Store
How to install:
Download the image/xz file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn the to an SD card (8 GB or larger).
The PinePhone should recognize the SD card as a bootable device and boot from it.
The premade users are:
User: manjaro
Password: 123456
User: root
password: root
Donate!
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Bugtracker
If you face issues with this editon, please open a new issue on our bug-tracker
Development Changelog
We will list our progress to Beta25 here
  • Beta24 (2022-06-05) Download
    • based on stable branch
  • Dev (2022-06-20) Download
    • based on unstable branch
    • Pipewire got updated to 0.3.52
    • Chatty is at 0.6.6
    • Firefox got renewed to 101
    • Gnome packages are now at 42.2
    • Kernel is now at 5.18.3
    • Mesa is at 22.1.1
    • Pamac and libpamac got renewed
    • Phosh gets its second beta release of 0.20.0
    • Phoc is at 0.20
    • systemd is updated to 251.2
    • xorg-xwayland is at 22.1.2
  • Dev (2022-06-28) Download
    • Chatty is at 0.6.7
    • Kernel got updated to 5.18.6
      • this includes also fixes for PPP cameras to make them work with ppp-cam testing app
    • update of glibc-locales including C.UTF-8
    • Gstreamer is at 1.20.3
    • Networkmanager got updated to 1.38.2
    • PulseAudio is renewed to 16.1
    • Megapixels is at 1.5.0
    • Mesa got updated to 22.1.2
    • Phosh got renewed to 0.20.0-beta2 and Phoc to 0.21.0-beta1
    • Squeekboard bumped to 1.18.0
      • introduced a regression with Terminal App (kgx/gnome-console), or not …
  • Dev (2022-06-29) Download
    • Kernel got updated to 5.18.7
      • PPP: Add support for applying Type-C plug orientation correctly to Rockchip Type-C PHY from the DWC3 USB driver.
      • PPP: Enable processing the highest resolution of the IMX258 sensor via RKISP10.
    • Phosh got more MRs added
    • Gnome-Console replaces kgx
    • ModemManager got updated to 1.18.10
    • MegaPixels is at 1.5.1
    • js91 may break Gnome-Weather, so we have to see on how we deal with that
  • Dev (2022-06-30) Download
    • Kernel got updated to 5.18.8
    • Phosh got MR1079 added, which may not be part of 0.20.0 release.
    • Firefox got updated to 102.0
    • js91 got downgraded to a working version so Gnome-Weather starts normally
  • Dev (2022-07-02) Download
    • Phosh got MR1079 removed.
    • eg25-manager gains udev support for the custom firmware
    • modemmanager got fix for sms added: fix spliting messages into chunks in gsm7 encoding
    • phosh-antispam got updated to 2.1.1
  • Dev (2022-07-07) Download
    • Pipewire got updated to 0.3.53
    • gjs update fixed the js91 issue
    • more packages got updated to Gnome 42 series
    • some Gnome packages to renewed to 42.3 release
    • Mesa is at 22.1.3
    • Phosh and Phoc gained more fixes
    • wireplumber is now used for audio management. Report back any issues due to that!
  • Dev (2022-07-09) Download
    • Pipewire got updated to 0.3.54
    • Firefox is at 102.0.1
    • Wireplumber got renewed to 0.4.11
    • Kernel got bumped to 5.18.10
Really happy to see a new “stable” release after such a long time. :slight_smile: The new phosh gestures are nice on the pro, and its generally overall very smooth. There notification bar swipe down is a bit glitchy in landscape mode though, for PPKB users, its going to be difficult. Seems like it doesn’t adjust to the change in height correctly, making it hard to swipe up, and cutting off notifications.
What is this scale-to-fit feature that you mentioned?
Thanks by the way for this amazing job :smiley:.
I’ve noticed that one of things left to polish in Phosh in Pinephone is that some apps just seem out of bounds, like @LinuxFan1 mentioned in his post.
I was trying to understand how this works. Is this just a problem of how Phosh represents windows or a problem of apps themselves?
Take as a Manajro example, Pamac. In my Pinephone when I open Pamac and click some app to install I get an out of bound window. Is this a Pamac issue or a Phosh issue?
Hello, i tried to start Beta24 of Phosh for PinePhone from SD card 32 GB …after 10min.
After installing this release fresh i am no longer able to update the modem firmware, adb says protobuf.30.so not found, and this seems to be a long-standing problem. I found this weird since i updated the firmware a month ago to version 0.6.5 but i guess the old library was there from previous version of manjaro that i had been updating?
It would be nice to get this fixed at some point, if arch is not doing it maybe android-tools could get promoted to manjaro repo with the fix?
After installing this release, my PPP boots into a black screen with no way to recover but reflashing. I have tried installing the phosh build multiple times and had to go back to arch, because manjaro is just broken. Arch has the same problem by the way, but only if one updates the install (the release is from 2022/05/02)
I found this issue on the bugtracker which seems to resemble my issue:
gitlab(dot)manjaro(dot)org/manjaro-arm/issues/pinephone/phosh/-/issues/258
I though I had a solution to the no audio on suspend issue but turned out to be a bust so i just deleted my previous posts.
today’s first stable update brings a very annoying bug: previously the OSK would only hide the uppermost buttons (arrows) in firefox, making it annoying to type in addresses.
With this update the same is true with even the terminal. As soon as you tap on the text part of the app or try to open a new terminal tab, the OSK resizes and hides the arrows. Making using the terminal an absolute pain.
edit: clicking the globe button and selecting text input language: terminal seems to bring the buttons back. Weird inconsistency.
This is passed my skill level but I am dying to see the fix they have for Mobian on the Pro. It gets suspend and call audio working nearly perfect.
I have tested it on my Pro using install-able .deb packages to go on top of Mobian, that being said Mobian is way far back with the Phosh interface, still using tap gestures and the icons are old looking.
Is it already possible to install manjaro with fde on the pp?
testing branch with phosh/phoc 0.20 seems to make the UI noticeably faster.
Not exactly release related but any news on GPS?
Your image is not on the stable branch, as only testing and unstable have the update to Squeekboard 1.18.0, which brings in that regression: Terminal layout switches to en_US on focus within kgx (#341) · Issues · World / Phosh / squeekboard · GitLab
Edit: seems it is not a bug but a feature: layout switches as soon as you tab in text part or try to open a new tab (#158) · Issues · GNOME / Console · GitLab
It happens on stable once updated, i double-checked just now by re-flashing beta24, ensuring it works as expected, then updating, and seeing the issue.
sha1sum Manjaro-ARM-phosh-pinephone-beta24.img.xz
602843553b7edabce617dfa49782d47731bf7d39
OK, then share the package list what got updated on your end. Based on the issue I reported, squeekboard is not the issue here. Might be Phosh or Phoc. So share your /var/log/pacman.log to see what got updated on your end.
[2022-06-28T14:31:55+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T14:31:55+0000] [PACMAN] synchronizing package lists
[2022-06-28T14:36:00+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T14:36:00+0000] [PACMAN] synchronizing package lists
[2022-06-28T14:37:15+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T14:37:15+0000] [PACMAN] synchronizing package lists
[2022-06-28T14:38:11+0000] [PACMAN] starting full system upgrade
[2022-06-28T14:43:24+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T14:43:24+0000] [PACMAN] synchronizing package lists
[2022-06-28T14:43:35+0000] [ALPM] transaction started
[2022-06-28T14:43:35+0000] [ALPM] upgraded manjaro-system (20220528-1 -> 20220619-1)
[2022-06-28T14:43:35+0000] [ALPM-SCRIPTLET] ==> Enabling periodic trimming of filesystems...
[2022-06-28T14:43:36+0000] [ALPM-SCRIPTLET]     Starting initial filesystem trimming in background...
[2022-06-28T14:43:50+0000] [ALPM] transaction completed
[2022-06-28T14:43:50+0000] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-06-28T14:43:50+0000] [ALPM] running '30-systemd-update.hook'...
[2022-06-28T14:43:51+0000] [PACMAN] starting full system upgrade
[2022-06-28T15:02:54+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:02:54+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:02:57+0000] [PACMAN] starting full system upgrade
[2022-06-28T15:21:22+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:21:22+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:22:06+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:22:06+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:22:26+0000] [PACMAN] starting full system upgrade
[2022-06-28T15:24:06+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:24:06+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:24:08+0000] [PACMAN] starting full system upgrade
[2022-06-28T15:25:45+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:25:45+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:25:48+0000] [PACMAN] starting full system upgrade
[2022-06-28T15:32:58+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:32:58+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:37:58+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:37:58+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:38:28+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-28T15:38:28+0000] [PACMAN] synchronizing package lists
[2022-06-28T15:38:36+0000] [PACMAN] starting full system upgrade
[2022-06-28T15:53:36+0000] [ALPM] transaction started
[2022-06-28T15:53:36+0000] [ALPM] upgraded alsa-card-profiles (1:0.3.51-1 -> 1:0.3.52-2)
[2022-06-28T15:53:37+0000] [ALPM] upgraded iana-etc (20220427-1 -> 20220603-1)
[2022-06-28T15:53:40+0000] [ALPM] upgraded glibc (2.35-2 -> 2.35-5.1)
[2022-06-28T15:53:41+0000] [ALPM-SCRIPTLET] Generating locales...
[2022-06-28T15:53:41+0000] [ALPM-SCRIPTLET] Generation complete.
[2022-06-28T15:53:41+0000] [ALPM] upgraded alsa-ucm-conf (1.2.6.3-1 -> 1.2.7-1)
[2022-06-28T15:53:41+0000] [ALPM] upgraded alsa-lib (1.2.6.1-1 -> 1.2.7-2)
[2022-06-28T15:53:53+0000] [ALPM] upgraded gcc-libs (11.2.0-3 -> 12.1.0-2.1)
[2022-06-28T15:53:57+0000] [ALPM] upgraded zstd (1.5.2-3 -> 1.5.2-5)
[2022-06-28T15:53:57+0000] [ALPM] upgraded libldap (2.6.2-1 -> 2.6.2-2)
[2022-06-28T15:53:57+0000] [ALPM] installed libevent (2.1.12-1)
[2022-06-28T15:53:57+0000] [ALPM] installed libverto (0.3.2-4)
[2022-06-28T15:53:58+0000] [ALPM] upgraded krb5 (1.19.3-1 -> 1.19.3-3)
[2022-06-28T15:53:58+0000] [ALPM] upgraded libgpg-error (1.45-1 -> 1.45-2)
[2022-06-28T15:53:58+0000] [ALPM] upgraded systemd-libs (251-1 -> 251.2-1)
[2022-06-28T15:53:58+0000] [ALPM] upgraded ca-certificates-mozilla (3.78-1 -> 3.79-1)
[2022-06-28T15:54:00+0000] [ALPM] upgraded binutils (2.38-3 -> 2.38-5.1)
[2022-06-28T15:54:03+0000] [ALPM] upgraded boost-libs (1.78.0-2 -> 1.79.0-1)
[2022-06-28T15:54:04+0000] [ALPM] upgraded btrfs-progs (5.17-1 -> 5.18.1-1)
[2022-06-28T15:54:04+0000] [ALPM] upgraded lv2 (1.18.2-1 -> 1.18.4-2)
[2022-06-28T15:54:04+0000] [ALPM] upgraded serd (0.30.10-1 -> 0.30.12-2)
[2022-06-28T15:54:04+0000] [ALPM] upgraded sord (0.16.8-1 -> 0.16.10-2)
[2022-06-28T15:54:04+0000] [ALPM] upgraded sratom (0.6.8-3 -> 0.6.10-3)
[2022-06-28T15:54:04+0000] [ALPM] upgraded lilv (0.24.12-4 -> 0.24.14-2)
[2022-06-28T15:54:05+0000] [ALPM] upgraded pipewire (1:0.3.51-1 -> 1:0.3.52-2)
[2022-06-28T15:54:07+0000] [ALPM] upgraded kbd (2.4.0-2 -> 2.5.0-2)
[2022-06-28T15:54:07+0000] [ALPM] upgraded hwdata (0.359-1 -> 0.360-1)
[2022-06-28T15:54:07+0000] [ALPM] upgraded libnftnl (1.2.1-1 -> 1.2.2-1)
[2022-06-28T15:54:08+0000] [ALPM] upgraded file (5.41-1 -> 5.42-1)
[2022-06-28T15:54:15+0000] [ALPM] upgraded systemd (251-1 -> 251.2-1)
[2022-06-28T15:54:16+0000] [ALPM] upgraded libpulse (15.0-4 -> 16.0-1)
[2022-06-28T15:54:18+0000] [ALPM] upgraded glib2 (2.72.1-1 -> 2.72.2-1)
[2022-06-28T15:54:18+0000] [ALPM] upgraded pipewire-pulse (1:0.3.51-1 -> 1:0.3.52-2)
[2022-06-28T15:54:18+0000] [ALPM] upgraded callaudiod (0.1.4-1 -> 0.1.4+1+gd380d60-1)
[2022-06-28T15:54:18+0000] [ALPM] upgraded nspr (4.33-2 -> 4.34-1)
[2022-06-28T15:54:18+0000] [ALPM] upgraded nss (3.78-1 -> 3.79-1)
[2022-06-28T15:54:20+0000] [ALPM] upgraded protobuf (3.20.1-2 -> 21.1-1)
[2022-06-28T15:54:21+0000] [ALPM] upgraded libphonenumber (1:8.12.48-1 -> 1:8.12.50-2)
[2022-06-28T15:54:24+0000] [ALPM] upgraded libx11 (1.8-1 -> 1.8.1-2)
[2022-06-28T15:54:27+0000] [ALPM] upgraded iso-codes (4.9.0-1 -> 4.10.0-1)
[2022-06-28T15:54:30+0000] [ALPM] upgraded gstreamer (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:54:32+0000] [ALPM] upgraded libdrm (2.4.110-1 -> 2.4.111-1)
[2022-06-28T15:54:45+0000] [ALPM] upgraded llvm-libs (13.0.1-4 -> 13.0.1-6)
[2022-06-28T15:54:45+0000] [ALPM] upgraded vulkan-icd-loader (1.3.213-1 -> 1.3.217-1)
[2022-06-28T15:54:54+0000] [ALPM] upgraded mesa (22.0.4-1 -> 22.1.1-2)
[2022-06-28T15:54:55+0000] [ALPM] upgraded gst-plugins-base-libs (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:54:55+0000] [ALPM] upgraded nettle (3.7.3-1.1 -> 3.8-1)
[2022-06-28T15:54:57+0000] [ALPM] upgraded gnutls (3.7.5-1 -> 3.7.6-1)
[2022-06-28T15:54:57+0000] [ALPM] upgraded libproxy (0.4.17-6 -> 0.4.17-7)
[2022-06-28T15:54:57+0000] [ALPM] upgraded tracker3 (3.3.0-2 -> 3.3.1-1)
[2022-06-28T15:54:57+0000] [ALPM] upgraded libtiff (4.3.0-2 -> 4.4.0-1)
[2022-06-28T15:54:57+0000] [ALPM] upgraded libcups (1:2.4.1-1 -> 1:2.4.2-3)
[2022-06-28T15:54:59+0000] [ALPM] upgraded librsvg (2:2.54.3-1 -> 2:2.54.4-1)
[2022-06-28T15:54:59+0000] [ALPM] upgraded gtk-update-icon-cache (1:4.6.4-1 -> 1:4.6.5-1)
[2022-06-28T15:55:00+0000] [ALPM] upgraded xkeyboard-config (2.35.1-1 -> 2.36-2)
[2022-06-28T15:55:07+0000] [ALPM] upgraded gtk3-mobile (3.24.33-1 -> 3.24.34-1)
[2022-06-28T15:55:18+0000] [ALPM] upgraded perl (5.34.1-1 -> 5.36.0-1)
[2022-06-28T15:55:33+0000] [ALPM] upgraded webkit2gtk (2.36.2-1 -> 2.36.3-1)
[2022-06-28T15:55:33+0000] [ALPM] upgraded tdb (1.4.6-1 -> 1.4.7-1)
[2022-06-28T15:55:33+0000] [ALPM] upgraded libtool (2.4.6+59+gb55b1cc8-2 -> 2.4.7-2)
[2022-06-28T15:55:42+0000] [ALPM] upgraded evolution-data-server (3.44.1-1 -> 3.44.2-1)
[2022-06-28T15:55:46+0000] [ALPM] upgraded python (3.10.4-1 -> 3.10.5-1)
[2022-06-28T15:55:48+0000] [ALPM] upgraded python-more-itertools (8.12.0-2 -> 8.13.0-1)
[2022-06-28T15:55:48+0000] [ALPM] installed python-jaraco.functools (3.5.0-2)
[2022-06-28T15:55:48+0000] [ALPM] installed python-jaraco.context (4.1.1-2)
[2022-06-28T15:55:48+0000] [ALPM] installed python-jaraco.text (3.8.0-2)
[2022-06-28T15:55:48+0000] [ALPM] installed python-nspektr (0.4.0-1)
[2022-06-28T15:55:48+0000] [ALPM] installed python-tomli (2.0.1-1)
[2022-06-28T15:55:48+0000] [ALPM] installed python-trove-classifiers (2022.5.19-1)
[2022-06-28T15:55:48+0000] [ALPM] installed python-validate-pyproject (0.9-1)
[2022-06-28T15:55:49+0000] [ALPM] upgraded python-setuptools (1:60.6.0-1 -> 1:61.3.1-1)
[2022-06-28T15:55:51+0000] [ALPM] upgraded python-zipp (3.8.0-1 -> 3.8.0-2)
[2022-06-28T15:55:51+0000] [ALPM] upgraded feedbackd (0.0.0+git20220208-1 -> 0.0.0+git20220520-1)
[2022-06-28T15:55:54+0000] [ALPM] upgraded gst-plugins-bad-libs (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:56:02+0000] [ALPM] upgraded gtk4 (1:4.6.4-1 -> 1:4.6.5-1)
[2022-06-28T15:56:02+0000] [ALPM] upgraded libolm (3.2.11-1 -> 3.2.12-1)
[2022-06-28T15:56:02+0000] [ALPM] upgraded protobuf-c (1.4.0-3 -> 1.4.0-4)
[2022-06-28T15:56:05+0000] [ALPM] upgraded libpurple (2.14.9-1 -> 2.14.10-1)
[2022-06-28T15:56:06+0000] [ALPM] upgraded gnome-desktop-common (1:42.1-1 -> 1:42.2-1)
[2022-06-28T15:56:07+0000] [ALPM] upgraded gnome-desktop (1:42.1-1 -> 1:42.2-1)
[2022-06-28T15:56:07+0000] [ALPM] upgraded chatty (0.6.4-1 -> 0.6.6-1)
[2022-06-28T15:56:09+0000] [ALPM] upgraded dnsmasq (2.86-1 -> 2.86-2)
[2022-06-28T15:56:10+0000] [ALPM] upgraded eog (42.1-1 -> 42.2-1)
[2022-06-28T15:56:10+0000] [ALPM] upgraded libass (0.15.2-2 -> 0.16.0-1)
[2022-06-28T15:56:12+0000] [ALPM] upgraded libbluray (1.3.0-2 -> 1.3.1-1)
[2022-06-28T15:56:13+0000] [ALPM] upgraded zimg (3.0.3-2 -> 3.0.4-1)
[2022-06-28T15:56:13+0000] [ALPM] upgraded hidapi (0.11.2-1 -> 0.12.0-1)
[2022-06-28T15:56:19+0000] [ALPM] upgraded ffmpeg (2:5.0-7 -> 2:5.0.1-2)
[2022-06-28T15:56:49+0000] [ALPM] upgraded firefox (100.0.2-1 -> 101.0-1)
[2022-06-28T15:56:51+0000] [ALPM] upgraded gedit (42.0-1 -> 42.1-1)
[2022-06-28T15:56:52+0000] [ALPM] upgraded glslang (11.9.0-1 -> 11.10.0-1)
[2022-06-28T15:56:52+0000] [ALPM] upgraded libadwaita (1:1.1.1-1 -> 1:1.1.2-1)
[2022-06-28T15:56:52+0000] [ALPM] upgraded upower (0.99.17-1 -> 0.99.19-1)
[2022-06-28T15:56:53+0000] [ALPM] upgraded gnome-bluetooth-3.0 (42.0-1 -> 42.1-1)
[2022-06-28T15:56:53+0000] [ALPM] upgraded gnome-desktop-4 (1:42.1-1 -> 1:42.2-1)
[2022-06-28T15:56:53+0000] [ALPM] upgraded pipewire-alsa (1:0.3.51-1 -> 1:0.3.52-2)
[2022-06-28T15:56:53+0000] [ALPM] upgraded gnome-settings-daemon (42.1-1 -> 42.2-1)
[2022-06-28T15:56:53+0000] [ALPM] upgraded libnma-common (1.8.38-1 -> 1.8.40-1)
[2022-06-28T15:56:53+0000] [ALPM] upgraded libnma-gtk4 (1.8.38-1 -> 1.8.40-1)
[2022-06-28T15:56:54+0000] [ALPM] upgraded talloc (2.3.3-3 -> 2.3.4-1)
[2022-06-28T15:56:54+0000] [ALPM] upgraded tevent (1:0.11.0-3 -> 1:0.12.1-1)
[2022-06-28T15:56:54+0000] [ALPM] upgraded ldb (2:2.5.0-1 -> 2:2.5.1-1)
[2022-06-28T15:56:56+0000] [ALPM] upgraded smbclient (4.16.1-3 -> 4.16.2-1)
[2022-06-28T15:56:56+0000] [ALPM] upgraded libbytesize (2.6-3 -> 2.7-1)
[2022-06-28T15:56:56+0000] [ALPM] upgraded xfsprogs (5.16.0-1 -> 5.18.0-1)
[2022-06-28T15:56:59+0000] [ALPM] upgraded gnome-control-center-mobile (42.1-6 -> 42.2-1.7)
[2022-06-28T15:57:00+0000] [ALPM] upgraded gnome-keyring (1:42.0-1 -> 1:42.1-1)
[2022-06-28T15:57:10+0000] [ALPM] upgraded js91 (91.9.1-1 -> 91.10.0-1)
[2022-06-28T15:57:10+0000] [ALPM] upgraded libinput (1.20.1-1 -> 1.21.0-1)
[2022-06-28T15:57:10+0000] [ALPM] upgraded gnome-maps (42.1-1 -> 42.2-1)
[2022-06-28T15:57:10+0000] [ALPM] upgraded xorg-xwayland (22.1.1-1 -> 22.1.2-1)
[2022-06-28T15:57:12+0000] [ALPM] upgraded mutter (42.1-1 -> 42.2-1)
[2022-06-28T15:57:13+0000] [ALPM] upgraded libnma (1.8.38-1 -> 1.8.40-1)
[2022-06-28T15:57:13+0000] [ALPM] upgraded libdvdread (6.1.2-1 -> 6.1.3-1)
[2022-06-28T15:57:15+0000] [ALPM] upgraded gnome-shell (1:42.1-1 -> 1:42.2-1)
[2022-06-28T15:57:16+0000] [ALPM] upgraded gst-editing-services (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:57:16+0000] [ALPM] upgraded gst-plugin-gtk (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:57:16+0000] [ALPM] upgraded libopenmpt (0.6.3-1 -> 0.6.4-1)
[2022-06-28T15:57:18+0000] [ALPM] upgraded imath (3.1.5-1 -> 3.1.5-2)
[2022-06-28T15:57:23+0000] [ALPM] upgraded imagemagick (7.1.0.35-1 -> 7.1.0.37-1)
[2022-06-28T15:57:23+0000] [ALPM] upgraded gst-plugins-bad (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:57:23+0000] [ALPM] upgraded gst-plugins-base (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:57:24+0000] [ALPM] upgraded gst-plugins-good (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:57:24+0000] [ALPM] upgraded gst-plugins-ugly (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:57:24+0000] [ALPM] upgraded gst-python (1.20.2-1 -> 1.20.2-2)
[2022-06-28T15:57:24+0000] [ALPM] upgraded gvfs (1.50.1-1 -> 1.50.2-1)
[2022-06-28T15:57:26+0000] [ALPM] upgraded iproute2 (5.17.0-3 -> 5.18.0-1)
[2022-06-28T15:57:26+0000] [ALPM] upgraded iw (5.16-1 -> 5.19-1)
[2022-06-28T15:57:26+0000] [ALPM] upgraded jasper (3.0.3-1 -> 3.0.4-1)
[2022-06-28T15:57:26+0000] [ALPM] upgraded perl-error (0.17029-3 -> 0.17029-4)
[2022-06-28T15:57:26+0000] [ALPM] upgraded perl-timedate (2.33-3 -> 2.33-4)
[2022-06-28T15:57:26+0000] [ALPM] upgraded perl-mailtools (2.21-5 -> 2.21-6)
[2022-06-28T15:57:27+0000] [ALPM] upgraded libpamac (11.3.0-1 -> 11.3.1-1)
[2022-06-28T15:57:30+0000] [ALPM] upgraded linux-pinephone (5.18.0-1 -> 5.18.3-1)
[2022-06-28T15:57:31+0000] [ALPM] upgraded nm-connection-editor (1.26.0-1 -> 1.28.0-1)
[2022-06-28T15:57:33+0000] [ALPM] upgraded ntfs-3g (2021.8.22-1 -> 2022.5.17-1)
[2022-06-28T15:57:34+0000] [ALPM] upgraded openvpn (2.5.6-1 -> 2.5.7-1)
[2022-06-28T15:57:34+0000] [ALPM] upgraded pamac-cli (10.4.0-2 -> 10.4.1-1)
[2022-06-28T15:57:34+0000] [ALPM] upgraded pamac-gtk (10.4.0-2 -> 10.4.1-1)
[2022-06-28T15:57:34+0000] [ALPM] upgraded pamac-gnome-integration (10.4.0-2 -> 10.4.1-1)
[2022-06-28T15:58:47+0000] [ALPM] upgraded papirus-icon-theme (20220508-1 -> 20220606-1)
[2022-06-28T15:58:50+0000] [ALPM] upgraded pciutils (3.8.0-1 -> 3.8.0-2)
[2022-06-28T15:58:50+0000] [ALPM] upgraded seatd (0.6.4-2 -> 0.7.0-1)
[2022-06-28T15:58:51+0000] [ALPM] upgraded phoc (0.13.1+47+g4d9e3b0-1 -> 0.20.0+79+ge5a6514-1)
[2022-06-28T15:58:51+0000] [ALPM] upgraded phosh (0.17.0+162+g95913fa0-1 -> 0.20.0beta1+11+ga63d1b2c-2)
[2022-06-28T15:58:51+0000] [ALPM] upgraded phosh-antispam (2.0-1 -> 2.1-1)
[2022-06-28T15:58:54+0000] [ALPM] upgraded poppler (22.05.0-2 -> 22.06.0-1)
[2022-06-28T15:58:55+0000] [ALPM] upgraded poppler-glib (22.05.0-2 -> 22.06.0-1)
[2022-06-28T15:58:58+0000] [ALPM] upgraded python-cryptography (37.0.0-1 -> 37.0.2-1)
[2022-06-28T15:58:59+0000] [ALPM] upgraded python-pillow (9.1.0-1 -> 9.1.1-1)
[2022-06-28T15:58:59+0000] [ALPM] warning: directory permissions differ on /etc/sudoers.d/
filesystem: 755  package: 750
[2022-06-28T15:59:02+0000] [ALPM] upgraded sudo (1.9.10-1 -> 1.9.11.p2-1)
[2022-06-28T15:59:02+0000] [ALPM] upgraded systemd-sysvcompat (251-1 -> 251.2-1)
[2022-06-28T15:59:06+0000] [ALPM] upgraded tracker (2.3.6+7+gb27396252-4 -> 1:2.3.6+r7+gb27396252-1)
[2022-06-28T15:59:06+0000] [ALPM] upgraded vvmd (0.8-1 -> 0.9-1)
[2022-06-28T15:59:06+0000] [ALPM] upgraded wireless-regdb (2022.04.08-1 -> 2022.06.06-1)
[2022-06-28T15:59:13+0000] [ALPM] transaction completed
[2022-06-28T15:59:39+0000] [ALPM] running '20-systemd-sysusers.hook'...
[2022-06-28T15:59:41+0000] [ALPM] running '30-systemd-catalog.hook'...
[2022-06-28T15:59:42+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-06-28T16:00:58+0000] [ALPM] running '30-systemd-hwdb.hook'...
[2022-06-28T16:01:03+0000] [ALPM] running '30-systemd-sysctl.hook'...
[2022-06-28T16:01:03+0000] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-06-28T16:01:03+0000] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-06-28T16:01:03+0000] [ALPM] running '30-systemd-update.hook'...
[2022-06-28T16:01:03+0000] [ALPM] running '30-update-mime-database.hook'...
[2022-06-28T16:01:06+0000] [ALPM] running '40-update-ca-trust.hook'...
[2022-06-28T16:01:11+0000] [ALPM] running '60-depmod.hook'...
[2022-06-28T16:01:19+0000] [ALPM] running '60-glibc-locales.hook'...
[2022-06-28T16:01:38+0000] [ALPM] running '60-linux-pinephone.hook'...
[2022-06-28T16:01:45+0000] [ALPM] running '90-linux-pinephone.hook'...
[2022-06-28T16:01:45+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux-pinephone.preset: 'default'
[2022-06-28T16:01:45+0000] [ALPM-SCRIPTLET]   -> -k 5.18.3-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2022-06-28T16:01:45+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.18.3-1-MANJARO-ARM
[2022-06-28T16:01:46+0000] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-06-28T16:01:48+0000] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-06-28T16:01:50+0000] [ALPM-SCRIPTLET]   -> Running build hook: [bootsplash-manjaro]
[2022-06-28T16:01:50+0000] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2022-06-28T16:01:51+0000] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-06-28T16:01:51+0000] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-06-28T16:01:52+0000] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-06-28T16:01:52+0000] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-06-28T16:01:52+0000] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-06-28T16:01:52+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-28T16:01:52+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
[2022-06-28T16:01:59+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-06-28T16:01:59+0000] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-06-28T16:01:59+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux-pinephone.preset: 'default'
[2022-06-28T16:01:59+0000] [ALPM-SCRIPTLET]   -> -k 5.18.3-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2022-06-28T16:01:59+0000] [ALPM-SCRIPTLET] ==> Starting build: 5.18.3-1-MANJARO-ARM
[2022-06-28T16:02:00+0000] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-06-28T16:02:02+0000] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-06-28T16:02:04+0000] [ALPM-SCRIPTLET]   -> Running build hook: [bootsplash-manjaro]
[2022-06-28T16:02:04+0000] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2022-06-28T16:02:05+0000] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-06-28T16:02:05+0000] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-06-28T16:02:06+0000] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-06-28T16:02:06+0000] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-06-28T16:02:06+0000] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-06-28T16:02:06+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-28T16:02:06+0000] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
[2022-06-28T16:02:13+0000] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-06-28T16:02:13+0000] [ALPM] running 'dbus-reload.hook'...
[2022-06-28T16:02:13+0000] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-06-28T16:02:13+0000] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2022-06-28T16:02:13+0000] [ALPM] running 'gio-querymodules.hook'...
[2022-06-28T16:02:14+0000] [ALPM] running 'glib-compile-schemas.hook'...
[2022-06-28T16:02:14+0000] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2022-06-28T16:02:14+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-06-28T16:03:05+0000] [ALPM] running 'gtk4-querymodules.hook'...
[2022-06-28T16:03:06+0000] [ALPM] running 'gvfsd.hook'...
[2022-06-28T16:03:06+0000] [ALPM] running 'locale-gen.hook'...
[2022-06-28T16:03:06+0000] [ALPM] running 'update-desktop-database.hook'...
[2022-06-29T01:04:09+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-29T01:04:09+0000] [PACMAN] synchronizing package lists
[2022-06-29T01:05:42+0000] [PACMAN] starting full system upgrade
[2022-06-29T01:10:41+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-29T01:10:41+0000] [PACMAN] synchronizing package lists
[2022-06-29T01:10:42+0000] [PACMAN] starting full system upgrade
[2022-06-29T04:28:29+0000] [PACMAN] Running 'pacman -Syu'
[2022-06-29T04:28:29+0000] [PACMAN] synchronizing package lists
[2022-06-29T04:28:31+0000] [PACMAN] starting full system upgrade
I found that in the latest kernel package (5.18.9-1) the WiFi hotspot functionality can’t work (at least not completely). The network appears and DHCP works, but there’s no internet access. This is because the PP kernel is missing a few build parameters. I just rebuilt the kernel to test my theory and hotspot now fully works. That being said, I’m not a kernel dev and I think I enabled way more CONFIG_NF_ parameters than I had to. I think the ones that are required are CONFIG_NF_NAT and CONFIG_NF_TABLES.
Note: In my testing using the GNOME Settings for setting up the WiFi hotspot not always succeeds. If it doesn’t, you can use nmcli d wifi hotspot ifname wlan0 band bg password aaaaaaaa ssid a con-name a. This works every time for me.
Here’s a diff of the two kconfigs:
$ diff kconfig_old kconfig_upd
957c957
< # CONFIG_SYN_COOKIES is not set
> CONFIG_SYN_COOKIES=y
1016c1016
< CONFIG_NETFILTER_NETLINK=m
> CONFIG_NETFILTER_NETLINK=y
1017a1018,1019
> CONFIG_NETFILTER_FAMILY_ARP=y
> CONFIG_NETFILTER_NETLINK_HOOK=y
1021c1023
< CONFIG_NETFILTER_NETLINK_OSF=m
> CONFIG_NETFILTER_NETLINK_OSF=y
1051c1053,1087
< # CONFIG_NF_TABLES is not set
> CONFIG_NETFILTER_SYNPROXY=y
> CONFIG_NF_TABLES=y
> CONFIG_NF_TABLES_INET=y
> CONFIG_NF_TABLES_NETDEV=y
> CONFIG_NFT_NUMGEN=y
> CONFIG_NFT_CT=y
> CONFIG_NFT_FLOW_OFFLOAD=y
> CONFIG_NFT_CONNLIMIT=y
> CONFIG_NFT_LOG=y
> CONFIG_NFT_LIMIT=y
> CONFIG_NFT_MASQ=y
> CONFIG_NFT_REDIR=y
> CONFIG_NFT_NAT=y
> CONFIG_NFT_TUNNEL=y
> CONFIG_NFT_OBJREF=y
> # CONFIG_NFT_QUEUE is not set
> CONFIG_NFT_QUOTA=y
> CONFIG_NFT_REJECT=y
> CONFIG_NFT_REJECT_INET=y
> # CONFIG_NFT_COMPAT is not set
> CONFIG_NFT_HASH=y
> CONFIG_NFT_FIB=y
> CONFIG_NFT_FIB_INET=y
> CONFIG_NFT_XFRM=y
> CONFIG_NFT_SOCKET=y
> CONFIG_NFT_OSF=y
> CONFIG_NFT_TPROXY=y
> CONFIG_NFT_SYNPROXY=y
> CONFIG_NF_DUP_NETDEV=y
> CONFIG_NFT_DUP_NETDEV=y
> CONFIG_NFT_FWD_NETDEV=y
> CONFIG_NFT_FIB_NETDEV=y
> CONFIG_NFT_REJECT_NETDEV=y
> CONFIG_NF_FLOW_TABLE_INET=y
> CONFIG_NF_FLOW_TABLE=y
1146,1148c1182,1189
< # CONFIG_NF_SOCKET_IPV4 is not set
< # CONFIG_NF_TPROXY_IPV4 is not set
< # CONFIG_NF_DUP_IPV4 is not set
> CONFIG_NF_SOCKET_IPV4=y
> CONFIG_NF_TPROXY_IPV4=y
> CONFIG_NF_TABLES_IPV4=y
> CONFIG_NFT_REJECT_IPV4=y
> CONFIG_NFT_DUP_IPV4=y
> CONFIG_NFT_FIB_IPV4=y
> CONFIG_NF_TABLES_ARP=y
> CONFIG_NF_DUP_IPV4=y
1176,1179c1217,1224
< # CONFIG_NF_SOCKET_IPV6 is not set
< # CONFIG_NF_TPROXY_IPV6 is not set
< # CONFIG_NF_DUP_IPV6 is not set
< CONFIG_NF_REJECT_IPV6=m
> CONFIG_NF_SOCKET_IPV6=y
> CONFIG_NF_TPROXY_IPV6=y
> CONFIG_NF_TABLES_IPV6=y
> CONFIG_NFT_REJECT_IPV6=y
> CONFIG_NFT_DUP_IPV6=y
> CONFIG_NFT_FIB_IPV6=y
> CONFIG_NF_DUP_IPV6=y
> CONFIG_NF_REJECT_IPV6=y
1204a1250
> # CONFIG_NF_TABLES_BRIDGE is not set
1795a1842
> # CONFIG_IFB is not set
@philm
How difficult will it be to implement this;
It seems with community modem firmware and the correct kernel patches we could have working suspend and the Pro could become a daily driver.
I have tested the community modem firmware on the OG pinephone with excellent results.
I had not updated since at least two weeks but recently <2022-07-11> I updated my pinephone from the stable repositories which makes chatty crashing all the time. I suppose it is because of pipewire or the switch from media-session to wireplumber.
I tried to reinstall a proper Manjaro from scratch I choosed Manjaro-ARM-phosh-pinephone-20220710 stable and then unstable repositories but chatty always crashed.
journalctl:
manjaro-arm kernel: gc2145 3-003c: device id: 0x2145
manjaro-arm kernel: sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
manjaro-arm kernel: gc2145 3-003c: Failed to read firmware gc2145-init.bin, continuing anyway...
manjaro-arm kernel: gc2145 3-003c: bank switch: 0x01
manjaro-arm kernel: gc2145 3-003c: bank switch: 0x00
manjaro-arm systemd[1]: Started Process Core Dump (PID 6297/UID 0).
manjaro-arm systemd-coredump[6298]: [🡕] Process 6270 (chatty) of user 1000 dumped core.
                                    Module linux-vdso.so.1 with build-id bcd25aaca5521822de0facbc45822cc164be0c15
                                    Module im-wayland.so with build-id b79a3e81dc74f498cbc1897cd34139c76739f459
                                    Module librsvg-2.so.2 with build-id 8cb63b7b9cb203e3124ce55fd84afa74905b3fc0
                                    Module libpixbufloader-svg.so with build-id 420777fa9e3bd251267e0a5368a0069775ed692c
                                    Module libfreeblpriv3.so with build-id 406f2c382f76f2ca8f98caebf8a539a685933bae
                                    Module libsoftokn3.so with build-id fa6de728182893a43b5e018982132d1b38935363
                                    Module libxcb-xkb.so.1 with build-id 761402d45128ec184d8f6031aa39f25a0e7a2f0b
                                    Module libxkbcommon-x11.so.0 with build-id 5cf26a709ff230a3118f9d6e7d99ee4549756947
                                    Module libvulkan.so.1 with build-id ad00eaf59280e13cef42f892ff19f6dda9dd31d1
                                    Module libgstvulkan-1.0.so.0 with build-id b3c1d89b908c27e6791ba0e7784ad20fcff2c8e0
                                    Module libgstvulkan.so with build-id 213cb83019077dbabf044d92c79e07b2bc4c0c32
                                    Module libasound.so.2 with build-id c23fb3503140d029c42f4c2be200b44f55c65de3
                                    Module libgstalsa.so with build-id 7b7247c1de22942ba9dc3ff7bb36524935f7ed08
                                    Module librt.so.1 with build-id f95a26a83c917376d558b8455c894600943b389b
                                    Module libv4lconvert.so.0 with build-id c68787f0d3225ebfa05f7b8d87a3a00bd60e3073
                                    Module libv4l2.so.0 with build-id 5162daf853bc0e53b9e5074d6161e5980aa6fd32
                                    Module libgstallocators-1.0.so.0 with build-id 9d4f6cfff1db79a916ffc032cd46a48ac6607c83
                                    Module libgstvideo4linux2.so with build-id 34acc26f84661e3dfb14c4049abae3b6699f6b10
                                    Module libatomic.so.1 with build-id e499b8090d7c5bfc1a0e1a738f264a26446623ff
                                    Module libusb-1.0.so.0 with build-id 2890fa779982028a68171da58b37629778773459
                                    Module libgudev-1.0.so.0 with build-id 5a6f3c10a634c4fbe5d6480a6c61323440662400
                                    Module libgstbasecamerabinsrc-1.0.so.0 with build-id 19bff89a8c6454476cbc7bd6a805298c89c72d19
                                    Module libgstuvch264.so with build-id 4a2cf8e570c29fb6d23a821064cc03d7da4a1616
                                    Module libogg.so.0 with build-id cd094d37daca0f473ddb0114a4d4e12bbf586bfb
                                    Module libvorbis.so.0 with build-id 6e61f620dc5f1521bc1159776bbaf8960e788670
                                    Module libopus.so.0 with build-id 63a1c96d2529ac2acd99fe1eb7e967ee801512dc
                                    Module libFLAC.so.8 with build-id 1e139be533b1180c9328ac6c4e908ab9034fe052
                                    Module libvorbisenc.so.2 with build-id e22853dde0ca0c1d3f3cebfdeaec5e890ec5bf66
                                    Module libasyncns.so.0 with build-id a76ad576f5a807bdfd9acbd2aaa74ad1d351e419
                                    Module libsndfile.so.1 with build-id dfbef7323367bd5616c8a9f04881b5748b53ce21
                                    Module libpulsecommon-16.1.so with build-id ca87e0ac82fa27cdf4ffb39ad495dcbdd7dafd14
                                    Module libpulse.so.0 with build-id 007472a1216aad381a8c2d0d74e09a0113ac9a76
                                    Module libgstpulseaudio.so with build-id 80f3461f7062f7d621333d8f908c51544fe38a1b
                                    Module libmicrodns.so.1 with build-id c1fb08efffc99a9d50e2cf091d84e6289c7724f2
                                    Module libgstmicrodns.so with build-id 542daf8d98507cf3528a21f8ac9bd0368ffe5f66
                                    Module libgsttag-1.0.so.0 with build-id 9a89e51bfd395a0f7603f3b7dab00b63d7d61724
                                    Module libgstaudio-1.0.so.0 with build-id d16a34366298b59a34aea598224cfa7d24ae28eb
                                    Module libgstdecklink.so with build-id 4a84fb8ec15ec1dedf435852707a664ff5cdea12
                                    Module libntlm.so with build-id 0c4706608f545648a82632f793c77e2564c7b974
                                    Module libgdbm.so.6 with build-id 4c9c62a5a7c165ea4c6818cb5e91775eddeafb6c
                                    Module libsasldb.so with build-id 477bced72db238de4c5a0cc1c7b91d3310b24b96
                                    Module libcrammd5.so with build-id a165920af85836d5f040881a2445a9764f6cb237
                                    Module libplain.so with build-id 3268d913478cef31881b7dbaf4e4edbf41a1b90c
                                    Module libscram.so with build-id 486c76fc2a725999b226faaa8c9d06df4070a206
                                    Module libanonymous.so with build-id 3f514886069513fe207d072353a537da7d861e08
                                    Module libdigestmd5.so with build-id 824ec69690d233c6b70c0acef09b4873dfc75300
                                    Module liblogin.so with build-id 732897603b0d98efa21570be197899c6372f0125
                                    Module nss-prefs.so with build-id ddc2b88ffcec1216eb8bf56e404c2efaa8379bd1
                                    Module dbus-example.so with build-id 02c1e2423c07b788fa3117b2df2f9861272d8d96
                                    Module joinpart.so with build-id 666e0a260abb2aaa8d214798a870e4c310016276
                                    Module statenotify.so with build-id c538c4256f7a60b26bb3ebe366ed030c062ee122
                                    Module ssl.so with build-id 758022db1f6dc26047d1e69399d13b3b013cff63
                                    Module buddynote.so with build-id b13b999300236936cc5975756b456af6732318b0
                                    Module libxmpp.so with build-id dd8feb76c5f2b56b2fdd8fc3da3ae143bd267ffe
                                    Module newline.so with build-id 80544c4e36c4007b6c76185a7541a6e6f372cf1a
                                    Module libzephyr.so with build-id 471ad5c61b0af3012afce74211e48a4647ebfe07
                                    Module libcrypt.so.2 with build-id 63e5fd8b6a8cfd34fb4d6e06ff05a7cf1ee4c1dc
                                    Module libperl.so with build-id 1878bfe1653666d3aabecb7a009c30ab141058a6
                                    Module perl.so with build-id 56ff5a72fb4b8ba75d23b82bc3ea24197c8f6d3e
                                    Module offlinemsg.so with build-id b9046426a53bb84cc05ae859623fdf3302cdc5d7
                                    Module libavahi-glib.so.1 with build-id b754bca72c14cb055ea3912775d477dbdb88067b
                                    Module libavahi-client.so.3 with build-id ()280820074d21c261d58736c8f33230cc476ec86c
                                    Module libavahi-common.so.3 with build-id 58f0ffed8f26a8a97dfedaa364b0ff60b188b405
                                    Module libbonjour.so with build-id 193f88c9c17767b96935f378ea46f47a1c96fea0
                                    Module libnovell.so with build-id 30da7a2009d127e25742750c1151613f25992082
                                    Module ssl-nss.so with build-id 3e713e21e6892b9ddd7d277f9be31e08b5ac21ba
                                    Module log_reader.so with build-id 7630509f9ac03c3758d08add49c472b12808ba9d
                                    Module psychic.so with build-id ab8e4bbd15a87229d4fce894d207142b04ffa6bb
                                    Module libirc.so with build-id ce6faf6dd62bae2617d2e1612115989204ec3ac5
                                    Module mm-sms.so with build-id c8bc3313bc96d92e786f89581538be58b03bf0c5
                                    Module libsimple.so with build-id 4e3796264f5cecc3e7ab30dab507463acaa72583
                                    Module libgg.so with build-id 9fcfcc7794948da2e5466954ffa8c5271a093faf
                                    Module idle.so with build-id 07b9b1eb36fff5617720ce16f2c4e0ff7a3d6d03
                                    Module libwebp.so.7 with build-id aa329951573bfebef9ef217d6f762bcb3b0ee7e3
                                    Module telegram-purple.so with build-id b2e2d0129abc4a3b904d8d4a81067cf29a37bc3d
                                    Module autoaccept.so with build-id cbc2e8c06ab8eef6d34488e7fbf26039b0aaa734
                                    Module libhttp_parser.so.2.9 with build-id f63eda5dacebdfa4bed0758518aa1460086d6e5d
                                    Module libmatrix.so with build-id ce99d11fcaf692a0f21c0640ef206a467ece1159
                                    Module libgvfscommon.so with build-id 8eff85b77a549cd0f1cfff13cbd0112d94790041
                                    Module libgvfsdbus.so with build-id 7241facc8924753fec7f1ee97447c2cda3afcb75
                                    Module libical.so.3 with build-id 683fff13aad9ed7f0c022f43cd7021994ec06aad
                                    Module libcamelimapx.so with build-id a5c953d23918a70c1869cdef73c523b4cd24214c
                                    Module libcamelpop3.so with build-id b657c061b806e30eaf8adc21d3f5ac3a290e807c
                                    Module libcamelsmtp.so with build-id 20e325c2e204d7d48bea211bf035464068df0f77
                                    Module libcamellocal.so with build-id 98c4545db6b52f71d4cbe86e13e634dad07c50dc
                                    Module libcamelsendmail.so with build-id 0c94eeab7de02a38fd46acc18cdff63d71004d4a
                                    Module libcamelnntp.so with build-id 110ec4281c81ca2c21e77a737d0f7bca92d50951
                                    Module libdconfsettings.so with build-id 1e2f36b2fbc16f464b4c73e74f2b1dcbf12b6355
                                    Module libdl.so.2 with build-id 6fa316ff8958df953371c5a82f386eb885d1f576
                                    Module libdb-5.3.so with build-id 2a7a5afc50a52a9e24ab703087dbaac1df753d93
                                    Module libgck-1.so.0 with build-id 80530990be46f13df7ca72c69ab0ff5df3e50f8a
                                    Module libgmp.so.10 with build-id 35d9649c35f9752b0223e5613d43a52c97ca0282
                                    Module libhogweed.so.6 with build-id a01aee4ee0f2c450f608d7b7be1e3a460425ebc3
                                    Module libnettle.so.8 with build-id e51f131505f108cd0962edcfcd7b51901a2e19ce
                                    Module libtasn1.so.6 with build-id e64114db392bb17238bd5cb22dfd12e308db52b0
                                    Module libbrotlienc.so.1 with build-id 76053488c7e22034d59155c13d13d161849e3eab
                                    Module libp11-kit.so.0 with build-id 5c3eefdf311483790b33a8f76dc45a87f6769ecf
                                    Module libelf.so.1 with build-id 6528e29ed5d6455c8a184fbe6df40866fcc70b12
                                    Module libplc4.so with build-id 3496927897dcfe24ecd3e71eb7cea40b8c94d934
                                    Module libplds4.so with build-id 3798cac2d651247aca1953a03b36603274dfd5a8
                                    Module libnssutil3.so with build-id 05a25f30ba28e52336eb1380a90b8c4c3bc17415
                                    Module libabsl_time_zone.so.2111.0.0 with build-id 2ad0088579e6ab7bebf3057f738d0e22adbdf0ff
                                    Module libabsl_civil_time.so.2111.0.0 with build-id f23b9dc7872178385bb7e8266d1ce7ee9de2b50a
                                    Module libabsl_time.so.2111.0.0 with build-id ba99c3d20527cb422bfb8daa6bfe26ecbdfede4c
                                    Module libabsl_demangle_internal.so.2111.0.0 with build-id 4e49b30b877a8e2871ff4ef4430a935ffda39af2
                                    Module libabsl_debugging_internal.so.2111.0.0 with build-id 6acbefbcd8bb1344fbe10f680cfa00c705afc31a
                                    Module libabsl_malloc_internal.so.2111.0.0 with build-id 2b7e94146af323bada9de18458fd5fc27eac24b2
                                    Module libabsl_symbolize.so.2111.0.0 with build-id f2d24bcca688645af088f849300cb64f9299f8bb
                                    Module libabsl_stacktrace.so.2111.0.0 with build-id 64ab07c4399a87c6ef1562fca9073104f9273b92
                                    Module libabsl_graphcycles_internal.so.2111.0.0 with build-id 71d40bfc7171e67eeccb82ba5f99b7c58476d62b
                                    Module libabsl_synchronization.so.2111.0.0 with build-id a03b631b63711b833efd191872b4312dd939bee4
                                    Module libabsl_exponential_biased.so.2111.0.0 with build-id f2461c1b315cd7c66245770c6058b6d995c7a153
                                    Module libabsl_hashtablez_sampler.so.2111.0.0 with build-id 4bd8327d43b98a524f0b85b5a952a70f784683b4
                                    Module libabsl_int128.so.2111.0.0 with build-id 8edf48ebbbb843a37db227fea1904f9857abdcc5
                                    Module libabsl_spinlock_wait.so.2111.0.0 with build-id 29391513fa688223bd66969936648a1467dbebc0
                                    Module libabsl_log_severity.so.2111.0.0 with build-id ecb0495281aaba6e27775efd2c8a4010e799b990
                                    Module libabsl_raw_logging_internal.so.2111.0.0 with build-id 58abcd8a0f838ec2bc62813acec9dc20237dee08
                                    Module libabsl_base.so.2111.0.0 with build-id e223bd49c7cec794f6806e833b0d4136b51308d9
                                    Module libabsl_bad_variant_access.so.2111.0.0 with build-id 0d4b8339bd331e8bc282dc5c0ceba0db5c562aab
                                    Module libabsl_bad_optional_access.so.2111.0.0 with build-id d7f63d95a0f963907328de077d2a1a6206430372
                                    Module libabsl_strings_internal.so.2111.0.0 with build-id 9f1c4f8828901324f9996d4771f0cb7fa393656b
                                    Module libabsl_throw_delegate.so.2111.0.0 with build-id 29cc1ecfea33690227e6b4288f3865071a6170b7
                                    Module libabsl_low_level_hash.so.2111.0.0 with build-id 929f4d1a588776bb94f64e81171a278f8da30d90
                                    Module libabsl_city.so.2111.0.0 with build-id 758db4af4a2db8fc9ef9b169e641a83c007f647e
                                    Module liblz4.so.1 with build-id 6d85cb32490fa810dbc0b9cbb0043fc52e6ddba0
                                    Module libcap.so.2 with build-id ba39fbcf17238edd9188c42c664778b3da8d8975
                                    Module libebackend-1.2.so.10 with build-id 61559677f4c9fbcfaba214810d43ec55a20e10f2
                                    Module libgcr-base-3.so.1 with build-id ce8ee872d52cb38d63da444198c95ac49a1d4961
                                    Module libgoa-1.0.so.0 with build-id 5c9a21b8e1a85042057d7e378418a12175683857
                                    Module libicudata.so.71 with build-id 88055d582ad0bda24d5bb319dafeb2660ba9d459
                                    Module libssl3.so with build-id 1693c2241955a03e97f8a31ab16c21e6baac313a
                                    Module libtss2-sys.so.1 with build-id 89f439d4e09182afde87e097eac7dd585b5c6816
                                    Module libcrypto.so.1.1 with build-id 9d991c1890f3d1770c88bf2458c3764c1d2c3dda
                                    Module libzstd.so.1 with build-id dacfb4dea5ccf817614864ec38c35db7aa8cfdcc
                                    Module libXdmcp.so.6 with build-id c34a7b1d542b8fcb0adebca91cad73bc9e8fe921
                                    Module libXau.so.6 with build-id 8f008840b4549b6f657594fe676a282e63ad503c
                                    Module libbz2.so.1.0 with build-id 671b8e3830aec15cb5be944105925ff3cb0a7dd6
                                    Module libdatrie.so.1 with build-id 87fcb9f58297ecce72ebd75c568e00ecd71e61f7
                                    Module libstemmer.so.0 with build-id b1174135aa5983af4c4b5f2b00c314b425950bab
                                    Module libatspi.so.0 with build-id 3638d9abaab74a64682ed7338e90e4b1f4bde80c
                                    Module libexpat.so.1 with build-id 4abaf8b150c31c2879020778aff9e96650869be9
                                    Module libgraphite2.so.3 with build-id 9e11887a32ce782f664f0ab9c6bb0b7f53c9263e
                                    Module libtirpc.so.3 with build-id 477e2f79995885291906d9fbba5b1cd0765e4691
                                    Module libprotobuf-c.so.1 with build-id 95eb9c6bfbc63a275b61ba14ddf0c00fb55a2dba
                                    Module libgnutls.so.30 with build-id c8c411beca56610f31411f045ec646b3339c0931
                                    Module libdw.so.1 with build-id e17f4bae0cfb447e0e2fe73a8d6e6aa22ed06626
                                    Module libunwind.so.8 with build-id 61326672c6f2e4827bab44da3b6649c228cf8187
                                    Module liborc-0.4.so.0 with build-id 1900ddfb6c1970e18098181fe05a71b815b99674
                                    Module libnspr4.so with build-id 5504387c68e2274748a71b60117d7e04d58b21dd
                                    Module libnss3.so with build-id 05124ddc679924ac000de7d1b6cd7b83886ef097
                                    Module libsmime3.so with build-id 3fe95ad3cd348423d0ff0aaf74eef4150c11cd48
                                    Module libblkid.so.1 with build-id c2b0e80dcad7ea830bc336d2d2b6e8a6dae70355
                                    Module libresolv.so.2 with build-id 7b04c33881a5856b4772580959fb03ca224ddb02
                                    Module libkeyutils.so.1 with build-id bb7058f5ed47bb3eea0a0787373dbe5951200b3d
                                    Module libkrb5support.so.0 with build-id 03dd9e5cb57e38505a8ef49e32e1871c4e4f75f4
                                    Module libcom_err.so.2 with build-id 4d3519bec62821560a76e699c333c1386fd0dfc7
                                    Module libk5crypto.so.3 with build-id 0757331e0ff393768594cb153bf0123197b2b3e2
                                    Module libkrb5.so.3 with build-id 35bdefdfd4b2923f723b45a7f646ba94fd92eeb8
                                    Module libbrotlicommon.so.1 with build-id 04156f592cfadcf198f252eabfbc56b4c76249ac
                                    Module libidn2.so.0 with build-id be16fc6cb7814edc928c646a2f11ddfcc0ec1822
                                    Module libunistring.so.2 with build-id 42266638367f902c57ecd1f659ac285b0b18f98e
                                    Module liblzma.so.5 with build-id d34507011f065d2da4c4cc360615b2cd3ce3d4b2
                                    Module libabsl_strings.so.2111.0.0 with build-id c0781c49e9c3222a1971b5ee9f20fbd5a497b274
                                    Module libabsl_raw_hash_set.so.2111.0.0 with build-id 8fdadf6b0918e2fd4efc93dd28736208c37cef19
                                    Module libabsl_hash.so.2111.0.0 with build-id 946caae9330ec69affd5bb339978f1fbb380d907
                                    Module libboost_thread.so.1.79.0 with build-id 51e3a44cbc864f559e4f0002fbc06e0cccbabc0e
                                    Module libprotobuf.so.32 with build-id 0828bae3909c34fbc3099729d2315a43eb4fc82a
                                    Module libseccomp.so.2 with build-id a0f32d4db8542aaad0b5bfdb99da3c4faae6ec08
                                    Module libudev.so.1 with build-id 2239cd2c1c1d26f94ffc7186f74eab1ae500c7fc
                                    Module libxkbregistry.so.0 with build-id e7b492cffb8af7352a3ed5c10e88c9a67a00934a
                                    Module libsystemd.so.0 with build-id 468551920a3ea41bee03cfaa550b2abc5187c18e
                                    Module libenchant-2.so.2 with build-id 316753d3db4925f2c7ea852eb0559c6534c917db
                                    Module libedata-book-1.2.so.26 with build-id aa158f2e71876f1fb2267c2e9e4ac5f545bf225b
                                    Module libgdata.so.22 with build-id e99ce7fc54ebd1071ebfc700f0e3f070bee3811a
                                    Module libicuuc.so.71 with build-id 53ecd82d12c0528edd85aeff7b665e763b6174a9
                                    Module libicui18n.so.71 with build-id 2164e5091f47411702fed750939f44bb9c32f1b9
                                    Module libedbus-private.so with build-id 5a2ff30b8a560185a82b9301efff325d91f2ddba
                                    Module libcamel-1.2.so.63 with build-id 31d04fbd76179f2fb8029195cb1ef11966375788
                                    Module libtss2-tctildr.so.0 with build-id f8e135e68cd6ae5ed407e6725732370981e5688e
                                    Module libtss2-rc.so.0 with build-id b25412fe32b8371b9f10aafdb8214a061d7052a5
                                    Module libtss2-mu.so.0 with build-id b7ad82188a4a38093e687405f58b9def58759280
                                    Module libtss2-esys.so.0 with build-id 90e8247770c2280e96c05e0200236c9b93d127a8
                                    Module libtiff.so.5 with build-id 93b28227435b9f7f536a6ce90015cdbce0f155d8
                                    Module libjpeg.so.8 with build-id 3b429508e97a328f07e98ecae1a45f0d858bd943
                                    Module libpixman-1.so.0 with build-id a851566e1507d4413a41b61292aac5bd9756e005
                                    Module libxcb-shm.so.0 with build-id e613db3881d24cac716d8743f1e14382cd92bce5
                                    Module libxcb-render.so.0 with build-id 61c9ea5627fe0686b37fa560d0a59f756787ef7e
                                    Module libxcb.so.1 with build-id d14a0198d72f0e5c38a30b0bd51b005a63d5d04f
                                    Module libXrender.so.1 with build-id dadc45a68ffa250afeddb28077edc4bbe03249fb
                                    Module libfreetype.so.6 with build-id 109c44d125e314e149e66320746e4bb8ebeeeb5a
                                    Module libpng16.so.16 with build-id 29b168abcc30c146d3490f3aaf15193985f1a7ad
                                    Module libthai.so.0 with build-id 5c63f94a2609b8861e3aa24b8313ace0c300fbf1
                                    Module libXinerama.so.1 with build-id 8d06cc8e1ccb78c977e3b2ea887f23753baedf1b
                                    Module libXrandr.so.2 with build-id 8b979d44d2e8cf0d90b7e23df87e847074899bad
                                    Module libXcomposite.so.1 with build-id daa656de37dbf37cfbd2c1b3e25a53e9843b9c28
                                    Module libXdamage.so.1 with build-id 0ab5b716a744b64eaf0febc5362d0dd71077f8fc
                                    Module libXcursor.so.1 with build-id 0e61376c504eda0182f71dae68a656922c9293eb
                                    Module libXext.so.6 with build-id 7033fa6f103dd8cb8c35f55d2f0ec2fde6380c5d
                                    Module libwayland-egl.so.1 with build-id fcb595b35d959d324db30039f479e219fe327a6e
                                    Module libwayland-cursor.so.0 with build-id 461371a379757e686157d664e5cc7b5b30903c1d
                                    Module libwayland-client.so.0 with build-id 2d2e3e5b3c1ec06a5019ffcbb0778da03d10b6b1
                                    Module libxkbcommon.so.0 with build-id e170d688b38a7b6cda68754de5b70a09db45227d
                                    Module libXfixes.so.3 with build-id faf13dd9ba34dc8f956e99e969109547b64434e2
                                    Module libtracker-sparql-3.0.so.0 with build-id 8f2edbd42cf088801546abd2d3dae4ad0ada2938
                                    Module libcloudproviders.so.0 with build-id f8034d43d66af528f5b61ba6815ffd1e102e19db
                                    Module libatk-bridge-2.0.so.0 with build-id 6995228605c9a12c1763fd35eb22b0ca94285f10
                                    Module libX11.so.6 with build-id 07763d58f5bb5afd5cebc010f73055aa7a90721a
                                    Module libXi.so.6 with build-id e15421edebb0055f4063c4f3ce15a9d789580fdc
                                    Module libepoxy.so.0 with build-id 1cf5f978e17e03543476a9ceb3367c76c569db98
                                    Module libatk-1.0.so.0 with build-id a8cbc210232439890611607ba668fe089b5d58e0
                                    Module libcairo-gobject.so.2 with build-id 4276f9abfd948f50bf5624faf10b4b5e76b58034
                                    Module libfribidi.so.0 with build-id 21a0b71b6569ab984d3f5198adc0b4046498323c
                                    Module libfontconfig.so.1 with build-id 1bad17c3f12be0e465347fd7a39afa7ee6da54ab
                                    Module libpangoft2-1.0.so.0 with build-id 0298a08f4b516b6573b4dada230d4a4e1e7eec96
                                    Module libharfbuzz.so.0 with build-id e6f66f69f7affee6e1b5895d178414935964ae82
                                    Module libpangocairo-1.0.so.0 with build-id 4e21952326d4f58f4d5d51a523056beed221b041
                                    Module libsasl2.so.3 with build-id df9a7ade658a11aaf6480b62b8e5d204678247cd
                                    Module libnsl.so.3 with build-id 811a8f52791dc54001405faf7b173b65511b94a8
                                    Module libm.so.6 with build-id 061d75252b42faa79887b44cec63eb025035f99f
                                    Module libgadu.so.3 with build-id 47443883cb0be977dc72687ce5ce653b78c4f724
                                    Module libidn.so.12 with build-id cb9bbaa04d6f3b098932710c8e3af2b898de809a
                                    Module libgstreamer-1.0.so.0 with build-id 4288654e637828f424f46e03677fb488a42938ec
                                    Module libgstbase-1.0.so.0 with build-id 08d43162e70372a5f25e0d37e3727ba80bd8954f
                                    Module libgstapp-1.0.so.0 with build-id b72096d64c8ebb8448a48ea9db951c7315e99c35
                                    Module libgstvideo-1.0.so.0 with build-id e27200f5e9ba8a2449465bcbc5c76b3b35b501bf
                                    Module libfarstream-0.2.so.5 with build-id a33c1f13b87a10083fc9df0efe3ba24ddfec161a
                                    Module libnm.so.0 with build-id 2d49cc9bd3e04480f124ed4770b4e94fc02f044d
                                    Module libgthread-2.0.so.0 with build-id 5eff24ec6f9c7c6c37a63c1f77e634f9045d7de6
                                    Module libdbus-1.so.3 with build-id 15748dc82a87ed7b2fac67d0e3145a65fc7662aa
                                    Module libdbus-glib-1.so.2 with build-id 42d06bd8eed69e9393d31feaf1f292a896def84e
                                    Module libffi.so.8 with build-id 5103e7b5b7addb8026a35a62734fefd1c7ef5c64
                                    Module libmount.so.1 with build-id 4e047119cfe3165e1a34913a55537c30d6746c5b
                                    Module libpcre.so.1 with build-id 75dc63d269e8b1acbd020273e4ada841b6217666
                                    Module libpthread.so.0 with build-id 5fb84aef10e18bc3fcfdbfff64d8bd82f2b62232
                                    Module libz.so.1 with build-id b4b17bbf3e5421036ed035fb06a26109d4b0d4fe
                                    Module libgssapi_krb5.so.2 with build-id b9dfd0c3c95073f97ac3a5f919e5f4cf9da07b74
                                    Module libbrotlidec.so.1 with build-id e290ba34ca052f62e053a9bc510745f064bd7b43
                                    Module libpsl.so.5 with build-id 213d37a55930e1f0d86dee8091aa144e64c19fca
                                    Module libxml2.so.2 with build-id 71cbddf1e72bd68cfc278c48769b935040b0a4f8
                                    Module libgmodule-2.0.so.0 with build-id fc4d4a4d2bb1a4f8019dc3ade44a0f2e7a5a67de
                                    Module libgpg-error.so.0 with build-id eb33d6d304779773a5d2e80d63ffd7c365f9b201
                                    Module libc.so.6 with build-id a11e506985b1f3d7eb868fc58de1473a19d5ebd0
                                    Module libgcc_s.so.1 with build-id 977d93f2a20a599052cf3d0910f4a43614d2129d
                                    Module libstdc++.so.6 with build-id 013f6ffe3ad4158f8188963e2808129d90be5579
                                    Module libphonenumber.so.8 with build-id b79252f33ce7c8b3067ed0aabe702b2e678a0439
                                    Module libfeedback-0.0.so.0 with build-id 472ae31232069f8d82f82dcfb240c28b437eac64
                                    Module libgnome-desktop-3.so.19 with build-id d660254b8f600f197e5993c2dde80d6c5b38d0e6
                                    Module libgspell-1.so.2 with build-id f636253de440f1b7a1e3d654ba240d72a78fe8f0
                                    Module libebook-1.2.so.20 with build-id 8b7491bec216a61556bfd20090684e5e7d7059df
                                    Module libedataserver-1.2.so.26 with build-id 5c19a77ed0ba1ee669962f0a477e6704bec45788
                                    Module libebook-contacts-1.2.so.3 with build-id 670f4136644078765a4899372ea4e58b2f973fc9
                                    Module libsqlite3.so.0 with build-id 607e40f63904e3f45b9361ef75e067f94bb5d7d6
                                    Module libhandy-1.so.0 with build-id 9c264b01087bf8e0a2036d65116ba7c8d0c20b5f
                                    Module libsecret-1.so.0 with build-id 6fc24a35ba15e34b4dcaddaa7866eca71f6ccf3e
                                    Module libgdk_pixbuf-2.0.so.0 with build-id 07f1aed5605ab62376bc8e0d47e9de0168487890
                                    Module libcairo.so.2 with build-id cb7c5b73e8599a0b58682b3d82c81e0f94fdcb8f
                                    Module libpango-1.0.so.0 with build-id bd0f3d300f6b12bcae6aa22f6f280a3010a17221
                                    Module libgdk-3.so.0 with build-id 44828f1e988e79bafc82fbc15e01cc27746f8c60
                                    Module libgtk-3.so.0 with build-id 024639ab2ecc365dd797689cee241c4bdbd2d086
                                    Module libjabber.so.0 with build-id c2621aea4259975c812fe67c583256e4f37f8644
                                    Module libpurple.so.0 with build-id f7c7442c6e7af832a2b0977a8d32a7d81729c877
                                    Module libmm-glib.so.0 with build-id b45be40dba4bb3ecb7ef530280e98203ba48327a
                                    Module libolm.so.3 with build-id f716eb41629724328b3dd4b58da36b508057b7f7
                                    Module libjson-glib-1.0.so.0 with build-id 743f474e2128f6c9656e33700e3c25afd0d9ecf2
                                    Module libgobject-2.0.so.0 with build-id 1efd784b2c6881fcdfac34e08bbadd8ce00fb35d
                                    Module libgio-2.0.so.0 with build-id 12412bffe778c2f8bccafffe6cb10b7e820107d8
                                    Module libglib-2.0.so.0 with build-id c0aaa06e0a3d9679012e7770d2c288c3af02852f
                                    Module libsoup-2.4.so.1 with build-id f1aa02714ec9a117c402a16e0230d1a0a516b2a9
                                    Module libgcrypt.so.20 with build-id b10fee43a15f81876aeadec4e734decfc4214e4e
                                    Module chatty with build-id 8da3ac9454db33f225e25a0dbc01415d9da1a66e
                                    Stack trace of thread 6270:
                                    #0  0x0000aaaade73a214 chatty_mm_account_start_chat (chatty + 0x6a214)
                                    #1  0x0000aaaade73aa70 n/a (chatty + 0x6aa70)
                                    #2  0x0000aaaade73b844 n/a (chatty + 0x6b844)
                                    #3  0x0000ffffbaf3b038 n/a (libgio-2.0.so.0 + 0xdb038)
                                    #4  0x0000ffffbaf3c00c n/a (libgio-2.0.so.0 + 0xdc00c)
                                    #5  0x0000ffffbac7a2b0 n/a (libmm-glib.so.0 + 0x5a2b0)
                                    #6  0x0000ffffbaf3b038 n/a (libgio-2.0.so.0 + 0xdb038)
                                    #7  0x0000ffffbaf3c00c n/a (libgio-2.0.so.0 + 0xdc00c)
                                    #8  0x0000ffffbafc2bb0 n/a (libgio-2.0.so.0 + 0x162bb0)
                                    #9  0x0000ffffbaf3b038 n/a (libgio-2.0.so.0 + 0xdb038)
                                    #10 0x0000ffffbaf3c00c n/a (libgio-2.0.so.0 + 0xdc00c)
                                    #11 0x0000ffffbafc17b0 n/a (libgio-2.0.so.0 + 0x1617b0)
                                    #12 0x0000ffffbaf3b038 n/a (libgio-2.0.so.0 + 0xdb038)
                                    #13 0x0000ffffbaf3c00c n/a (libgio-2.0.so.0 + 0xdc00c)
                                    #14 0x0000ffffbafb1110 n/a (libgio-2.0.so.0 + 0x151110)
                                    #15 0x0000ffffbaf3b038 n/a (libgio-2.0.so.0 + 0xdb038)
                                    #16 0x0000ffffbaf3b088 n/a (libgio-2.0.so.0 + 0xdb088)
                                    #17 0x0000ffffbb112738 g_main_context_dispatch (libglib-2.0.so.0 + 0x62738)
                                    #18 0x0000ffffbb112d10 n/a (libglib-2.0.so.0 + 0x62d10)
                                    #19 0x0000ffffbb112df4 g_main_context_iteration (libglib-2.0.so.0 + 0x62df4)
                                    #20 0x0000ffffbaf765b0 g_application_run (libgio-2.0.so.0 + 0x1165b0)
                                    #21 0x0000aaaade6f8610 main (chatty + 0x28610)
                                    #22 0x0000ffffb9387b80 n/a (libc.so.6 + 0x27b80)
                                    #23 0x0000ffffb9387c60 __libc_start_main (libc.so.6 + 0x27c60)
                                    #24 0x0000aaaade6f86f0 _start (chatty + 0x286f0)
                                    Stack trace of thread 6271:
                                    #0  0x0000ffffb94404d8 __poll (libc.so.6 + 0xe04d8)
                                    #1  0x0000ffffbb112c60 n/a (libglib-2.0.so.0 + 0x62c60)
                                    #2  0x0000ffffbb112df4 g_main_context_iteration (libglib-2.0.so.0 + 0x62df4)
                                    #3  0x0000ffffbb112e7c n/a (libglib-2.0.so.0 + 0x62e7c)
                                    #4  0x0000ffffbb1437ac n/a (libglib-2.0.so.0 + 0x937ac)
                                    #5  0x0000ffffb93e0aec n/a (libc.so.6 + 0x80aec)
                                    #6  0x0000ffffb944a5dc n/a (libc.so.6  + 0xea5dc)
                                    Stack trace of thread 6273:
                                    #3  0x0000ffffb2edc564 n/a (libdconfsettings.so + 0xc564)
                                    Stack trace of thread 6275:
                                    #2  0x0000ffffbb113100 g_main_loop_run (libglib-2.0.so.0 + 0x63100)
                                    #3  0x0000ffffb9a16eb4 n/a (libedataserver-1.2.so.26 + 0x76eb4)
                                    Stack trace of thread 6278:
                                    #0  0x0000ffffb9446424 syscall (libc.so.6 + 0xe6424)
                                    #1  0x0000ffffbb174a90 g_cond_wait (libglib-2.0.so.0 + 0xc4a90)
                                    #2  0x0000ffffbb0d8238 n/a (libglib-2.0.so.0 + 0x28238)
                                    #3  0x0000ffffbb0d8880 g_async_queue_pop (libglib-2.0.so.0 + 0x28880)
                                    #4  0x0000aaaade781dfc n/a (chatty + 0xb1dfc)
                                    #5  0x0000ffffbb1437ac n/a (libglib-2.0.so.0 + 0x937ac)
                                    #6  0x0000ffffb93e0aec n/a (libc.so.6 + 0x80aec)
                                    #7  0x0000ffffb944a5dc n/a (libc.so.6 + 0xea5dc)
                                    Stack trace of thread 6283:
                                    #1  0x0000ffff99bc9140 n/a (libpulse.so.0 + 0x39140)
                                    #2  0x0000ffff99bb9030 pa_mainloop_poll (libpulse.so.0 + 0x29030)
                                    #3  0x0000ffff99bb97cc pa_mainloop_iterate (libpulse.so.0 + 0x297cc)
                                    #4  0x0000ffff99bb98c0 pa_mainloop_run (libpulse.so.0 + 0x298c0)
                                    #5  0x0000ffff99bc9250 n/a (libpulse.so.0 + 0x39250)
                                    #6  0x0000ffff99b54d5c n/a (libpulsecommon-16.1.so + 0x64d5c)
                                    #7  0x0000ffffb93e0aec n/a (libc.so.6 + 0x80aec)
                                    #8  0x0000ffffb944a5dc n/a (libc.so.6 + 0xea5dc)
                                    Stack trace of thread 6282:
                                    #1  0x0000ffff99c423bc n/a (libmicrodns.so.1 + 0x23bc)
                                    #2  0x0000ffff99c427e0 mdns_listen (libmicrodns.so.1 + 0x27e0)
                                    #3  0x0000ffff99c61dd0 n/a (libgstmicrodns.so + 0x1dd0)
                                    Stack trace of thread 6276:
                                    #1  0x0000ffffbb174c2c g_cond_wait_until (libglib-2.0.so.0 + 0xc4c2c)
                                    #2  0x0000ffffbb0d81f4 n/a (libglib-2.0.so.0 + 0x281f4)
                                    #3  0x0000ffffbb0d8a7c g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x28a7c)
                                    #4  0x0000ffffbb144570 n/a (libglib-2.0.so.0 + 0x94570)
                                    Stack trace of thread 6272:
                                    #3  0x0000ffffbafc5d84 n/a (libgio-2.0.so.0 + 0x165d84)
                                    Stack trace of thread 6279:
                                    #3  0x0000ffffb9962fe0 n/a (libebook-1.2.so.20 + 0x12fe0)
                                    Stack trace of thread 6284:
                                    #1  0x0000ffff997c4318 n/a (libusb-1.0.so.0 + 0x14318)
                                    #2  0x0000ffffb93e0aec n/a (libc.so.6 + 0x80aec)
                                    #3  0x0000ffffb944a5dc n/a (libc.so.6 + 0xea5dc)
                                    Stack trace of thread 6285:
                                    #3  0x0000ffff9972ff7c n/a (libgstvideo4linux2.so + 0xff7c)
                                    ELF object binary architecture: AARCH64
manjaro-arm systemd[1]: systemd-coredump@5-6297-0.service: Deactivated successfully.
manjaro-arm systemd[1]: systemd-coredump@5-6297-0.service: Consumed 4.247s CPU time.
chatty---debug output in terminal:
20:00:10.7136            GStreamer[ 6270]:CRITICAL: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
20:00:10.7144            GStreamer[ 6270]:CRITICAL: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
20:00:11.4852                   **[ 6270]: WARNING: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
20:00:11.4872                   **[ 6270]: WARNING: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
20:00:11.4893                   **[ 6270]: WARNING: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
20:00:11.4914                   **[ 6270]: WARNING: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
20:00:11.4937                   **[ 6270]: WARNING: Error loading plugin: libhunspell-1.7.so.0: cannot open shared object file: No such file or directory
20:00:11.4961                   **[ 6270]: WARNING: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
20:00:11.4982                   **[ 6270]: WARNING: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
20:00:11.5002                   **[ 6270]: WARNING: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
20:00:11.5024                   **[ 6270]: WARNING: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
20:00:11.5044                   **[ 6270]: WARNING: Error loading plugin: libhunspell-1.7.so.0: cannot open shared object file: No such file or directory
(20:00:12) mediamanager: Registered Audio/Source device Built-in Audio Headset Microphone + Internal Microphone
(20:00:12) mediamanager: Registered Audio/Sink device Built-in Audio Headphones + Internal Earpiece + Internal speaker
(20:00:12) mediamanager: Registered Video/Source device sun6i-csi
Segmentation fault (core dumped)
I solved the issue by reinstalling the stable beta 24, installing manually rtkit and realtime-privileges and then adding my user to both groups:
sudo pacman -S rtkit realtime-privileges
sudo gpasswd -a manjaro rtkit
sudo gpasswd -a manjaro realtime
I’m not sure if the latter is really necessary but now I can update from stable or unstable and chatty works. So it seems important to include rtkit in the images that uses wireplumber.
