Manjaro ARM Beta21 of Phosh for PinePhone!
The Manjaro ARM project is proud to announce our twentyfirst BETA release for the PinePhone running Phosh!
Those images either run the 5.16 kernel from Megi, which are is designed for the PinePhone or 5.16 kernel by Mobian, which supports the PinePhonePro.
Features:
- Firefox uses a dedicated configuration and plays videos on Youtube pretty well
- Camera app with access to back and front camera, including autofocus
- Auto-Rotate function and manual rotate
- Welcome wizard for easy setup of the device
- We have now a working Torch in the quick-access-menu
- Prime phone functions working, including resume from deep-sleep and free speaking
- Recording of audio works
- Most applications got added to
scale-to-fit - Haptic feedback functions are given
- Optimized keyboard layout for terminal
- Maps working with geolocate
- Volume buttons working
- Sensors fully functional
- Easy access to Bluetooth, Wlan, Rotate and Mobile functions via quick settings
- Default branch is
arm-stable. This can be changed by editing/etc/pacman-mirrors.conf - usage of callaudiod for better audio experience with calls
- This image uses a Crust enabled uboot
Changes since Beta20
- Kernel got updated to 5.16.2
- switched to Pipewire
- PipeWire is now at 0.3.43 including some additional upstream patches to make switching of audio-profiles work
Phosh and Phoc got additional patches
- we support now complex passwords at lockscreen
- initial VPN support got added
- supports to dismiss notifications via swipes
- alsa-ucm-pinephone gained more adjustments for the PinePhonePro
chatty is now at 0.6.0-beta
- this version of Chats updates the database schema
- History of SMS/MMS need to been cleaned, else the the app will crash
- you may move the file ~/.purple/chatty/db/chatty-history.db.xxxx (where xxxx is a unix timestamp) to a backup directory of yours
- Calls got renewed to 42alpha0
- megapixels is at 1.4.3
- phoc 0.11.0 uses now wlsroot 0.15.0
- eg25-manager gained more audio improvement for the PinePhonePro and handles now modem firmware flashes much better. Preparation for fwupd
- gnome-calls 42alpha0 got additional UX improvements added
- pinephone-manjaro-tweaks fixed an issue with upgrading the Plasma-Mobile Factory image of PinePhone Beta Edition to be able to update via Discover
- squeekboard got a new stable release as in 1.15.0
- Mesa is at 21.3.4
- Xorg-Server is at 21.1.3
- mmsd-tng is now at 1.7
- siglo is at 0.9.6
- callaudiod got renewed to 0.1.3 including more enhancements for pipewire and tracks and exports current states
- Bluez is now at 5.63
- Gnome parts are now at 41.3
- Firefox got updated to 96.0.2
- Systemd is now at 250.3
- Python got updated to 3.10
- Uboot for the regular Pinephone got updated to 2022.01
- We dropped Telegram including Qt5 and Qt6
- We use now a more mobile friendly version of Gnome-Clocks
A detailed list of package changes can be found here.
Currently broken:
- GPS may not work as it should
Known issues
Chatty may crash with experimental features like MMS enabled. You may disable them via
gsettings set sm.puri.Chatty experimental-features falseif that is the case - UI becomes unresponsive after a while.
- Doing a recording may result in noisy audio savings
- Lots of apps are still missing or are not mobile friendly yet.
Download:
About the device:
PinePhone:
Perhaps youâre in a line of work where security is a must, or a hard-core Linux enthusiast, or perhaps youâve just got enough of Android and iOS and youâre ready for something else â the PinePhone may be the next Phone for you. Powered by the same Quad-Core ARM Cortex A53 64-Bit SOC used in our popular PINE A64 Single Board Computer, the PinePhone runs mainline Linux as well as anything else youâll get it to run.
The purpose of the PinePhone isnât only to deliver a functioning Linux phone to end-users, but also to actively create a market for such a device, as well as to support existing and well established Linux-on-Phone projects. All major Linux Phone-oriented projects, as well as other FOSS OSâ, are represented on the PinePhone and developers work together on our platform to bring support this this community driven device.
Order
Pinephones Beta Edition are still on stock. Visit the Pine64 Store
How to install:
Download the image/xz file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn the to an SD card (8 GB or larger).
The PinePhone should recognize the SD card as a bootable device and boot from it.
The premade users are:
User: manjaro
Password: 123456
User: root
password: root
Donate!
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Bugtracker
If you face issues with this editon, please open a new issue on our bug-tracker
Development Changelog
We will list our progress to Beta22 here
- Beta21 (2022-01-24) Download
- based on stable branch
- Dev (2022-01-28) Download
- based on unstable branch
- Pipewire got updated to 0.3.44 including the needed fixes to make audio profile switching work
- Chatty got renewed to 0.6.0.
- Firefox is now at 96.0.3
- Calls got its first Beta1 of 42 release series
- Mesa is now at 21.3.5
- We added some more fixes and improvements to Pamac
- Phoc is now at 0.12.0 and uses wlroots 0.14.1
- Phosh got updated to 0.15.0
- Squeekboard is now at 0.16.0
- Dev (2022-02-02) Download
- Chatty and Calls gained UI improvements and SMS/MMS enhancements
- We updated the device profiles for Pinephone(Pro)
- More fixes went into Pamac to have a better AUR support
- Phosh gained some UI polish and small fixes
- squeekboard adopted more the overall design/look
- Kernel is now at 5.16.5
- Dev (2022-02-07) Download
- Kernel got updated to 5.16.7
- Pipewire is at 0.3.45
- Chatty gained more MMS fixes
- Calls got some more fixes in regard of SIP
- More small AUR fixes for Pamac got added
- Phosh gained some improvements with power management
- Phoc got small fixes in regard of keyboard managmenet added
