Manjaro ARM Beta 21 with Phosh (PinePhone / PinePhonePro)
I haven’t had a look at the logs for it yet, but I have found Waydroid fails to launch on the PinePhone Pro build of Manjaro Phosh edition Beta 21.
Same issue waydroid didn’t work
Updating like @vincentm also worked for me. Cheers. I noticed the phone wanted to suspend a number of times while the update was downloading/running in the terminal. I had to actively keep is awake. Perhaps suspend was the reason for the black screen.
One hick-up was mobile data. Although wifi was active/stable, the update from beta20 ate the mobile data contingent first.
Thanks for Manjaro ARM + Phosh – this is working really well on PinePhonePro! A few issues with audio+bluetooth but the experience is mostly awesome!
Wanted to leave a quick note for anyone trying to use this with T-Mobile. MMS might not work out of the box but you can set your APN in settings and then edit configuration data under ~/.mms using the info from T-Mobile’s BYOD Page – restart then MMS picks right up.
