for more info see here:
and here:
and here:
A post was split to a new topic: Passwordsafe issues
Is it time to switch to Manjaro Phosh on PinePhonePro?
Are just no releasing any new Plasma KDE images/builds or is Phosh just moving way faster forward?
You shouldnât need to re-install the OS each time there is an update.
There will be an updated image soon, when the new Plasma stuff gets into stable branch.
Why are binder and ashmem modules not added to the kernel by default? Canât even install them via dkms
Binder is built into the kernel. Ashmem no longer exists from kernel 5.18 and above. Software should be able to use memfd
(I think itâs called) instead.
Hmm okay, but Waydroid is still missing ashmem. Maybe I have an outdated version. memfd is present
According to this issue on waydroid, if ashmem is not found it should automatically use memfd.
Hmm doesnât work. Guess I just have to be patient
Same for me. Clients connect but no data is transferred. Checked for default route and nameservers but I canât get it to work. Also I canât find documentation about restoration of defaults. file permissions or involved services.
See my post here for info about why hotspot doesnât work.
