ht tps://ibb.co/mGY74j1
(sorry I am not allowed to post media or links. it is a link to a GIF showing my messed up terminal input)
It was like this from the beginning.
Do you know anything about this problem?
Hello, has video acceleration been turned off? Videos on chromium are now extremely choppy. On chrome://gpu/
Problems Detected
Accelerated video decode is unavailable on Linux: 137247, 1032907 Disabled Features: accelerated_video_decode
Protected video decoding with swap chain is for certain Intel and AMD GPUs on Windows: 1093625 Disabled Features: protected_video_decode
Clear uniforms before first program use on all platforms: 124764, 349137 Applied Workarounds: clear_uniforms_before_first_program_use
Always rewrite vec/mat constructors to be consistent: 398694 Applied Workarounds: scalarize_vec_and_mat_constructor_args
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715 Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Some drivers canât recover after OUT_OF_MEM and context lost: 893177 Applied Workarounds: exit_on_context_lost
Hi. I am having the same experience with the latest Xfce image for rockpi4b. It works more smoothly with the previous images. Is installing xf86-video-fbturbo-git enough? how would be the procedure to do that? Thank you.
Hello, thanks for the answer. I was testing i3wm with this same version and I got the impression that being lighter it behaved better. but I had problems: for example with the screen resolution settings. It only proposed 1920x1280 and I need to change to 1024x768 and I could not do it. Sorry My English.
Well, after a pretty hard struggle, I couldnât change the screen resolution, but I did change the font size for the whole system, which solved my problem. Whatâs more, I donât know if itâs because I broke my head trying to solve the problem, but Iâm very happy with the result, given the simplicity of the solution, and the satisfaction of the result: change Xft.dpi: 192 in ~ /. Xresources made all the letters enlarged.
Hi @Strit, Is there anyway to boot Manjaro 20.08 for AllWinner H5 SoC?
I also noticed that thereâs a different Algorithm for booting up between Version 20.06 and 20.08
Just for Info:
I can boot in Armbian using this box using Balbes150âs Latest Image + U-Boot Patch.
For Version 20.08, do you need to add uboot.sd & uboot.ext like in Armbianâs latest image by Balbes150?
I downloaded the Khadas Vim 1 xfce & kde plasma Ver 20.08, and also Pinebook kde plasa Ver 20.08, then burn it to sdcard using Etcher, then change the extlinux.conf. Then Plug it into the box, then nothing happen.
Manjaro ARM does not currently support any Allwinner H5 SoCâs as far as I know. And you would need at least an âalmostâ correct uboot binary for the H5 to get it to boot, which we donât have.
However, when I applied this patch via etcher in Manjaro SD Card, the image become unrecognized partition. I donât know what is wrong? But, in Armbian it went smoothly using this uboot patch.
We do
NanoPi Neo Plus 2 which I use for Dockers on Manjaro ARM.
Yes you can use that or just use uboot-nanopi-neo-plus2 pkg or just create an image for it from Manjaro Arm Flasher for neo-plus2
Maybe youâre flashing it wrong or the uboot needs boot.scr which we donât use.
Can you build Neo Plus 2 Image directly from Manjaro Arm Flasher and replace the dtb in extlinux.conf
