Hanzel
15 August 2021 14:30
63
Used the Gnome minimalist ISO in kvm.
Error reported by @Sincide is gone.
Rebooting after install: the layout previews (the wireframes if that is a good name?) where almost impossible to see. After rebooting this behavior was gone, this could be a issue on my end tho.
Pleasantly surprised with the default snapshot when updating.
Layout switcher settings:
Dynamic wallpapaper open button does nothing, starting gnome-layout-switcher
reveals the following when pressing the button:
/bin/sh: line 1: dynamic-wallpaper-editor: command not found
Enabling the window tiling option does not appear to do anything, the console reveals:
Extension āpop-shell@system76.comā does not exist
Pop-shell was turned on
The tiling option on the layouts enables the material shell.
If the pop-shell will not be supported, the option could be temporarily removed?
Excellent work so far
Thatās a known issue still being worked on.
Install dynamic-wallpaper-editor
, itās an optional dependency.
Install gnome-shell-extension-pop-shell
, itās also an optional dependency.
We were thinking of either creating a prompt to install missing packages or automatically installing them, but havenāt gotten around to it yet.
With Manjaro 21.0.7 XFCE cups daemon is not enabled with installation.
Printing is - I think - standart with every computer system.
Is it possible to enable cups background service with installation ?
just a minor thing @philm (EDIT wrong Mod was Fabby) - for those who are tl;dr the link to the RC in the first paragraph always points to a specific tag, correct would be Releases Ā· manjaro/release-review Ā· GitHub (always showing the newest release-review). Might cause unnecessary confusion and wrong error reports from the hasty Thanks for all the work!
There are users who donāt want to install a printer. For the ones who do ā¦
Just open a terminal and with a few commands you can configure your printer
sudo pacman -S --noconfirm manjaro-printer;sudo gpasswd -a your username sys
sudo systemctl enable cups.service;sudo systemctl enable cups.socket;sudo systemctl enable cups.path;sudo systemctl enable --now cups.service
Just type print in the menu and you can configure with midori
In Manjaro 21.0.7 KDE cups service is enabled during installation.
Like me ⦠I am glad that the minimal.iso is offered, where for me unnecessary stuff is not even installed. Please NEVER give up the minimal ISO!
AlanP
16 August 2021 13:25
70
Hi team,
I made a fast short test of the live usb Manjaro KDE 21.1 minimal (202108151035). I received a notification error at the start of the desktop:
Matray ā Error
āError occured fetching news: cannot resolve hostnameā
Note: I was not connected to the internet (offline).
Tomorrow I will do an installation for testing.
I have now the 21.1 rc for a while here running. matray I had to disable, however, because the had never updated after the 1.x, ie . the messages, which came immediately after the 1st start, then remained. For me worthless (am anyway constantly logged in here ā¦)
XRaTiX
16 August 2021 13:55
72
But the normal iso is disabled by default,sure maybe you can disable it in the minimal iso by default but not on the normal iso.
I installed the minimal ISO. matray
was easy to remove from the autostart.
pulsar
16 August 2021 19:18
74
I installed the āmanjaro-kde-21.1-stable-staging-210815-linux513ā iso. I get eerror when installed packages.
ldconfig: /usr/lib/libpamac-snap.so.11 is not a symbolic link
ldconfig: /usr/lib/libpamac-flatpak.so.11 is not a symbolic link
pamac install gimp ī² ā
Preparing...
Resolving dependencies...
Checking inter-conflicts...
To install (19):
babl 0.1.86-1 (Required By: gimp) extra 315.1 kB
libspiro 1:20200505-2 (Required By: gimp) extra 17.2 kB
libgexiv2 0.12.3-1 (Required By: gimp) community 114.5 kB
luajit 2.0.5-3 (Required By: gimp) community 308.0 kB
lensfun 0.3.95-4 (Required By: gimp) extra 357.5 kB
metis 5.1.0.p10-2 (Required By: gimp) extra 170.7 kB
blas 3.10.0-1 (Required By: gimp) extra 128.8 kB
lapack 3.10.0-1 (Required By: gimp) extra 2.5 MB
tbb 2020.3-1 (Required By: gimp) extra 402.8 kB
suitesparse 5.10.1-1 (Required By: gimp) extra 1.1 MB
gegl 0.4.30-6 (Required By: gimp) extra 2.2 MB
libmypaint 1.6.1-1 (Required By: gimp) extra 237.2 kB
libwmf 0.2.12-2 (Required By: gimp) extra 1.9 MB
mypaint-brushes1 1.3.1-1 (Required By: gimp) extra 1.4 MB
gtk2 2.24.33-2 (Required By: gimp) extra 6.2 MB
netpbm 10.73.36-1 (Required By: gimp) extra 1.9 MB
gts 0.7.6.121130-2 (Required By: gimp) extra 216.0 kB
graphviz 2.48.0-2 (Required By: gimp) extra 4.0 MB
gimp 2.10.24-6 extra 21.0 MB
Total download size: 44.5 MB
Total installed size: 213.6 MB
Apply transaction ? [y/N] y
Download of lensfun (0.3.95-4) started
Download of libspiro (1:20200505-2) started
Download of libspiro (1:20200505-2) finished
Download of babl (0.1.86-1) started
Download of lensfun (0.3.95-4) finished
Download of babl (0.1.86-1) finished
Download of blas (3.10.0-1) started
Download of tbb (2020.3-1) started
Download of blas (3.10.0-1) finished
Download of tbb (2020.3-1) finished
Download of libgexiv2 (0.12.3-1) started
Download of luajit (2.0.5-3) started
Download of luajit (2.0.5-3) finished
Download of libgexiv2 (0.12.3-1) finished
Download of metis (5.1.0.p10-2) started
Download of lapack (3.10.0-1) started
Download of metis (5.1.0.p10-2) finished
Download of suitesparse (5.10.1-1) started
Download of suitesparse (5.10.1-1) finished
Download of netpbm (10.73.36-1) started
Download of lapack (3.10.0-1) finished
Download of gts (0.7.6.121130-2) started
Download of gts (0.7.6.121130-2) finished
Download of gegl (0.4.30-6) started
Download of netpbm (10.73.36-1) finished
Download of libwmf (0.2.12-2) started
Download of gegl (0.4.30-6) finished
Download of mypaint-brushes1 (1.3.1-1) started
Download of libwmf (0.2.12-2) finished
Download of mypaint-brushes1 (1.3.1-1) finished
Download of gtk2 (2.24.33-2) started
Download of libmypaint (1.6.1-1) started
Download of libmypaint (1.6.1-1) finished
Download of graphviz (2.48.0-2) started
Download of graphviz (2.48.0-2) finished
Download of gimp (2.10.24-6) started
Download of gtk2 (2.24.33-2) finished
Download of gimp (2.10.24-6) finished
Checking keyring... [19/19]
Checking integrity... [19/19]
Loading packages files... [19/19]
Checking file conflicts... [19/19]
Checking available disk space... [19/19]
Installing lensfun (0.3.95-4)... [1/19]
Installing libspiro (1:20200505-2)... [2/19]
Installing tbb (2020.3-1)... [3/19]
Installing babl (0.1.86-1)... [4/19]
Installing blas (3.10.0-1)... [5/19]
Installing libgexiv2 (0.12.3-1)... [6/19]
Installing luajit (2.0.5-3)... [7/19]
Installing metis (5.1.0.p10-2)... [8/19]
Installing lapack (3.10.0-1)... [9/19]
Installing suitesparse (5.10.1-1)... [10/19]
Installing gegl (0.4.30-6)... [11/19]
Installing netpbm (10.73.36-1)... [12/19]
Installing gts (0.7.6.121130-2)... [13/19]
Installing libmypaint (1.6.1-1)... [14/19]
Installing libwmf (0.2.12-2)... [15/19]
Installing mypaint-brushes1 (1.3.1-1)... [16/19]
Installing gtk2 (2.24.33-2)... [17/19]
Installing graphviz (2.48.0-2)... [18/19]
Installing gimp (2.10.24-6)... [19/19]
Arming ConditionNeedsUpdate... [1/7]
Refreshing PackageKit... [2/7]
Warn about old perl modules [3/7]
Probing GDK-Pixbuf loader modules... [4/7]
Probing GTK2 input method modules... [5/7]
Updating icon theme caches... [6/7]
Updating the desktop file MIME type cache... [7/7]
Super minimal thingie pacman -Sy yay
brings up the āAUR detecetd ⦠blahā GTK dialog. Donāt click cancel, but OK and the next dialog has āgtk_okā on the ok button. not even sure if thatās a manjaro thing ā¦
frau-nein-gekocht:
gtk_ok
GTK is
You can submit an issue for Pamac here:
~~Sign in Ā· GitLab
Itās easy for the developers to see and keep track of issues there.
EDIT: Might want to mention the yaourt
bit, too. Thatās long deprecated and insecure.
EDIT: Thatās manjaro-aur-support
, not Pamac. See Philās response below.
āJaja, double holds bettaā Thanks for pointing that out, Iāll try that. Good night
EDIT: Thanks for the hint. Will do as soon as I get rid of the 422 error logging in, something with my OTP. Tomorrow. yyaaaawwwnourt.
philm
17 August 2021 06:44
78
That dialog is not part of Pamac . I think @Ste74 introduced it as an additional helper called manjaro-aur-support to the Gnome edition.
fch
17 August 2021 07:10
79
With those great news about choosing btrfs for swap, is it also available to choose btrfs for the whole system on calamares while performing a fresh install? Thanks for the great work!
omano
17 August 2021 08:47
80
I think that is actually the other way around. You can select BTRFS as file system, and it works with SWAP file.
philm:
This release features major improvements to Calamares , including filesystem selection for automatic partitioning and enhanced support for btrfs . For btrfs installations, the default subvolume layout has been improved for easier rollbacks and less wasted space on snapshots. Additionally, swapfiles on btrfs filesystem are now supported.
Wollie
Split this topic
17 August 2021 10:14
81
4 posts were split to a new topic: Issues after update
AlanP
17 August 2021 10:35
82
What is matray used for ?
