I use XFS as / partitionwith manjaro, so cool and so fast.
but have to be done manually and not so difficult to do.
happy to see there is another XFS Lover in town
I’m currently running the stable-staging and i’m pretty happy with it.
But i’d love to see Manjaro put some more attention to stuffs like
- Sharing Folders on LAN
Well there are was ways to do that all over the internet but those are so complicated when we often have no time for that “samba here, samba there etc.”
Please make as easy as a click is so we can stop being rejected by mate at work or in our Home office LAN for both Plasma and Gnome (because those are the biggest player in town).
Thanks Phil, Thanks team!
Does the btrfs installation includes compression by default or it has to be done manually?
Plasma already has a one click share button,if you right click on the folder and go to sharing tab.
You can also install warpinator or nitroshare applications to share folder over LAN.
I doubt that Calamares supports this so has to be done manually.
It shows new announcements on forum as notifications and allows quick access to the corresponding thread to check if there are some expected problems or manual intervention needed.
I made some tests with the Manjaro 21.1 KDE minimal ISO.
Installation of Manjaro: OK.
Installation of some software: OK.
Installation of Global themes: OK.
Installation of other menu (launchpad menu): OK.
Maytray error → I disabled Maytray.
Use Dolphin: OK.
By default, it is X11 who is used. Now, I want to switch to Wayland. How to do that ?
Is Optimus technology is taken in account by Wayland now ? I’ve got a laptop with the Optimus technology.
Thanks.
As far as I know it is still in a technical preview state (google KDE Wayland). Nvidia on top of that is multiplying the issues. Try it for yourself you’ll see what works.
Search KDE enable Wayland on the forum.
